查看: 3542|回复: 0
[讨论] 请教UVM库中uvm_reg::add_hdl_path_slice是不是写错了?
发表于 2014-12-19 17:25:34 | 显示全部楼层 |阅读模式
  1. function void uvm_reg::add_hdl_path_slice(string name,
  2.                                           int offset,
  3.                                           int size,
  4.                                           bit first = 0,
  5.                                           string kind = "RTL");
  6.     uvm_queue #(uvm_hdl_path_concat) paths = m_hdl_paths_pool.get(kind);
  7.     uvm_hdl_path_concat concat;
  8.
  9.     if (first || paths.size() == 0) begin
  10.        concat = new();
  11.        paths.push_back(concat);
  12.     end
  13.     else
  14.        concat = paths.get(paths.size()-1);
  15.    concat.add_path(name, offset, size);
  16. endfunction
    复制代码
这里第11行paths.push_back(concat);是不是应该放在function最后一句写?否则concat.add_path()之后没法更新paths啊?
GMT+8, 2025-12-10 05:08 , Processed in 0.015114 second(s), 6 queries , Gzip On, Redis On.
