查看: 4991|回复: 1
用simulink中的gain模块时报错,求指教这是为什么?
发表于 2014-10-25 10:26:08 | 显示全部楼层 |阅读模式
Warning: Parameter precision loss occurred for 'Gain'. The parameter's value cannot be represented exactly using the run-time data type. A small quantization error has occurred. You can control this diagnostic on
the Diagnostics pane of the Configuration Parameters dialog. This originated from 'test_substage_1_5/Substage_1_5/Gain2'.
 楼主| 发表于 2014-10-26 23:22:46 | 显示全部楼层
好吧,已解决
GMT+8, 2025-12-16 04:20 , Processed in 0.022088 second(s), 5 queries , Gzip On, Redis On.
