查看: 3449|回复: 0
[求助] 请问我用的FPGA的时钟源和ODDR2的IP核可以用在cpld中吗?
发表于 2014-10-23 21:35:03 | 显示全部楼层 |阅读模式
我在Xilinx ISE中直接把原来用于FPGA的程序改为CPLD的了,直接改到器件,综合会出现错误:ERROR:NgdBuild:604 - logical block 'oddr2_inst' with type 'ODDR2' could not be
   resolved. A pin name misspelling can cause this, a missing edif or ngc file,
   case mismatch between the block name and the edif or ngc file name, or the
   misspelling of a type name. Symbol 'ODDR2' is not supported in target 'xbr'.
ERROR:NgdBuild:973 - The IBUFG symbol 'clk_inst/clkin1_buf' is not supported in
   the xbr architecture.
ERROR:NgdBuild:604 - logical block 'clk_inst/dcm_sp_inst' with type 'DCM_SP'
   could not be resolved. A pin name misspelling can cause this, a missing edif
   or ngc file, case mismatch between the block name and the edif or ngc file
   name, or the misspelling of a type name. Symbol 'DCM_SP' is not supported in
   target 'xbr'.
ERROR:NgdBuild:770 - IBUF 'clk_IBUF' and IBUFG 'clkin1_buf' on net 'clk_IBUF'
   are lined up in series. Buffers of the same direction cannot be placed in
   series.
ERROR:NgdBuild:925 - input net 'clk_IBUF' is connected to the incorrect side of
   buffer(s):
ERROR:NgdBuild:770 - BUFG 'clkout1_buf' and BUFG 'clkout1_buf' on net
   'clk_inst/clk0' are lined up in series. Buffers of the same direction cannot
   be placed in series.
ERROR:NgdBuild:770 - BUFG 'clkout3_buf' and BUFG 'clkout3_buf' on net
   'clk_inst/clk180' are lined up in series. Buffers of the same direction
   cannot be placed in series.
ERROR:NgdBuild:770 - BUFG 'clkout4_buf' and BUFG 'clkout4_buf' on net
   'clk_inst/clk270' are lined up in series. Buffers of the same direction
ERROR:NgdBuild:770 - BUFG 'clkout2_buf' and BUFG 'clkout2_buf' on net
   'clk_inst/clk90' are lined up in series. Buffers of the same direction cannot
有那位大神知道吗?
GMT+8, 2025-12-21 13:19 , Processed in 0.013160 second(s), 6 queries , Gzip On, Redis On.
