查看: 8535|回复: 3
[求助] 综合veriog问题请教"signed to unsigned conversion occurs"
发表于 2014-10-21 05:14:07 | 显示全部楼层 |阅读模式
各位好,
在下用Design Compiler综合verilog代码的时候总遇到一些warning,想请教各位是怎么回事,十分感谢,代码和具体信息如下:
module PartialProdGen(out, A, B);    parameter BITWIDTH = 6'b010000;
    input [BITWIDTH - 1 : 0] A, B;
    output [BITWIDTH * BITWIDTH - 1 : 0] out;
    wire [BITWIDTH * BITWIDTH - 1 : 0] out;
    generate
     genvar i, j;
    for(i = 0; i < BITWIDTH; i = i + 1)
    begin: gen_1
        for(j = 0; j < BITWIDTH; j = j + 1)
        begin: gen_2
            assign out[BITWIDTH * i + j] = A[j] & B;
        end        ------------16行
    end        ------------17行
    endgenerateendmodule
Warning:  Starting with the 2000.11-1 release, the Presto Verilog reader treats Verilog 'integer' types as signed; synthesized result may not match earlier versions of HDL Compiler. (VER-314)
Warning:  /homes/mccc/DV_WORK4/source_code/PartialProdGen.v:17: signed to unsigned conversion occurs. (VER-318)
Warning:  /homes/mccc/DV_WORK4/source_code/PartialProdGen.v:16: signed to unsigned conversion occurs. (VER-318)
发表于 2017-6-15 10:09:35 | 显示全部楼层
第15行错了,1bit=1bit(按位异或)多bits,这样是错误的
发表于 2017-6-15 10:10:25 | 显示全部楼层
回复 2# 阿盟爱自由
按位与,写错了,不要在意这些细节
发表于 2017-6-15 22:38:55 | 显示全部楼层
signed 类型的数据转换成了unsigned, 应该是两中类型的信号混用了
GMT+8, 2025-12-22 19:04 , Processed in 0.017561 second(s), 7 queries , Gzip On, Redis On.
