查看: 2906|回复: 3
[求助] route_group和route_zrt_group有什么区别吗【已解决】
发表于 2015-1-6 21:51:45 | 显示全部楼层 |阅读模式
如题。
 楼主| 发表于 2015-1-6 21:56:03 | 显示全部楼层
额 刚从手册里找到啦
route_zrt_group performs detail routing of the clock nets.
You can also perform detail routing of the clock nets as a standalone process, using the
route_zrt_group -all_clock_nets -reuse_existing_global_route true
command.
To prevent routing of the clock nets, use the -no_clock_route option of the clock_opt
command
这是手册里的。而route_group应该是global route吧,请大神们指正
发表于 2015-1-7 10:12:25 | 显示全部楼层
你简直把版面当自己的黑板了,呵呵
 楼主| 发表于 2015-1-7 10:51:32 | 显示全部楼层
回复 3# icfbicfb
版大,上面的解释应该正确吧
GMT+8, 2025-10-5 22:51 , Processed in 0.012920 second(s), 3 queries , Gzip On, Redis On.
