查看: 5975|回复: 1
allegro 的层叠设置cross section中的shield选项是做什么用的
发表于 2014-12-29 14:04:40 | 显示全部楼层 |阅读模式
如图,shield这一列有什么作用。选和不选有什么区别?谢谢
发表于 2018-11-14 16:13:14 | 显示全部楼层
By using the Setup > Cross-section form you can define how the
board stackup will be built. The board must have at least one internal plane that is defined ! u. Y2 W: y# {: v1 e
as ‘Shielded’. This is necessary for simulating correctly in Allegro SI. Inside the Allegro * B6 ], A  R( O
SI tool is a calculator tool that helps the engineer decide the width of the trace to route to 1 ]' D- ]+ z" y0 U, u( ?
achieve the required impedance。
标注为屏蔽层,就是用来计算阻抗的(参考平面)。
GMT+8, 2025-12-16 00:04 , Processed in 0.018955 second(s), 6 queries , Gzip On, Redis On.
