查看: 3316|回复: 2
[求助] 对ICCUG里面的一些术语不是很了解,求助!
发表于 2014-12-24 09:27:09 | 显示全部楼层 |阅读模式
在CTS部分看到说插入Boundary Cells
    When you are working on a block-level design, you might want to preserve the boundary
conditions of the block’s clock ports (the boundary clock pins). A boundary cell is a fixed
buffer that is inserted immediately after the boundary clock pins to preserve the boundary
conditions of the clock pin.
请问一下什么是
boundary conditions,boundary cells在这里的作用是什么呢?
发表于 2014-12-24 13:27:49 | 显示全部楼层
就是clock port刚进模块插入的第一个buffer,更靠近clock port,
主要是指模块level,
 楼主| 发表于 2014-12-24 13:41:49 | 显示全部楼层
回复 2# icfbicfb
   谢谢版主,大概明白了
GMT+8, 2025-12-30 04:21 , Processed in 0.017449 second(s), 6 queries , Gzip On, Redis On.
