查看: 3525|回复: 4
[其它] Vias between layers in CADENCE and TSMC PDK
发表于 2015-1-9 00:59:00 | 显示全部楼层 |阅读模式
Hi,
  I'm new in Cadence and I'm designing circuits with TSMC0.13umPDK. My circuit contains 8 layers, but I don't know; how to place a via betweentwo layers? for example metal via between met1 and met2.
  I'm trying to do this in schematic, may be this is notpossible in the schematic? because in the vias folder of my KitDesign TSMC90nm thereare only symbolic and layout folders? if this is correct in which step, we canadd vias between layers and via_gnd to take their influence in the performanceof the designed circuits (during simulation with cadence).
  I will appreciate your help.
发表于 2015-1-9 08:28:00 | 显示全部楼层
Basically you can't include the effect of via during the schematic simulation. You need to layout the circuit and do extraction so you can get the via resistance. If you want to learn IC design, I suggest you to learn with someone who have some experience. Otherwise you will waste a lot of time.
 楼主| 发表于 2015-1-10 20:49:31 | 显示全部楼层
回复 2# podcast
Thanks for your help.
发表于 2015-4-14 22:00:36 | 显示全部楼层
呵呵
发表于 2022-6-24 14:43:34 | 显示全部楼层
thansk
GMT+8, 2025-9-13 22:51 , Processed in 0.017884 second(s), 5 queries , Gzip On, Redis On.
