查看: 9748|回复: 2
silvaco仿真问题
发表于 2014-11-3 15:35:14 | 显示全部楼层 |阅读模式
本人用silvaco仿真太阳能电池,在光源设置这一块出现这个问题,想请教有经验的或者此方面的高手,这是为什么?不胜感激
Warning: Projection cannot be done with
current bias step.  Using previous solution
for initial guess.
发表于 2015-6-21 17:30:55 | 显示全部楼层
That message also appears in my code. But it seems it doesn't alter anything if the code just keeps running to the end and the result comes out successfully. So don't bother about it if you can get the results.
发表于 2021-7-16 21:35:23 | 显示全部楼层
您好,是不是光照没有影响电场我也遇到类似问题,想请教一下
GMT+8, 2025-12-20 22:08 , Processed in 0.210580 second(s), 8 queries , Gzip On, Redis On.
