查看: 2485|回复: 0
[求助] 简单的Flip_flop测试例做formality错误
发表于 2014-12-9 15:01:20 | 显示全部楼层 |阅读模式
不明白下面最简单的ff做formality都不过,是什么原因,如何改正?谢谢~
report:
Matched Compare Points     BBPin    Loop   BBNet     Cut    Port     DFF     LAT   TOTAL
Passing (equivalent)             0          0         0           0       1         0         0       1
Failing (not equivalent)         0          0         0           0       0         1         0       1
ref:
module ff(
      input d, clk,
      output reg q);
    always @(posedge clk)
      q <= d;
   endmodule
imp:(是通过ISE做map后产生的
`timescale 1 ns/1 ps
module ff (
  clk, d, q
  input clk;
  input d;
  output q;
  wire clk_BUFGP;
  wire GLOBAL_LOGIC1;
  wire \clk/INBUF ;
  wire \q/O ;
  wire \d/INBUF ;
  wire \clk_BUFGP/BUFG/S_INVNOT ;
  wire \clk_BUFGP/BUFG/I0_INV ;
  wire \q/OUTPUT/OFF/O1INV_36 ;
  wire q_OBUF_39;
  wire \q/OUTPUT/OTCLK1INV_33 ;
  wire GND;
  wire VCC;
  initial $sdf_annotate("netgen/map/ff_map.sdf");
  X_IPAD   \clk/PAD  (
    .PAD(clk)
  X_BUF   \clk_BUFGP/IBUFG  (
    .I(clk),
    .O(\clk/INBUF )
  X_OPAD   \q/PAD  (
    .PAD(q)
  X_OBUF   q_OBUF (
    .I(\q/O ),
    .O(q)
  X_IPAD   \d/PAD  (
    .PAD(d)
  X_BUF   d_IBUF (
    .I(d),
    .O(\d/INBUF )
  X_BUFGMUX   \clk_BUFGP/BUFG  (
    .I0(\clk_BUFGP/BUFG/I0_INV ),
    .I1(GND),
    .S(\clk_BUFGP/BUFG/S_INVNOT ),
    .O(clk_BUFGP)
  X_INV   \clk_BUFGP/BUFG/SINV  (
    .I(GLOBAL_LOGIC1),
    .O(\clk_BUFGP/BUFG/S_INVNOT )
  X_BUF   \clk_BUFGP/BUFG/I0_USED  (
    .I(\clk/INBUF ),
    .O(\clk_BUFGP/BUFG/I0_INV )
  X_BUF   \q/OUTPUT/OFF/O1INV  (
    .I(\d/INBUF ),
    .O(\q/OUTPUT/OFF/O1INV_36 )
  X_BUF   \q/OUTPUT/OFF/OMUX  (
    .I(q_OBUF_39),
    .O(\q/O )
  X_BUF   \q/OUTPUT/OTCLK1INV  (
    .I(clk_BUFGP),
    .O(\q/OUTPUT/OTCLK1INV_33 )
  X_FF #(
    .INIT ( 1'b0 ))
  q_22 (
    .I(\q/OUTPUT/OFF/O1INV_36 ),
    .CE(VCC),
    .CLK(\q/OUTPUT/OTCLK1INV_33 ),
    .SET(GND),
    .RST(GND),
    .O(q_OBUF_39)
  X_ONE   GLOBAL_LOGIC1_VCC (
    .O(GLOBAL_LOGIC1)
  X_ZERO   NlwBlock_ff_GND (
    .O(GND)
  X_ONE   NlwBlock_ff_VCC (
    .O(VCC)
endmodule
`timescale  1 ps / 1 ps
module glbl ();
    parameter ROC_WIDTH = 100000;
    parameter TOC_WIDTH = 0;
    wire GSR;
    wire GTS;
    wire PRLD;
    reg GSR_int;
    reg GTS_int;
    reg PRLD_int;
//--------   JTAG Globals --------------
    wire JTAG_TDO_GLBL;
    wire JTAG_TCK_GLBL;
    wire JTAG_TDI_GLBL;
    wire JTAG_TMS_GLBL;
    wire JTAG_TRST_GLBL;
    reg JTAG_CAPTURE_GLBL;
    reg JTAG_RESET_GLBL;
    reg JTAG_SHIFT_GLBL;
    reg JTAG_UPDATE_GLBL;
    reg JTAG_SEL1_GLBL = 0;
    reg JTAG_SEL2_GLBL = 0 ;
    reg JTAG_SEL3_GLBL = 0;
    reg JTAG_SEL4_GLBL = 0;
    reg JTAG_USER_TDO1_GLBL = 1'bz;
    reg JTAG_USER_TDO2_GLBL = 1'bz;
    reg JTAG_USER_TDO3_GLBL = 1'bz;
    reg JTAG_USER_TDO4_GLBL = 1'bz;
    assign (weak1, weak0) GSR = GSR_int;
    assign (weak1, weak0) GTS = GTS_int;
    assign (weak1, weak0) PRLD = PRLD_int;
    initial begin
GSR_int = 1'b1;
PRLD_int = 1'b1;
#(ROC_WIDTH)
GSR_int = 1'b0;
PRLD_int = 1'b0;
    end
    initial begin
GTS_int = 1'b1;
#(TOC_WIDTH)
GTS_int = 1'b0;
    end
endmodule
GMT+8, 2025-12-26 02:48 , Processed in 0.017544 second(s), 6 queries , Gzip On, Redis On.
