查看: 2800|回复: 0
[求助] 虚拟机 ubuntu下 D C license问题
发表于 2014-10-23 16:56:28 | 显示全部楼层 |阅读模式
windows 系统的主机,安装了 Oracle 虚拟机。
虚拟机系统是Ubuntu 14.4 ,下载了DC 的安装文件,安装成功。
license的设置 完全参照了 本站的 帖子,换了好几个帖子的方法,运行 sssverify  提示license 可用。
设置好环境变量如下
export PATH="/home/ubuntu/synopsys/B-2008.09/bin:"$PATH
#lmgrd
export PATH="/home/ubuntu/synopsys/scl/linux/bin:"$PATH
#start synopsys license using lmgrd
alias lmli2="lmgrd -c /home/ubuntu/synopsys/license/synopsys.dat -l ~/syn_lic.log"
export SYNOPSYS="/home/ubuntu/synopsys/"
export SNPSLMD_LICENSE_FILE=27000@ubuntu
alias dc="dc_shell"
alias dv="design_vision"
安装路径/home/ubuntu/synopsys/   ,其下包含
B-2008.09 是 DC的安装目录;
scl 是SLC的安装目录
license 存放license目录
系统启动后在终端直接运行 ./lmgrd -c /home/ubuntu/synopsys/license/synopsys.dat
输出结果 如下
ubuntu@ubuntu-VirtualBox:~/synopsys/scl/linux/bin$ 16:55:32 (lmgrd) -----------------------------------------------
16:55:32 (lmgrd)   Please Note:
16:55:32 (lmgrd)
16:55:32 (lmgrd)   This log is intended for debug purposes only.
16:55:32 (lmgrd)   In order to capture accurate license
16:55:32 (lmgrd)   usage data into an organized repository,
16:55:32 (lmgrd)   please enable report logging. Use Macrovision's
16:55:32 (lmgrd)   software license administration  solution,
16:55:32 (lmgrd)   FLEXnet Manager, to  readily gain visibility
16:55:32 (lmgrd)   into license usage data and to create
16:55:32 (lmgrd)   insightful reports on critical information like
16:55:32 (lmgrd)   license availability and usage. FLEXnet Manager
16:55:32 (lmgrd)   can be fully automated to run these reports on
16:55:32 (lmgrd)   schedule and can be used to track license
16:55:32 (lmgrd)   servers and usage across a heterogeneous
16:55:32 (lmgrd)   network of servers including Windows NT, Linux
16:55:32 (lmgrd)   and UNIX. Contact Macrovision at
16:55:32 (lmgrd)   www.macrovision.com for more details on how to
16:55:32 (lmgrd)   obtain an evaluation copy of FLEXnet Manager
16:55:32 (lmgrd)   for your enterprise.
16:55:32 (lmgrd)
16:55:32 (lmgrd)
16:55:32 (lmgrd)
16:55:32 (lmgrd) "ubuntu-VirtualBox": Not a valid server hostname, exiting.
16:55:32 (lmgrd) Valid license server system hosts are: "VJAPTU52UN4EYAL"
16:55:32 (lmgrd) Using license file "/home/ubuntu/synopsys/license/synopsys.dat"
求大神帮忙
GMT+8, 2025-12-28 23:24 , Processed in 0.014995 second(s), 4 queries , Gzip On, Redis On.
