查看: 1126|回复: 0
[招聘] 【Marvell Cellular手机部门】招聘ASIC Implementation Engineer
发表于 2015-1-5 13:26:56 | 显示全部楼层 |阅读模式
Job Title: ASIC Implementation Engineer Location: Shanghai/Beijing
Job Description:- Block,IP macro or SoC level implementation in 28nm or 20nm TSMC/UMC process- UPFSynthesis with Synopsys DC or DCT/G flows- RTL2Gateand Gate2Gate formal check with LEC and/or formality
tools.- Workingwith BE team to timing closure in Primetime-SI on multi-corners and multi-modes-
Ability to build or perfect theEDA-methodology-flow with perl, tcl or shell -Knowledge on DFT (mbist/scan) will be an added advantage
Qualifications:- BSEE degree or above- Strong understanding of synthesis flow using DC/DCT/DCG - for a lowpower (UPF) and high speed- complex SoC- Hands on experience with formal verification tools such as LEC and/orformality- Must have the CTS conceptions in ICC at P&R stage
- Strong STA skills. Must have thorough knowledge on closing timing at unit andtop level
- Experience in mbist and scan will be plus- Proficient in Perl, Tcl and Shell programming-Good team work spirit
If you are interested in the position, please send your resume to the following email address:   jiangrr@marvell.comSubject of your email should be: School_Name_Applied position_Information source
Eg.SJTU_Zhang Peng _Data Analyst_BBS
GMT+8, 2025-12-27 14:23 , Processed in 0.014144 second(s), 7 queries , Gzip On, Redis On.
