查看: 3216|回复: 1
[求助] 关于 verilogout_no tri和 verilogout_show_unconnected_pins 不起作用
发表于 2014-12-17 12:02:18 | 显示全部楼层 |阅读模式
设置了 set verilogout_no_tri true 然后写了一个简单的 三态门代码:module test (clk,en,din,dout);
  input clk,en,din;
  output dout;
  reg dout;
  always@(posedge clk)
    begin
        if(en)
  dout<=din;
else
  dout<=1'bz;
end
endmodule
为什么还是会有警告呢,这个命令没起作用啊
Warning: In design 'test', input pin 'clear' of leaf cell 'dout_tri_enable_reg' is not connected to any net.  Logic 0 assumed. (LINT-0)
Warning: In design 'test', input pin 'preset' of leaf cell 'dout_tri_enable_reg' is not connected to any net.  Logic 0 assumed. (LINT-0)
Warning: In design 'test', input pin 'data_in' of leaf cell 'dout_tri_enable_reg' is not connected to any net.  Logic 0 assumed. (LINT-0)
类似还有 set verilogout_show_unconnected_pins true
和 set_fix_multiple_port_nets -all -buffer_constants
这几个命令都起不到作用
发表于 2018-1-11 13:29:42 | 显示全部楼层
什么原因?
GMT+8, 2025-12-25 12:13 , Processed in 0.017778 second(s), 6 queries , Gzip On, Redis On.
