查看: 11762|回复: 22
[求助] LVS时出现的错误
发表于 2015-1-8 14:56:01 | 显示全部楼层 |阅读模式
很明显的版图的9个器件与电路的9个器件对应起来,连线也没问题,但总是会有以下错误,求高手解决!!!谢谢!!!
                                 INCORRECT INSTANCES
DISC#  LAYOUT NAME                                               SOURCE NAME
  3    (S(GP)2)                                                  ** missing gate **
       Transistors:
         X11/X44(299.240,450.930)  GP
         X11/X45(300.340,450.930)  GP
  4    (S(GP)2)                                                  ** missing gate **
       Transistors:
         X11/X58(387.430,450.730)  GP
         X11/X60(388.530,450.730)  GP
  5    (S(GP)2)                                                  ** missing gate **
       Transistors:
         X11/X68(417.400,447.010)  GP
         X17/X82/X34/X1/X1/X1/X0(241.720,595.000)  GP
  6    (S(GP)2)                                                  ** missing gate **
       Transistors:
         X11/X72/X0(407.380,447.010)  GP
         X11/X73/X0(408.980,447.010)  GP
  7    (S(GP)2)                                                  ** missing gate **
       Transistors:
         X17/X15(264.220,561.250)  GP
         X17/X82/X33/X1/X1/X1/X0(241.720,567.800)  GP
  8    (S(GP)2)                                                  ** missing gate **
       Transistors:
         X18/X45(200.510,356.880)  GP
         X18/X41(213.685,348.380)  GP
  9    (S(GP)2)                                                  ** missing gate **
       Transistors:
         X21/X71/X0(272.290,31.690)  GP
         X21/X44/X0(272.290,37.690)  GP
10    (S(GP)2)                                                  ** missing gate **
       Transistors:
         X21/X72/X0(260.690,31.690)  GP
         X21/X45/X0(260.690,37.690)  GP
11    (S(GP)2)                                                  ** missing gate **
       Transistors:
         X21/X73/X0(249.890,31.690)  GP
         X21/X46/X0(249.890,37.690)  GP
12    ** missing gate **                                        (SUP2)
        Transistors:
        XI23/XI140/XM5  GP
        XI23/XI140/XM0  GP
13    ** missing gate **                                        (SUP2)
        Transistors:
        XM5==4  GP
        XM4  GP
14    ** missing gate **                                        (SUP2)
        Transistors:
        XI61/XP167==12  GP
        XI61/XP196==12  GP
15    ** missing gate **                                        (SUP2)
        Transistors:
        XI79/XI6/XM52  GP
        XI79/XI6/XM56  GP
16    ** missing gate **                                        (SUP2)
        Transistors:
        XI79/XI6/XM49  GP
        XI79/XI6/XM48  GP
17    ** missing gate **                                        (SUP2)
        Transistors:
        XI79/XI6/XM38  GP
        XI79/XI6/XM37  GP
18    ** missing gate **                                        (SUP2)
        Transistors:
        XI79/XI59/XM0==2  GP
        XI79/XI59/XP31==4  GP
19    ** missing gate **                                        (SUP2)
        Transistors:
        XI23/XX561/XI8/XM6  GP
        XI23/XX561/XI8/XM7  GP
20    ** missing gate **                                        (SUP2)
        Transistors:
        XI23/XX558/XI8/XM6  GP
        XI23/XX558/XI8/XM7  GP
发表于 2015-1-8 16:53:09 | 显示全部楼层
详细点呗
发表于 2015-1-8 21:42:20 | 显示全部楼层
像是管子没有识别到?
发表于 2015-1-9 08:19:41 | 显示全部楼层
详细点吧。还有这是什么工具做的啊??
 楼主| 发表于 2015-1-9 09:09:14 | 显示全部楼层
HHNEC的CD350工艺,calibre
发表于 2015-1-9 10:04:59 | 显示全部楼层
net list 抓出來 是 SUP2
layout 抓出來  是 SGP2
有可能 type 錯了 或是 layout 上 layer 有錯或有少
導致認成 其他 device
把另一段 寫 device 數量 unmatch 的部份
舖上來看看
 楼主| 发表于 2015-1-9 10:51:08 | 显示全部楼层
回复 6# motofatfat
INITIAL NUMBERS OF OBJECTS
                Layout    Source         Component Type
Nets:             249       203    *
Instances:        292       163    *    M (4 pins)
                   479       428    *    GP (5 pins)
                     8         8         Q (3 pins)
                    33        16    *    C (2 pins)
                    98        31    *    R (2 pins)
                     1         1         D (2 pins)
                    67        55    *    NH (5 pins)
Total Inst:       978       702
NUMBERS OF OBJECTS AFTER TRANSFORMATION
Nets:             146       146
Instances:        114       114         M (4 pins)
                   124       124         GP (5 pins)
                     8         8         Q (3 pins)
                    13        13         C (2 pins)
                    16        16         R (2 pins)
                     1         1         D (2 pins)
                     5         5         NH (5 pins)
                     0         9    *    SUP2 (3 pins)
                     9         0    *    S(GP)2 (4 pins)
                    12        12         SM2 (4 pins)
                     1         1         SM3 (5 pins)
Total Inst:       303       303
       * = Number of objects in layout different from number in source.
 楼主| 发表于 2015-1-9 10:52:51 | 显示全部楼层
回复 6# motofatfat
   这9个器件和版图其它地方的器件画法都是一样的,就不明白单单这9个不识别
发表于 2015-1-9 10:57:52 | 显示全部楼层
如果是type问题mos还是会match的,只是会提示bad component subtype
发表于 2015-1-9 10:59:54 | 显示全部楼层
如果是type的问题,还是会match的,只是会有bad component subtype提示
GMT+8, 2025-12-17 06:40 , Processed in 0.018866 second(s), 3 queries , Gzip On, Redis On.
