查看: 4145|回复: 6
eMMC 5.1 host controller
头像被屏蔽
发表于 2014-12-10 16:43:20 | 显示全部楼层 |阅读模式
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2015-3-27 18:18:54 | 显示全部楼层
*Compliance
.Compliant with eMMC Specification Version 5.1
.AMBA AXI Specification Version 3.00 (Standard)
.AMBA AHB Specification Version 2.00 (Optional)
.OCP specification Version 2.2 (Optional)
*Core Features
.Supports one of the following System/Host Interfaces: AHB, AXI or OCP
.Data transfer using PIO mode on the Host Bus Slave interface, using DMA mode on the Host Bus Master interface. Here the Host Bus is AHB or AXI or OCP Interface
.Supports eMMC5.1 Security Protocol Commands
.Supports 32-bit and 64-bit system bus
.Configurable FIFO size to support different block sizes
.Supports Interrupts and wake up functionality
.Supports Internal Clock divider for various card operational modes
*eMMC 5.1 features
.Host clock rate variable between 0 and 200 MHz
.HS400 high speed interface timing mode of up to 400 MB/s data rate
.Field firmware update
.eMMC device health report
.eMMC production state awareness
.Secure removal types
.Backward compatible to 1-bit, 4-bit and 8-bit modes
.Supports Primary & alternate boot modes
.Supports Packed commands, Data Tags, Discard & Sanitize features
.Supports 4KB block support
.Supports Tuning for HS200 mode
.Cyclic Redundancy Check CRC7 for command and CRC16 for data integrity
.Supports MMC Plus and MMC Mobile
.Password protection of Cards
发表于 2015-4-17 12:35:16 | 显示全部楼层
发表于 2015-7-2 11:31:13 | 显示全部楼层
回复 3# kejie
   你好,你的回复是ip吗
发表于 2015-7-4 22:24:38 | 显示全部楼层
发表于 2016-6-27 18:54:27 | 显示全部楼层
感谢楼主的分享
发表于 2016-6-28 14:47:20 | 显示全部楼层
thanks
GMT+8, 2025-11-8 18:12 , Processed in 0.020969 second(s), 8 queries , Gzip On, Redis On.
