查看: 1603|回复: 3
[招聘] 【全职】Marvell招聘DSP Engineer_Shanghai/Nanjing
发表于 2014-10-15 17:38:29 | 显示全部楼层 |阅读模式
1Job Title: DSP System Engineer
Department:Cellular Engineering
JobDescription:
PhysicalLayer System Engineer for 3G/GSM UE
MarvellShanghai is now looking for the TD-SCDMA, WCDMA, and GSM physical layerengineers to join us in 3G/2G production. As a worldwide leading fablesssemiconductor company, we are working on 3G/2G communication product andtechnology. You would join in us in the design, development, implementation anddebug of advanced physical layer firmware and system for the wirelesscommunication productions.
Qualification:
- A minimumof Bachelor degree in Electrical Engineering is required with specialization inDSP or communication
-Experience in the develop of the physical layer or L1 Controller of 3G/2G(TD-SCDMA, WCDMA, GSM) are preferred
- Relatedexperience in the 3G/2G system design, Dual RAT, HSPA and system testing is agood plus
- StrongDigital Signal Processing knowledge in the area of digital communication systemand of various digital modulation schemes
- Goodwritten and oral English skills
- Good Teamwork
2Job Title: DSP/Firmware Engineer
JobDescription:
-We arelooking for a DSP/Firmware Engineer with solid background in digitalcommunication and signal processing to join our system design team for wirelesscommunication system, include 2G/3G/4G.
-Thesuccessful candidate is expected to work in a collaborative team oncutting-edge data communication technologies. Responsibility includes designingalgorithm and architecture and implementation for the physical layer of themodems.
-Thisposition also requires close interaction with the digital design team on designspecification, verification and test.
Qualification:
-M.S.orPh.D in Electrical Engineering
-About 3yrs working experience.
-Must havestrong knowledge of digital communication and signal processing theory
-Proficientin building up communication system simulator with C/C++ and Matlab
-Knowledgeand experience on the communication physical layer are preferred
-Familiaritywith DSP and RTL implementation is a good plus.
-Goodcommunication skills in spoken and written English
-Good atcollaboration and team work
3Job Title: DSP Engineer (TD/LTE)
JobDescription:
-We arelooking for a DSP/Firmware Engineer with solid background in digital communicationand signal processing to join our system design team for wireless communicationsystem, include 2G/3G/4G.
Qualification:
4Job Title: DSP/Firmware Audio Engineer
JobDescription:
-We arelooking for a Senior DSP/Firmware Engineer with solid background in audioprocessing to join our system design team for wireless communication system,include 2G/3G/4G
-Helpcustomer do audio design related to the implementation with acoustic componentsand hardware circuit
-Cooperatewith customer to definite and develop audio DSP block
-Instructcustomer to implement audio tuning
-Supportcustomer to analyze and solve audio related problems
Qualification:
-B.Sc. inSignal & information Processing Engineering, Electronic Engineering,Telecommunication Engineering or other relevant major
-At least 3years of relevant working experience with emphasis on audio DSP tuning, hardwarecircuit design
-Familiarwith mobile phone test Standard
-Familiarwith acoustic design of audio components
-Familiarwith architecture application of one audio DSP processor
-Have thebasic knowledge of signal process algorithm, such as echo cancellation and soon
If you are interested in any one of the four positions, please send your resume to the following email address:   jiangrr@marvell.com
Subject of your email should be: School_Name_Applied position_Information source
Eg.SJTU_Zhang Peng _Data Analyst_BBS
发表于 2014-10-16 11:52:41 | 显示全部楼层
疑问:
1 DSP是指DSP芯片之类的器件?比如TI的?还是指信号处理?
2 对RTL有要求,是否岗位对应FPGA+DSP的开发?
 楼主| 发表于 2014-10-17 16:52:58 | 显示全部楼层
回复 2# thyears
   你好!我们这个DSP的职位是信号处理。不需要RTL,基本上是基带物理层的开发,不怎么需要FPGA。
发表于 2014-10-17 21:16:40 | 显示全部楼层
回复 3# Hwangbo
如果C,DSP,FPGA,RTL都没有要求?那需要哪些知识储备?
GMT+8, 2025-12-27 02:31 , Processed in 0.019279 second(s), 6 queries , Gzip On, Redis On.
