查看: 2912|回复: 5
[求助] 初次接触dc,跑完了脚本,时序违反怎么看,报告如下
发表于 2014-10-17 12:08:26 | 显示全部楼层 |阅读模式
Information: Propagating switching activity (low effort zero delay simulation). (PWR-6)
Warning: Design has unannotated primary inputs. (PWR-414)
Warning: Design has unannotated sequential cell outputs. (PWR-415)
Report : constraint
        -all_violators
Design : aes_ASIC
Version: C-2009.06-SP5
Date   : Wed Oct 15 23:21:06 2014
   min_delay/hold ('wb_clk' group)
                             Required        Actual
   Endpoint                 Path Delay     Path Delay        Slack
   PAD_wb_ack_o                 2.10           1.43 f        -0.67  (VIOLATED)
   PAD_wb_dat_o[0]              2.10           1.44 f        -0.66  (VIOLATED)
   PAD_wb_dat_o[1]              2.10           1.44 f        -0.66  (VIOLATED)
   PAD_wb_dat_o[2]              2.10           1.44 f        -0.66  (VIOLATED)
   PAD_wb_dat_o[3]              2.10           1.44 f        -0.66  (VIOLATED)
   PAD_wb_dat_o[4]              2.10           1.44 f        -0.66  (VIOLATED)
   PAD_wb_dat_o[5]              2.10           1.44 f        -0.66  (VIOLATED)
   PAD_wb_dat_o[6]              2.10           1.44 f        -0.66  (VIOLATED)
   PAD_wb_dat_o[7]              2.10           1.44 f        -0.66  (VIOLATED)
   PAD_wb_dat_o[8]              2.10           1.44 f        -0.66  (VIOLATED)
   PAD_wb_dat_o[9]              2.10           1.44 f        -0.66  (VIOLATED)
   PAD_wb_dat_o[10]             2.10           1.44 f        -0.66  (VIOLATED)
   PAD_wb_dat_o[11]             2.10           1.44 f        -0.66  (VIOLATED)
   PAD_wb_dat_o[12]             2.10           1.44 f        -0.66  (VIOLATED)
   PAD_wb_dat_o[13]             2.10           1.44 f        -0.66  (VIOLATED)
   PAD_wb_dat_o[14]             2.10           1.44 f        -0.66  (VIOLATED)
   PAD_wb_dat_o[15]             2.10           1.44 f        -0.66  (VIOLATED)
   PAD_wb_dat_o[16]             2.10           1.44 f        -0.66  (VIOLATED)
   PAD_wb_dat_o[17]             2.10           1.44 f        -0.66  (VIOLATED)
   PAD_wb_dat_o[18]             2.10           1.44 f        -0.66  (VIOLATED)
   PAD_wb_dat_o[19]             2.10           1.44 f        -0.66  (VIOLATED)
   PAD_wb_dat_o[20]             2.10           1.44 f        -0.66  (VIOLATED)
   PAD_wb_dat_o[21]             2.10           1.44 f        -0.66  (VIOLATED)
   PAD_wb_dat_o[22]             2.10           1.44 f        -0.66  (VIOLATED)
   PAD_wb_dat_o[23]             2.10           1.44 f        -0.66  (VIOLATED)
   PAD_wb_dat_o[24]             2.10           1.44 f        -0.66  (VIOLATED)
   PAD_wb_dat_o[25]             2.10           1.44 f        -0.66  (VIOLATED)
   PAD_wb_dat_o[26]             2.10           1.44 f        -0.66  (VIOLATED)
   PAD_wb_dat_o[27]             2.10           1.44 f        -0.66  (VIOLATED)
   PAD_wb_dat_o[28]             2.10           1.44 f        -0.66  (VIOLATED)
   PAD_wb_dat_o[29]             2.10           1.44 f        -0.66  (VIOLATED)
   PAD_wb_dat_o[30]             2.10           1.44 f        -0.66  (VIOLATED)
   PAD_wb_dat_o[31]             2.10           1.44 f        -0.66  (VIOLATED)
   aes_top_inst/text_out_reg[0]/D     1.08     0.95 f        -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[1]/D     1.08     0.95 f        -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[2]/D     1.08     0.95 f        -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[3]/D     1.08     0.95 f        -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[4]/D     1.08     0.95 f        -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[5]/D     1.08     0.95 f        -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[6]/D     1.08     0.95 f        -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[7]/D     1.08     0.95 f        -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[8]/D     1.08     0.95 f        -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[9]/D     1.08     0.95 f        -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[10]/D     1.08     0.95 f       -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[11]/D     1.08     0.95 f       -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[12]/D     1.08     0.95 f       -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[13]/D     1.08     0.95 f       -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[14]/D     1.08     0.95 f       -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[15]/D     1.08     0.95 f       -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[16]/D     1.08     0.95 f       -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[17]/D     1.08     0.95 f       -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[18]/D     1.08     0.95 f       -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[19]/D     1.08     0.95 f       -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[20]/D     1.08     0.95 f       -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[21]/D     1.08     0.95 f       -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[22]/D     1.08     0.95 f       -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[23]/D     1.08     0.95 f       -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[24]/D     1.08     0.95 f       -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[25]/D     1.08     0.95 f       -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[26]/D     1.08     0.95 f       -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[27]/D     1.08     0.95 f       -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[28]/D     1.08     0.95 f       -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[29]/D     1.08     0.95 f       -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[30]/D     1.08     0.95 f       -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[31]/D     1.08     0.95 f       -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[32]/D     1.08     0.95 f       -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[33]/D     1.08     0.95 f       -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[34]/D     1.08     0.95 f       -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[35]/D     1.08     0.95 f       -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[36]/D     1.08     0.95 f       -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[37]/D     1.08     0.95 f       -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[38]/D     1.08     0.95 f       -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[39]/D     1.08     0.95 f       -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[40]/D     1.08     0.95 f       -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[41]/D     1.08     0.95 f       -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[42]/D     1.08     0.95 f       -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[43]/D     1.08     0.95 f       -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[44]/D     1.08     0.95 f       -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[45]/D     1.08     0.95 f       -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[46]/D     1.08     0.95 f       -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[47]/D     1.08     0.95 f       -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[48]/D     1.08     0.95 f       -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[49]/D     1.08     0.95 f       -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[50]/D     1.08     0.95 f       -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[51]/D     1.08     0.95 f       -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[52]/D     1.08     0.95 f       -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[53]/D     1.08     0.95 f       -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[54]/D     1.08     0.95 f       -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[55]/D     1.08     0.95 f       -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[56]/D     1.08     0.95 f       -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[57]/D     1.08     0.95 f       -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[58]/D     1.08     0.95 f       -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[59]/D     1.08     0.95 f       -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[60]/D     1.08     0.95 f       -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[61]/D     1.08     0.95 f       -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[62]/D     1.08     0.95 f       -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[63]/D     1.08     0.95 f       -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[64]/D     1.08     0.95 f       -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[65]/D     1.08     0.95 f       -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[66]/D     1.08     0.95 f       -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[67]/D     1.08     0.95 f       -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[68]/D     1.08     0.95 f       -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[69]/D     1.08     0.95 f       -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[70]/D     1.08     0.95 f       -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[71]/D     1.08     0.95 f       -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[72]/D     1.08     0.95 f       -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[73]/D     1.08     0.95 f       -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[74]/D     1.08     0.95 f       -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[75]/D     1.08     0.95 f       -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[76]/D     1.08     0.95 f       -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[77]/D     1.08     0.95 f       -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[78]/D     1.08     0.95 f       -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[79]/D     1.08     0.95 f       -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[80]/D     1.08     0.95 f       -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[81]/D     1.08     0.95 f       -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[82]/D     1.08     0.95 f       -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[83]/D     1.08     0.95 f       -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[84]/D     1.08     0.95 f       -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[85]/D     1.08     0.95 f       -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[86]/D     1.08     0.95 f       -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[87]/D     1.08     0.95 f       -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[88]/D     1.08     0.95 f       -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[89]/D     1.08     0.95 f       -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[90]/D     1.08     0.95 f       -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[91]/D     1.08     0.95 f       -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[92]/D     1.08     0.95 f       -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[93]/D     1.08     0.95 f       -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[94]/D     1.08     0.95 f       -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[95]/D     1.08     0.95 f       -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[96]/D     1.08     0.95 f       -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[97]/D     1.08     0.95 f       -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[98]/D     1.08     0.95 f       -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[99]/D     1.08     0.95 f       -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[100]/D     1.08     0.95 f      -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[101]/D     1.08     0.95 f      -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[102]/D     1.08     0.95 f      -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[103]/D     1.08     0.95 f      -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[104]/D     1.08     0.95 f      -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[105]/D     1.08     0.95 f      -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[106]/D     1.08     0.95 f      -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[107]/D     1.08     0.95 f      -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[108]/D     1.08     0.95 f      -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[109]/D     1.08     0.95 f      -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[110]/D     1.08     0.95 f      -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[111]/D     1.08     0.95 f      -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[112]/D     1.08     0.95 f      -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[113]/D     1.08     0.95 f      -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[114]/D     1.08     0.95 f      -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[115]/D     1.08     0.95 f      -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[116]/D     1.08     0.95 f      -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[117]/D     1.08     0.95 f      -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[118]/D     1.08     0.95 f      -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[119]/D     1.08     0.95 f      -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[120]/D     1.08     0.95 f      -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[121]/D     1.08     0.95 f      -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[122]/D     1.08     0.95 f      -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[123]/D     1.08     0.95 f      -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[124]/D     1.08     0.95 f      -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[125]/D     1.08     0.95 f      -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[126]/D     1.08     0.95 f      -0.13  (VIOLATED)
   aes_top_inst/text_out_reg[127]/D     1.08     0.95 f      -0.13  (VIOLATED)
   aes_top_inst/text_in_reg[33]/D     1.12     1.00 f        -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[32]/D     1.12     1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[66]/D     1.12         1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[68]/D     1.12         1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[69]/D     1.12         1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[70]/D     1.12         1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[71]/D     1.12         1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[72]/D     1.12         1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[74]/D     1.12         1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[75]/D     1.12         1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[76]/D     1.12         1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[77]/D     1.12         1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[78]/D     1.12         1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[79]/D     1.12         1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[81]/D     1.12         1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[82]/D     1.12         1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[83]/D     1.12         1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[84]/D     1.12         1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[85]/D     1.12         1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[86]/D     1.12         1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[87]/D     1.12         1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[88]/D     1.12         1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[89]/D     1.12         1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[90]/D     1.12         1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[91]/D     1.12         1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[92]/D     1.12         1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[93]/D     1.12         1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[94]/D     1.12         1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[95]/D     1.12         1.00 f        -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[34]/D     1.12     1.00 f        -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[36]/D     1.12     1.00 f        -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[37]/D     1.12     1.00 f        -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[38]/D     1.12     1.00 f        -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[39]/D     1.12     1.00 f        -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[40]/D     1.12     1.00 f        -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[42]/D     1.12     1.00 f        -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[43]/D     1.12     1.00 f        -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[44]/D     1.12     1.00 f        -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[45]/D     1.12     1.00 f        -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[46]/D     1.12     1.00 f        -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[47]/D     1.12     1.00 f        -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[49]/D     1.12     1.00 f        -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[50]/D     1.12     1.00 f        -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[51]/D     1.12     1.00 f        -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[52]/D     1.12     1.00 f        -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[53]/D     1.12     1.00 f        -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[54]/D     1.12     1.00 f        -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[55]/D     1.12     1.00 f        -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[56]/D     1.12     1.00 f        -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[57]/D     1.12     1.00 f        -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[58]/D     1.12     1.00 f        -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[59]/D     1.12     1.00 f        -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[60]/D     1.12     1.00 f        -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[61]/D     1.12     1.00 f        -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[62]/D     1.12     1.00 f        -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[63]/D     1.12     1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[73]/D     1.12         1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[80]/D     1.12         1.00 f        -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[41]/D     1.12     1.00 f        -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[48]/D     1.12     1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[1]/D     1.12          1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[97]/D     1.12         1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[0]/D     1.12          1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[96]/D     1.12         1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[4]/D     1.12          1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[5]/D     1.12          1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[6]/D     1.12          1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[7]/D     1.12          1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[8]/D     1.12          1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[10]/D     1.12         1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[11]/D     1.12         1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[12]/D     1.12         1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[13]/D     1.12         1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[14]/D     1.12         1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[15]/D     1.12         1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[17]/D     1.12         1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[18]/D     1.12         1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[19]/D     1.12         1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[20]/D     1.12         1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[21]/D     1.12         1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[22]/D     1.12         1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[23]/D     1.12         1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[24]/D     1.12         1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[25]/D     1.12         1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[26]/D     1.12         1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[27]/D     1.12         1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[28]/D     1.12         1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[29]/D     1.12         1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[30]/D     1.12         1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[31]/D     1.12         1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[98]/D     1.12         1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[100]/D     1.12        1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[101]/D     1.12        1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[102]/D     1.12        1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[103]/D     1.12        1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[104]/D     1.12        1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[106]/D     1.12        1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[107]/D     1.12        1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[108]/D     1.12        1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[109]/D     1.12        1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[110]/D     1.12        1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[111]/D     1.12        1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[113]/D     1.12        1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[114]/D     1.12        1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[115]/D     1.12        1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[116]/D     1.12        1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[117]/D     1.12        1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[118]/D     1.12        1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[119]/D     1.12        1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[120]/D     1.12        1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[121]/D     1.12        1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[122]/D     1.12        1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[123]/D     1.12        1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[124]/D     1.12        1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[125]/D     1.12        1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[126]/D     1.12        1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[127]/D     1.12        1.00 f        -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[66]/D     1.12     1.00 f        -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[68]/D     1.12     1.00 f        -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[69]/D     1.12     1.00 f        -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[70]/D     1.12     1.00 f        -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[71]/D     1.12     1.00 f        -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[72]/D     1.12     1.00 f        -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[74]/D     1.12     1.00 f        -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[75]/D     1.12     1.00 f        -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[76]/D     1.12     1.00 f        -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[77]/D     1.12     1.00 f        -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[78]/D     1.12     1.00 f        -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[79]/D     1.12     1.00 f        -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[81]/D     1.12     1.00 f        -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[82]/D     1.12     1.00 f        -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[83]/D     1.12     1.00 f        -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[84]/D     1.12     1.00 f        -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[85]/D     1.12     1.00 f        -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[86]/D     1.12     1.00 f        -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[87]/D     1.12     1.00 f        -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[88]/D     1.12     1.00 f        -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[89]/D     1.12     1.00 f        -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[90]/D     1.12     1.00 f        -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[91]/D     1.12     1.00 f        -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[92]/D     1.12     1.00 f        -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[93]/D     1.12     1.00 f        -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[94]/D     1.12     1.00 f        -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[95]/D     1.12     1.00 f        -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[73]/D     1.12     1.00 f        -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[80]/D     1.12     1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[33]/D     1.12         1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[32]/D     1.12         1.00 f        -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[96]/D     1.12     1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[34]/D     1.12         1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[36]/D     1.12         1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[37]/D     1.12         1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[38]/D     1.12         1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[39]/D     1.12         1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[40]/D     1.12         1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[42]/D     1.12         1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[43]/D     1.12         1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[44]/D     1.12         1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[45]/D     1.12         1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[46]/D     1.12         1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[47]/D     1.12         1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[49]/D     1.12         1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[50]/D     1.12         1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[51]/D     1.12         1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[52]/D     1.12         1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[53]/D     1.12         1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[54]/D     1.12         1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[56]/D     1.12         1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[57]/D     1.12         1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[58]/D     1.12         1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[59]/D     1.12         1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[60]/D     1.12         1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[61]/D     1.12         1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[62]/D     1.12         1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[63]/D     1.12         1.00 f        -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[98]/D     1.12     1.00 f        -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[100]/D     1.12     1.00 f       -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[101]/D     1.12     1.00 f       -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[102]/D     1.12     1.00 f       -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[103]/D     1.12     1.00 f       -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[104]/D     1.12     1.00 f       -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[106]/D     1.12     1.00 f       -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[107]/D     1.12     1.00 f       -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[108]/D     1.12     1.00 f       -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[109]/D     1.12     1.00 f       -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[110]/D     1.12     1.00 f       -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[111]/D     1.12     1.00 f       -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[113]/D     1.12     1.00 f       -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[114]/D     1.12     1.00 f       -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[115]/D     1.12     1.00 f       -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[116]/D     1.12     1.00 f       -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[117]/D     1.12     1.00 f       -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[118]/D     1.12     1.00 f       -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[119]/D     1.12     1.00 f       -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[120]/D     1.12     1.00 f       -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[121]/D     1.12     1.00 f       -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[122]/D     1.12     1.00 f       -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[123]/D     1.12     1.00 f       -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[124]/D     1.12     1.00 f       -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[125]/D     1.12     1.00 f       -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[126]/D     1.12     1.00 f       -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[127]/D     1.12     1.00 f       -0.11  (VIOLATED)
   aes_top_inst/key_reg[41]/D     1.12         1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[48]/D     1.12         1.00 f        -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[105]/D     1.12     1.00 f       -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[112]/D     1.12     1.00 f       -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[99]/D     1.12     1.00 f        -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[24]/D     1.12     1.00 f        -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[25]/D     1.12     1.00 f        -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[1]/D     1.12      1.00 f        -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[0]/D     1.12      1.00 f        -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[2]/D     1.12      1.00 f        -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[4]/D     1.12      1.00 f        -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[5]/D     1.12      1.00 f        -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[6]/D     1.12      1.00 f        -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[7]/D     1.12      1.00 f        -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[8]/D     1.12      1.00 f        -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[10]/D     1.12     1.00 f        -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[11]/D     1.12     1.00 f        -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[12]/D     1.12     1.00 f        -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[13]/D     1.12     1.00 f        -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[14]/D     1.12     1.00 f        -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[15]/D     1.12     1.00 f        -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[17]/D     1.12     1.00 f        -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[18]/D     1.12     1.00 f        -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[19]/D     1.12     1.00 f        -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[20]/D     1.12     1.00 f        -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[21]/D     1.12     1.00 f        -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[22]/D     1.12     1.00 f        -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[23]/D     1.12     1.00 f        -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[26]/D     1.12     1.00 f        -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[27]/D     1.12     1.00 f        -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[28]/D     1.12     1.00 f        -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[29]/D     1.12     1.00 f        -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[30]/D     1.12     1.00 f        -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[31]/D     1.12     1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[64]/D     1.12         1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[65]/D     1.12         1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[67]/D     1.12         1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[99]/D     1.12         1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[105]/D     1.12        1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[112]/D     1.12        1.00 f        -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[64]/D     1.12     1.00 f        -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[65]/D     1.12     1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[35]/D     1.12         1.00 f        -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[3]/D     1.12      1.00 f        -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[9]/D     1.12      1.00 f        -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[16]/D     1.12     1.00 f        -0.11  (VIOLATED)
   aes_top_inst/text_in_reg[97]/D     1.12     1.00 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[3]/D     1.12          1.01 f        -0.11  (VIOLATED)
   aes_top_inst/key_reg[16]/D     1.12         1.01 f        -0.11  (VIOLATED)
   aes_top_inst/aes_cipher_inst/done_reg/D     1.10     1.00 f    -0.09 (VIOLATED)
   aes_top_inst/aes_cipher_inst/u0/r0/out_reg[29]/RN     1.10     1.03 f    -0.06 (VIOLATED)
   aes_top_inst/text_in_reg[67]/D     1.12     1.07 f        -0.05  (VIOLATED)
   aes_top_inst/text_in_reg[35]/D     1.11     1.08 f        -0.03  (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_out_reg[1]/D     1.10     1.07 f    -0.03 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_out_reg[9]/D     1.10     1.07 f    -0.03 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_out_reg[25]/D     1.10     1.07 f    -0.03 (VIOLATED)
   aes_top_inst/aes_cipher_inst/dcnt_reg[2]/RN     1.10     1.07 f    -0.03 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_out_reg[94]/D     1.10     1.07 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_out_reg[95]/D     1.10     1.07 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_out_reg[89]/D     1.10     1.07 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_out_reg[90]/D     1.10     1.07 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_out_reg[91]/D     1.10     1.07 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_out_reg[92]/D     1.10     1.07 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_out_reg[93]/D     1.10     1.07 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_out_reg[65]/D     1.10     1.07 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_out_reg[68]/D     1.10     1.07 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_out_reg[74]/D     1.10     1.07 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_out_reg[77]/D     1.10     1.07 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_out_reg[78]/D     1.10     1.07 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_out_reg[79]/D     1.10     1.07 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_out_reg[81]/D     1.10     1.07 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_out_reg[83]/D     1.10     1.07 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_out_reg[84]/D     1.10     1.07 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_out_reg[67]/D     1.10     1.07 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_out_reg[73]/D     1.10     1.07 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_out_reg[75]/D     1.10     1.07 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_out_reg[76]/D     1.10     1.07 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_out_reg[88]/D     1.10     1.07 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_out_reg[97]/D     1.10     1.07 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_out_reg[100]/D     1.10     1.07 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_out_reg[106]/D     1.10     1.07 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_out_reg[109]/D     1.10     1.07 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_out_reg[110]/D     1.10     1.07 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_out_reg[111]/D     1.10     1.07 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_out_reg[113]/D     1.10     1.07 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_out_reg[115]/D     1.10     1.07 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_out_reg[116]/D     1.10     1.07 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_out_reg[126]/D     1.10     1.07 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_out_reg[127]/D     1.10     1.07 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_out_reg[99]/D     1.10     1.07 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_out_reg[105]/D     1.10     1.07 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_out_reg[107]/D     1.10     1.07 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_out_reg[108]/D     1.10     1.07 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_out_reg[121]/D     1.10     1.07 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_out_reg[122]/D     1.10     1.07 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_out_reg[123]/D     1.10     1.07 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_out_reg[124]/D     1.10     1.07 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_out_reg[125]/D     1.10     1.07 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_out_reg[71]/D     1.10     1.07 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_out_reg[72]/D     1.10     1.07 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_out_reg[80]/D     1.10     1.07 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_out_reg[87]/D     1.10     1.07 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_out_reg[64]/D     1.10     1.07 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_out_reg[66]/D     1.10     1.07 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_out_reg[69]/D     1.10     1.07 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_out_reg[70]/D     1.10     1.07 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_out_reg[82]/D     1.10     1.07 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_out_reg[85]/D     1.10     1.07 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_out_reg[86]/D     1.10     1.07 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_out_reg[103]/D     1.10     1.07 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_out_reg[104]/D     1.10     1.07 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_out_reg[112]/D     1.10     1.07 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_out_reg[119]/D     1.10     1.07 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_out_reg[120]/D     1.10     1.07 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_out_reg[96]/D     1.10     1.07 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_out_reg[98]/D     1.10     1.07 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_out_reg[101]/D     1.10     1.07 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_out_reg[102]/D     1.10     1.07 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_out_reg[114]/D     1.10     1.07 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_out_reg[117]/D     1.10     1.07 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_out_reg[118]/D     1.10     1.07 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[0]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[1]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[2]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[3]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[4]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[5]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[6]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[7]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[8]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[9]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[10]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[11]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[12]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[13]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[14]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[15]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[16]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[17]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[18]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[19]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[20]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[21]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[22]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[23]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[24]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[25]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[26]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[27]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[28]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[29]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[30]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[31]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[32]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[33]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[34]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[35]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[36]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[37]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[38]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[39]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[40]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[41]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[42]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[43]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[44]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[45]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[46]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[47]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[48]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[49]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[50]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[51]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[52]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[53]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[54]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[55]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[56]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[57]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[58]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[59]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[60]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[61]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[62]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[63]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[64]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[65]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[66]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[67]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[68]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[69]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[70]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[71]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[72]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[73]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[74]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[75]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[76]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[77]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[78]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[79]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[80]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[81]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[82]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[83]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[84]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[85]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[86]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[87]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[88]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[89]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[90]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[91]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[92]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[93]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[94]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[95]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[96]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[97]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[98]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[99]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[100]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[101]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[102]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[103]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[104]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[105]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[106]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[107]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[108]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[109]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[110]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[111]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[112]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[113]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[114]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[115]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[116]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[117]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[118]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[119]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[120]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[121]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[122]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[123]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[124]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[125]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[126]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_in_r_reg[127]/D     1.03     1.01 f    -0.02 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_out_reg[10]/D     1.10     1.08 f    -0.01 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_out_reg[26]/D     1.10     1.08 f    -0.01 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_out_reg[2]/D     1.10     1.08 f    -0.01 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_out_reg[18]/D     1.10     1.08 f    -0.01 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_out_reg[14]/D     1.10     1.09 f    -0.01 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_out_reg[15]/D     1.10     1.09 f    -0.01 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_out_reg[30]/D     1.10     1.09 f    -0.01 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_out_reg[31]/D     1.10     1.09 f    -0.01 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_out_reg[7]/D     1.10     1.09 f    -0.01 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_out_reg[23]/D     1.10     1.09 f    -0.01 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_out_reg[6]/D     1.10     1.09 f    -0.01 (VIOLATED)
   aes_top_inst/aes_cipher_inst/text_out_reg[22]/D     1.10     1.09 f    -0.01 (VIOLATED)
   aes_top_inst/key_reg[9]/D     1.12          1.12 f         0.00  (VIOLATED: increase signficant digits)
   aes_top_inst/key_reg[2]/D     1.12          1.12 f         0.00  (VIOLATED: increase signficant digits)
   aes_top_inst/key_reg[55]/D     1.12         1.12 f         0.00  (VIOLATED: increase signficant digits)
   aes_top_inst/aes_cipher_inst/text_out_reg[11]/D     1.10     1.10 f     0.00 (VIOLATED: increase signficant digits)
   max_capacitance
                             Required        Actual
   Net                      Capacitance    Capacitance       Slack
   PAD_wb_ack_o                 0.11           2.20          -2.08  (VIOLATED)
   PAD_wb_dat_o[0]              0.11           2.20          -2.08  (VIOLATED)
   PAD_wb_dat_o[1]              0.11           2.20          -2.08  (VIOLATED)
   PAD_wb_dat_o[2]              0.11           2.20          -2.08  (VIOLATED)
   PAD_wb_dat_o[3]              0.11           2.20          -2.08  (VIOLATED)
   PAD_wb_dat_o[4]              0.11           2.20          -2.08  (VIOLATED)
   PAD_wb_dat_o[5]              0.11           2.20          -2.08  (VIOLATED)
   PAD_wb_dat_o[6]              0.11           2.20          -2.08  (VIOLATED)
   PAD_wb_dat_o[7]              0.11           2.20          -2.08  (VIOLATED)
   PAD_wb_dat_o[8]              0.11           2.20          -2.08  (VIOLATED)
   PAD_wb_dat_o[9]              0.11           2.20          -2.08  (VIOLATED)
   PAD_wb_dat_o[10]             0.11           2.20          -2.08  (VIOLATED)
   PAD_wb_dat_o[11]             0.11           2.20          -2.08  (VIOLATED)
   PAD_wb_dat_o[12]             0.11           2.20          -2.08  (VIOLATED)
   PAD_wb_dat_o[13]             0.11           2.20          -2.08  (VIOLATED)
   PAD_wb_dat_o[14]             0.11           2.20          -2.08  (VIOLATED)
   PAD_wb_dat_o[15]             0.11           2.20          -2.08  (VIOLATED)
   PAD_wb_dat_o[16]             0.11           2.20          -2.08  (VIOLATED)
   PAD_wb_dat_o[17]             0.11           2.20          -2.08  (VIOLATED)
   PAD_wb_dat_o[18]             0.11           2.20          -2.08  (VIOLATED)
   PAD_wb_dat_o[19]             0.11           2.20          -2.08  (VIOLATED)
   PAD_wb_dat_o[20]             0.11           2.20          -2.08  (VIOLATED)
   PAD_wb_dat_o[21]             0.11           2.20          -2.08  (VIOLATED)
   PAD_wb_dat_o[22]             0.11           2.20          -2.08  (VIOLATED)
   PAD_wb_dat_o[23]             0.11           2.20          -2.08  (VIOLATED)
   PAD_wb_dat_o[24]             0.11           2.20          -2.08  (VIOLATED)
   PAD_wb_dat_o[25]             0.11           2.20          -2.08  (VIOLATED)
   PAD_wb_dat_o[26]             0.11           2.20          -2.08  (VIOLATED)
   PAD_wb_dat_o[27]             0.11           2.20          -2.08  (VIOLATED)
   PAD_wb_dat_o[28]             0.11           2.20          -2.08  (VIOLATED)
   PAD_wb_dat_o[29]             0.11           2.20          -2.08  (VIOLATED)
   PAD_wb_dat_o[30]             0.11           2.20          -2.08  (VIOLATED)
   PAD_wb_dat_o[31]             0.11           2.20          -2.08  (VIOLATED)
   wb_rst_i (dont_touch)        0.11           2.14          -2.02  (VIOLATED)
   PAD_wb_adr_i[0]              0.11           2.05          -1.94  (VIOLATED)
   PAD_wb_adr_i[1]              0.11           2.05          -1.94  (VIOLATED)
   PAD_wb_adr_i[2]              0.11           2.05          -1.94  (VIOLATED)
   PAD_wb_adr_i[3]              0.11           2.05          -1.94  (VIOLATED)
   PAD_wb_adr_i[4]              0.11           2.05          -1.94  (VIOLATED)
   PAD_wb_adr_i[5]              0.11           2.05          -1.94  (VIOLATED)
   PAD_wb_clk_i (dont_touch)     0.11          2.05          -1.94  (VIOLATED)
   PAD_wb_cyc_i                 0.11           2.05          -1.94  (VIOLATED)
   PAD_wb_dat_i[0]              0.11           2.05          -1.94  (VIOLATED)
   PAD_wb_dat_i[1]              0.11           2.05          -1.94  (VIOLATED)
   PAD_wb_dat_i[2]              0.11           2.05          -1.94  (VIOLATED)
   PAD_wb_dat_i[3]              0.11           2.05          -1.94  (VIOLATED)
   PAD_wb_dat_i[4]              0.11           2.05          -1.94  (VIOLATED)
   PAD_wb_dat_i[5]              0.11           2.05          -1.94  (VIOLATED)
   PAD_wb_dat_i[6]              0.11           2.05          -1.94  (VIOLATED)
   PAD_wb_dat_i[7]              0.11           2.05          -1.94  (VIOLATED)
   PAD_wb_dat_i[8]              0.11           2.05          -1.94  (VIOLATED)
   PAD_wb_dat_i[9]              0.11           2.05          -1.94  (VIOLATED)
   PAD_wb_dat_i[10]             0.11           2.05          -1.94  (VIOLATED)
   PAD_wb_dat_i[11]             0.11           2.05          -1.94  (VIOLATED)
   PAD_wb_dat_i[12]             0.11           2.05          -1.94  (VIOLATED)
   PAD_wb_dat_i[13]             0.11           2.05          -1.94  (VIOLATED)
   PAD_wb_dat_i[14]             0.11           2.05          -1.94  (VIOLATED)
   PAD_wb_dat_i[15]             0.11           2.05          -1.94  (VIOLATED)
   PAD_wb_dat_i[16]             0.11           2.05          -1.94  (VIOLATED)
   PAD_wb_dat_i[17]             0.11           2.05          -1.94  (VIOLATED)
   PAD_wb_dat_i[18]             0.11           2.05          -1.94  (VIOLATED)
   PAD_wb_dat_i[19]             0.11           2.05          -1.94  (VIOLATED)
   PAD_wb_dat_i[20]             0.11           2.05          -1.94  (VIOLATED)
   PAD_wb_dat_i[21]             0.11           2.05          -1.94  (VIOLATED)
   PAD_wb_dat_i[22]             0.11           2.05          -1.94  (VIOLATED)
   PAD_wb_dat_i[23]             0.11           2.05          -1.94  (VIOLATED)
   PAD_wb_dat_i[24]             0.11           2.05          -1.94  (VIOLATED)
   PAD_wb_dat_i[25]             0.11           2.05          -1.94  (VIOLATED)
   PAD_wb_dat_i[26]             0.11           2.05          -1.94  (VIOLATED)
   PAD_wb_dat_i[27]             0.11           2.05          -1.94  (VIOLATED)
   PAD_wb_dat_i[28]             0.11           2.05          -1.94  (VIOLATED)
   PAD_wb_dat_i[29]             0.11           2.05          -1.94  (VIOLATED)
   PAD_wb_dat_i[30]             0.11           2.05          -1.94  (VIOLATED)
   PAD_wb_dat_i[31]             0.11           2.05          -1.94  (VIOLATED)
   PAD_wb_rst_i (dont_touch)     0.11          2.05          -1.94  (VIOLATED)
   PAD_wb_sel_i[0]              0.11           2.05          -1.94  (VIOLATED)
   PAD_wb_sel_i[1]              0.11           2.05          -1.94  (VIOLATED)
   PAD_wb_sel_i[2]              0.11           2.05          -1.94  (VIOLATED)
   PAD_wb_sel_i[3]              0.11           2.05          -1.94  (VIOLATED)
   PAD_wb_stb_i                 0.11           2.05          -1.94  (VIOLATED)
   PAD_wb_we_i                  0.11           2.05          -1.94  (VIOLATED)
   n1                           0.11           0.17          -0.06  (VIOLATED)
   n2                           0.11           0.17          -0.06  (VIOLATED)
   n3                           0.11           0.17          -0.06  (VIOLATED)
   n4                           0.11           0.17          -0.06  (VIOLATED)
   n5                           0.11           0.17          -0.06  (VIOLATED)
   n6                           0.11           0.17          -0.06  (VIOLATED)
   n7                           0.11           0.17          -0.06  (VIOLATED)
   n8                           0.11           0.17          -0.06  (VIOLATED)
   n9                           0.11           0.17          -0.06  (VIOLATED)
   n10                          0.11           0.17          -0.06  (VIOLATED)
   n11                          0.11           0.17          -0.06  (VIOLATED)
   n12                          0.11           0.17          -0.06  (VIOLATED)
   n13                          0.11           0.17          -0.06  (VIOLATED)
   n14                          0.11           0.17          -0.06  (VIOLATED)
   n15                          0.11           0.17          -0.06  (VIOLATED)
   n16                          0.11           0.17          -0.06  (VIOLATED)
   n17                          0.11           0.17          -0.06  (VIOLATED)
   n18                          0.11           0.17          -0.06  (VIOLATED)
   n19                          0.11           0.17          -0.06  (VIOLATED)
   n20                          0.11           0.17          -0.06  (VIOLATED)
   n21                          0.11           0.17          -0.06  (VIOLATED)
   n22                          0.11           0.17          -0.06  (VIOLATED)
   n23                          0.11           0.17          -0.06  (VIOLATED)
   n24                          0.11           0.17          -0.06  (VIOLATED)
   n25                          0.11           0.17          -0.06  (VIOLATED)
   n26                          0.11           0.17          -0.06  (VIOLATED)
   n27                          0.11           0.17          -0.06  (VIOLATED)
   n28                          0.11           0.17          -0.06  (VIOLATED)
   n29                          0.11           0.17          -0.06  (VIOLATED)
   n30                          0.11           0.17          -0.06  (VIOLATED)
   n31                          0.11           0.17          -0.06  (VIOLATED)
   n32                          0.11           0.17          -0.06  (VIOLATED)
   n33                          0.11           0.17          -0.06  (VIOLATED)
   max_area
                             Required        Actual
   Design                      Area           Area           Slack
   aes_ASIC                     0.00       1362990.88     -1362990.88 (VIOLATED)
   max_total_power
                             Required        Actual
   Design                   Total Power    Total Power       Slack
   aes_ASIC                     0.00uw     44375.60uw     -44375.60uw (VIOLATED)
1
 楼主| 发表于 2014-10-17 14:18:24 | 显示全部楼层
顶一顶
发表于 2014-10-17 16:44:35 | 显示全部楼层
negative slack就是违理啊,另外左边的位置也标清楚了,这个有什么疑问么?
发表于 2014-11-10 13:26:31 | 显示全部楼层
哎,新手,不懂,下个软件玩玩
发表于 2015-5-11 15:13:19 | 显示全部楼层
报告前面都写的有的,第一个报告是hold time的违反,这个不是很重要,可以在综合的时候解决,或者在布局布线的时候解决。
发表于 2015-5-11 15:45:53 | 显示全部楼层
igore,都不是大问题
GMT+8, 2025-12-30 02:06 , Processed in 0.069629 second(s), 5 queries , Gzip On, Redis On.
