楼主: min4max
在Ubuntu上设置并运行Calibre2014的终极解决方案,本方案对其他类似问题也应该有帮助
发表于 2016-3-4 23:14:36 | 显示全部楼层
gooooooooood
发表于 2016-3-14 14:21:26 | 显示全部楼层
其他系统安装破解十一样的吗?
发表于 2016-4-13 23:21:21 | 显示全部楼层
我要下载,求大神帮着安装。
发表于 2016-4-16 15:09:38 | 显示全部楼层
楼主你好,我安装的是calibre2014的aoi版本,但是在patch时出现如下问题:
[total hits/matching patterns/non-matching patterns]
60% ...bwarn : empty file: aoi_cal_2014.4_18.13/tmp/lockmgcld - skippingges
warn : empty file: aoi_cal_2014.4_18.13/tmp/yum-JunliPeng-2tjlSm/x86_64/6/epel/cachecookie - skipping
88% ...2fde8a609215059b5b0319fd660f796d462bbe6warn : empty file: aoi_cal_2014.4_18.13/tmp/yum-JunliPeng-2tjlSm/x86_64/6/base/cachecookie - skipping
94% ...74f8dcb1a38f24a24d90f55442fbbe21188f4e615-primary.sqlite : 0 changewarn : empty file: aoi_cal_2014.4_18.13/tmp/yum-JunliPeng-2tjlSm/x86_64/6/updates/cachecookie - skipping
warn : empty file: aoi_cal_2014.4_18.13/tmp/yum-JunliPeng-2tjlSm/x86_64/6/extras/cachecookie - skipping
                                warn : empty file: aoi_cal_2014.4_18.13/pkgs/icwb/dependencies/version - skipping
68% aoi_cal_2014.4_18.13/shared/systest/test.Calibrervelvs : 0 changeserror: failed to read+write: sfk - skipping
90% inwarn : empty file: install.ixl/JRE/.systemPrefs/.system.lock - skipping
warn : empty file: install.ixl/JRE/.systemPrefs/.systemRootModFile - skipping
9873 files checked, 0 changed.
1 errors, 8 warnings occurred.
请问是什么情况?
发表于 2016-4-21 10:26:53 | 显示全部楼层
多谢楼主
发表于 2016-5-4 14:49:13 | 显示全部楼层
回复 1# min4max
   thanks
发表于 2016-5-15 08:24:26 | 显示全部楼层
回复 1# min4max
    运行patch时出错,怎么解决
sudo ./patch_calibre aoi_cal_2014.4_18.13
65% install.ixl/javerror: failed to read+write: sfk - skippinges
33% ...i_cal_warn : empty file: aoi_cal_2014.4_18.13/pkgs/icwb.aoi/dependencies/version - skipping
9855 files checked, 0 changed.
1 errors, 3 warnings occurred.
发表于 2016-5-18 11:50:11 | 显示全部楼层
回复 1# min4max
aoi版本的calibre  patch无法成功。后换成ixl版本,patch成功。但运行sh cadence提示calibre下的lmgrd not found,还不知道怎么解决
发表于 2016-5-18 15:25:20 | 显示全部楼层
顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶
发表于 2016-5-31 17:11:06 | 显示全部楼层
感謝樓主分享!
GMT+8, 2025-12-28 23:19 , Processed in 0.023174 second(s), 4 queries , Gzip On, Redis On.
