查看: 963|回复: 0
[招聘] 【Marvell招聘】ASIC DFT design Engineer
发表于 2014-12-18 16:19:05 | 显示全部楼层 |阅读模式
Job Title: ASIC DFTdesign Engineer
Job Description:
-Block, IP and SoC level DFTimplementation (JTAG, Scan, Mbist and analog/IP test etc.) and RTL integration;
-Participate in test spec/plandefinition; create the DFT design document and signoff DFT reviewchecklists;
-Test patterns/vectors generation andverification;
-Interface to backend team on physicaldesign and timing closure;
-Interface to test engineers on ATE andvectors bring-up and debugging;
-Chip DFT quality sign-off
-DFT STA, constraint generation, formaland timing closure
Qualifications:
- DFT design andintegration experience
- Hands on DFTimplementation experience (Bscan, Mbist, DC/AC Scan, analog IP test circuit integration,IDDQ test, ATPG and test pattern verification)
- Expertise with DFTtools from Synopsy, Mentor, Syntest etc.
- Strong logic designand verification background
- Experience inSynthesis and STA will be plus
- Proficient in Perl,tcl and shell programming
- BSEE degree or above
- Good team workspirit
If you are interested in the position, please send your resume to the following email address:   jiangrr@marvell.com
Subject of your email should be: School_Name_Applied position_Information source
Eg.SJTU_Zhang Peng _Data Analyst_BBS
GMT+8, 2025-12-27 10:43 , Processed in 0.013187 second(s), 4 queries , Gzip On, Redis On.
