楼主: min4max
在Ubuntu上设置并运行Calibre2014的终极解决方案,本方案对其他类似问题也应该有帮助
发表于 2015-8-16 00:20:14 | 显示全部楼层
Cannot run on Arch linux
发表于 2015-8-16 18:08:51 | 显示全部楼层
回复 57# min4max
大神请帮忙看看这个吧!!
请问该patch是否适用于calibre 2014.4?我用这个patch 2014.4版本时,出现Rochester@P151:~/opt/mentor/Calibre2014$ sudo ./patch_calibre aoi_cal_2014.4_18.13
[sudo] password for Rochester:
[total hits/matching patterns/non-matching patterns]
90error: failed to read+write: sfk - skipping
                                        warn : empty file: aoi_cal_2014.4_18.13/pkgs/icwb.aoi/dependencies/version - skipping
66% install.iwarn : empty file: install.ixl/JRE/.systemPrefs/.system.lock - skipping
warn : empty file: install.ixl/JRE/.systemPrefs/.systemRootModFile - skipping
9862 files checked, 0 changed.
1 errors, 3 warnings occurred.
发表于 2015-8-17 07:56:43 | 显示全部楼层
楼主大神请帮忙看看:按照楼主方法安装之后,运行DRC时报错:the following products could not be licensed sufficiently
calibre interactive
我的OS:ubuntu 14.04LTS
Calibre版本: aoi_cal_2014.4_18.13
整个安装过程可疑的地方:
1. patch的时候报了一个error: failed to read+write: sfk - skipping
2.  license里面按照楼主的介绍,没有头两行server和daemon行,在cadence script里面把license server相关的变量#掉了
请楼主帮忙分析一下可能是什么原因?patch不支持calibre 2014.4?还是license有问题?谢谢!!!
发表于 2015-9-5 19:54:28 | 显示全部楼层
完全看不懂。。。。
发表于 2015-9-8 12:12:53 | 显示全部楼层
回复 63# jhonnyboy
   I had the similar issue. Patch will indicate there are few empty files. I fixed it by adding back server and daemon and then lmgrd the server. There are people had the related problem, but I didn't get this message, I guess your issue are the same as mine. So I am not sure if this is the cause.
ERROR: Current execution environment is VCO=aoi. Software tree is for environment VCO=ixl.
They use the following line to fix it.
setenv CALIBRE_2013_4_ALLOW_IXL_ON_RHEL6 101010
Refer to http://bbs.eetop.cn/thread-469617-2-1.html
发表于 2015-9-13 08:29:05 | 显示全部楼层
这是怎么回事   license不行吗
duobjfghj@fghf:~$ //  Calibre v2014.4_18.13    Wed Nov 5 16:04:06 PST 2014
//  Calibre Utility Library   v0-7_7-2014-2    Tue Jul 8 18:35:09 PDT 2014
//  Litho Libraries v2014.4_18.13  Wed Nov 5 16:04:06 PST 2014
//        Copyright Mentor Graphics Corporation 1996-2014
//                       All Rights Reserved.
//   THIS WORK CONTAINS TRADE SECRET AND PROPRIETARY INFORMATION
//      WHICH IS THE PROPERTY OF MENTOR GRAPHICS CORPORATION
//        OR ITS LICENSORS AND IS SUBJECT TO LICENSE TERMS.
//  Mentor Graphics software executing under x86-64 Linux
//  Running on Linux JhonChou 3.19.0-28-generic #30-Ubuntu SMP Mon Aug 31 15:52:51 UTC 2015 x86_64 glibc 2.21/NPTL 2.21
//  64 bit virtual addressing enabled
//  Running aoi_cal_2014.4_18.13/pkgs/icv/pvt/calibre –gui
//  Process ID: 7565
//  Starting time: Sun Sep 13 08:29:55 2015
发表于 2015-9-13 14:55:30 | 显示全部楼层
赞楼主的勤劳智慧,带走尝试
发表于 2015-9-22 20:12:55 | 显示全部楼层
thanks for sharing
发表于 2015-10-15 15:57:40 | 显示全部楼层
发表于 2015-10-29 11:21:24 | 显示全部楼层
楼主厉害
GMT+8, 2025-12-13 07:07 , Processed in 0.019452 second(s), 4 queries , Gzip On, Redis On.
