查看: 1890|回复: 2
[资料] 大型设计的仿真
发表于 2014-10-22 07:33:14 | 显示全部楼层 |阅读模式
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity cpri_tx_s_module is
end entity;
architecture rtl of cpri_tx_s_module is
    component cpri_tx_s_module is
port (
       --global signal
reset
: in  std_logic;
speed_sel
: in  std_logic_vector(1 downto 0);
pll_ref_clk
: in  std_logic;
pulse_10ms
: in  std_logic;
pulse_10ms_tx
: out std_logic;
   tx_hdlc_rate          : in  std_logic_vector(2 downto 0);
--serdes
   ser_tx_k_A              : out std_logic_vector(1 downto 0);
   ser_txd_A               : out std_logic_vector(15 downto 0);
   ser_tx_k_B              : out std_logic_vector(1 downto 0);
   ser_txd_B               : out std_logic_vector(15 downto 0);
   ser_tx_k_C              : out std_logic_vector(1 downto 0);
   ser_txd_C               : out std_logic_vector(15 downto 0);
   ser_tx_k_D              : out std_logic_vector(1 downto 0);
   ser_txd_D               : out std_logic_vector(15 downto 0);
--send repeater serial number
repeater_serial_number
: in  std_logic_vector(31 downto 0);
--DELAY TUNE
parallel_compensate_value_A : in std_logic_vector(15 downto 0);
parallel_compensate_value_B : in std_logic_vector(15 downto 0);
parallel_compensate_value_C : in std_logic_vector(15 downto 0);
parallel_compensate_value_D : in std_logic_vector(15 downto 0);
--send carrier number
carrier_number_2_1
carrier_number_4_3
carrier_number_6_5
carrier_number_8_7
carrier_number_10_9
carrier_number_12_11 : in  std_logic_vector(15 downto 0);
carrier_number_14_13 : in  std_logic_vector(15 downto 0);
carrier_number_16_15 : in  std_logic_vector(15 downto 0);
--lou delay count
frame_delay_cnt_local_A : in std_logic_vector(15 downto 0);
frame_delay_cnt_local_B : in std_logic_vector(15 downto 0);
frame_delay_cnt_local_C : in std_logic_vector(15 downto 0);
frame_delay_cnt_local_D : in std_logic_vector(15 downto 0);
--lou gain
lou_gain
lou_power_input_dl
phy_reset_indicate
: in std_logic_vector(7 downto 0);
--downlink_indicate
downlink_indicate_A
downlink_indicate_B
downlink_indicate_C
downlink_indicate_D
--hdlc
   hdlc_tx_data
: in  std_logic;
   hdlc_tx_clk
    : out std_logic;
tx_isk_eth
tx_data_eth
ethernet_tx_pulse
: out std_logic;
--iq
iq_tx_pulse_cpri_first_test : out std_logic;
iq_tx_pulse_first
: in  std_logic;
iq_tx_pulse_second
: in  std_logic;
tx_data_iq_first      : in  std_logic_vector(15 downto 0);
tx_data_iq_second     : in  std_logic_vector(15 downto 0)
    end component;
       --global signal
signal
reset
:   std_logic:='0';
signal
speed_sel
:   std_logic_vector(1 downto 0):="01";
signal
pll_ref_clk
:   std_logic:='0';
signal
pulse_10ms
:   std_logic:='0';
signal
pulse_10ms_tx
:  std_logic;
signal   tx_hdlc_rate          :   std_logic_vector(2 downto 0):="001";
--serdes
signal  ser_tx_k_A              :  std_logic_vector(1 downto 0);
signal   ser_txd_A               :  std_logic_vector(15 downto 0);
signal   ser_tx_k_B              :  std_logic_vector(1 downto 0);
signal   ser_txd_B               :  std_logic_vector(15 downto 0);
signal   ser_tx_k_C              :  std_logic_vector(1 downto 0);
signal   ser_txd_C               :  std_logic_vector(15 downto 0);
signal   ser_tx_k_D              :  std_logic_vector(1 downto 0);
signal   ser_txd_D               :  std_logic_vector(15 downto 0);
signal
:   std_logic_vector(31 downto 0):=x"1111_1111";
--DELAY TUNE
signal
parallel_compensate_value_A :  std_logic_vector(15 downto 0):=x"0001";
signal
parallel_compensate_value_B :  std_logic_vector(15 downto 0):=x"0011";
signal
parallel_compensate_value_C :  std_logic_vector(15 downto 0):=x"0111";
signal
parallel_compensate_value_D :  std_logic_vector(15 downto 0):=x"1001";
signal
carrier_number_2_1
:   std_logic_vector(15 downto 0):=x"1111";
signal
carrier_number_4_3
:   std_logic_vector(15 downto 0):=x"1011";
signal
carrier_number_6_5
:   std_logic_vector(15 downto 0):=x"1110";
signal
carrier_number_8_7
signal
carrier_number_10_9
signal
carrier_number_12_11 :   std_logic_vector(15 downto 0):=x"1111";
signal
carrier_number_14_13 :   std_logic_vector(15 downto 0):=x"1110";
signal
carrier_number_16_15 :   std_logic_vector(15 downto 0):=x"0111";
--lou delay count
signal
frame_delay_cnt_local_A :  std_logic_vector(15 downto 0):=x"4441";
signal
frame_delay_cnt_local_B :  std_logic_vector(15 downto 0):=x"5551";
signal
frame_delay_cnt_local_C :  std_logic_vector(15 downto 0):=x"6661";
signal
frame_delay_cnt_local_D :  std_logic_vector(15 downto 0):=x"7771";
--lou gain
signal
lou_gain
signal
lou_power_input_dl
signal
phy_reset_indicate
:  std_logic_vector(7 downto 0):=x"0001";
--downlink_indicate
signal
downlink_indicate_A
signal
downlink_indicate_B
signal
downlink_indicate_C
signal
downlink_indicate_D
--hdlc
   hdlc_tx_data
: in  std_logic;
   hdlc_tx_clk
    : out std_logic;
signal
tx_isk_eth
:  std_logic_vector(1 downto 0):=x"00";
signal
tx_data_eth
:  std_logic_vector(15 downto 0):=x"0000";
signal
ethernet_tx_pulse
:  std_logic;
--iq
signal
iq_tx_pulse_cpri_first_test :  std_logic;
signal
iq_tx_pulse_first
:   std_logic:='0';
signal
iq_tx_pulse_second
:   std_logic:='0';
signal
tx_data_iq_first      :   std_logic_vector(15 downto 0):=x"0000";
signal
tx_data_iq_second     :  std_logic_vector(15 downto 0):=x"0000";
-- Clock period definitions
    constant pll_ref_clk_period : time := 10 ns;
begin
   uut: cpri_tx_s_module
   PORT MAP (
          reset
=> logic_reset,
          speed_sel
=> "01",
          pll_ref_clk
=> global_clk,
          pulse_10ms
=> '0',
pulse_10ms_tx
=> pulse_10ms_tx,-- : out std_logic;
          tx_hdlc_rate
=> "011",
--serdes
ser_tx_k_A              =>
ser_tx_k_A,--
ser_txd_A               =>
ser_txd_A,--
ser_tx_k_B              =>
ser_tx_k_B,--
ser_txd_B               =>
ser_txd_B,--
ser_tx_k_C              =>
ser_tx_k_C,--
ser_txd_C               =>
ser_txd_C,--
ser_tx_k_D              =>
ser_tx_k_D,--
ser_txd_D               =>
ser_txd_D,--
repeater_serial_number,--: in  std_logic_vector(31 downto 0);
--DELAY TUNE
parallel_compensate_value_A => parallel_compensate_value_A,--
parallel_compensate_value_B => parallel_compensate_value_B,--
parallel_compensate_value_C => parallel_compensate_value_C,--
parallel_compensate_value_D => parallel_compensate_value_D,--
carrier_number_2_1      =>
carrier_number_2_1,
carrier_number_4_3      =>
carrier_number_4_3,
carrier_number_6_5      =>
carrier_number_6_5,
carrier_number_8_7      =>
carrier_number_8_7,
carrier_number_10_9     =>
carrier_number_10_9,
carrier_number_12_11    =>
carrier_number_12_11,
carrier_number_14_13    =>
carrier_number_14_13,
carrier_number_16_15    =>
carrier_number_16_15,
--lou delay count
frame_delay_cnt_local_A =>
frame_delay_cnt_local_A,--: in std_logic_vector(15 downto 0);
frame_delay_cnt_local_B =>
frame_delay_cnt_local_B,--: in std_logic_vector(15 downto 0);
frame_delay_cnt_local_C =>
frame_delay_cnt_local_C,--: in std_logic_vector(15 downto 0);
frame_delay_cnt_local_D =>
frame_delay_cnt_local_D,--: in std_logic_vector(15 downto 0);
--lou gain
lou_gain
=> lou_gain,--: in  std_logic_vector(15 downto 0);
lou_power_input_dl
=> lou_power_input_dl,--: in  std_logic_vector(15 downto 0);
phy_reset_indicate
=> phy_reset_indicate_tx,--: out std_logic_vector(7 downto 0);
--downlink_indicate
downlink_indicate_A
=> downlink_indicate_A,--: in std_logic_vector(15 downto 0);
downlink_indicate_B
=> downlink_indicate_B,--: in std_logic_vector(15 downto 0);
downlink_indicate_C
=> downlink_indicate_C,--: in std_logic_vector(15 downto 0);
downlink_indicate_D
=> downlink_indicate_D,--: in std_logic_vector(15 downto 0);
hdlc_tx_data
=>  : in  std_logic;
hdlc_tx_clk
   =>  : out std_logic;
tx_isk_eth
=>  tx_isk_eth,--: in std_logic_vector(1 downto 0);
tx_data_eth
=>  tx_data_eth,--: in std_logic_vector(15 downto 0);
ethernet_tx_pulse
=>  ethernet_tx_pulse,--: out std_logic;
iq_tx_pulse_cpri_first_test => iq_tx_pulse_cpri_first_test,--: out std_logic;
          iq_tx_pulse_first
=> iq_tx_pulse_out_first_i,
          iq_tx_pulse_second
=> iq_tx_pulse_out_second,
          tx_data_iq_first
=> tx_data_iq_out_first_i,--test_count,
          tx_data_iq_second
=> tx_data_iq_out_second--test_count
signal
tx_data_iq_first      : in  std_logic_vector(15 downto 0):=x"0000";
signal
iq_tx_pulse_first
: in  std_logic:='0';
signal
tx_isk_eth
: in std_logic_vector(1 downto 0):=x"00";
signal
tx_data_eth
-- Clock process definitions
        pll_ref_clk_process :process
        begin
    pll_ref_clk <= '0';
    wait for pll_ref_clk_period/2;
    pll_ref_clk <= '1';
        end process;
    tb :process
begin
   wait for 10ns;
   pulse_10ms <= '1';
   wait for 10ns;
   wait for 6143990ns;
end process;
tb1 :process(pll_ref_clk)
begin
   tx_data_iq_first <=  tx_data_iq_first + '1';
end process;
发表于 2014-10-22 11:50:43 | 显示全部楼层
高手兄,这是要干嘛啊
发表于 2014-10-27 13:29:07 | 显示全部楼层
testbench?
GMT+8, 2025-12-28 12:07 , Processed in 0.022720 second(s), 6 queries , Gzip On, Redis On.
