查看: 2561|回复: 5
[讨论] set_clock_tree_options -insert_boundary_cell 中的boundary_cell
发表于 2014-10-15 10:35:14 | 显示全部楼层 |阅读模式
哪位大神知道set_clock_tree_options -insert_boundary_cell 中的boundary_cell是什么,在做tree时什么时候需要插入呢?谢谢!
发表于 2014-10-15 10:49:00 | 显示全部楼层
When you are working on a block-level design, you might want to preserve the boundary
conditions of the block’s clock ports (the boundary clock pins). A boundary cell is a fixed
buffer that is inserted immediately after the boundary clock pins to preserve the boundary
conditions of the clock pin.
发表于 2014-10-15 11:00:40 | 显示全部楼层
clk从port进来的第一个buffer
 楼主| 发表于 2014-10-15 11:12:37 | 显示全部楼层
Thanks all, and i want to know what's the boundary conditions,drive strength or others? The boundary is the physical boundary or logical boundary of the block? Thanks again!
 楼主| 发表于 2014-10-15 11:16:05 | 显示全部楼层
   Thanks all, and i want to know what's the boundary conditions, driving strength or others? What is the boundary,physical or logical of the block-level design? Thanks again!
发表于 2014-10-15 16:29:23 | 显示全部楼层
回复 3# icfbicfb
   用了这个命令,作用是啥?自己插上ISO buffer吗?
GMT+8, 2025-11-2 02:55 , Processed in 0.017441 second(s), 4 queries , Gzip On, Redis On.
