查看: 3085|回复: 2
[求助] RGMII信号测试
发表于 2014-10-2 10:52:20 | 显示全部楼层 |阅读模式
RGMII信号测试应该关注哪些参数?TXCTL信号起什么作用?
请大神帮忙解答,感谢!
发表于 2014-10-3 06:18:31 | 显示全部楼层
RGMII is just GMII with multiplexed signals
to send TX_EN or TX_ER,
the TX_CTL is active at same time as TXD
this allows sending of  TX_EN, TX_ER
control encoding is
CTL(rising/falling), DV, ER, D(4 bits rising, 4 bits falling edge clock)
0/0,0,0,    xxxY   -> Y=link status
0/0,0,0      xYYx  ->   RXC clock speed  00=2.5,01=25,10=125,11=rsvd
0/0,0,0      Yxxx, where Y=0->HDX, Y=1 -> FDX
0/1,0,1     FF         -> carrier sense
1/0,1,1    00-FF      -> data error
1/1,1,0   00-FF     -> normal data
or you can take a look at xilinx ip doc
pg160-gmii-to-rgmii.pdf (page 30 or so)
I think there is an RGMII spec floating around here if not then find a PHY or MAC vendor
发表于 2014-10-3 06:19:21 | 显示全部楼层
GMT+8, 2025-12-24 19:40 , Processed in 0.013771 second(s), 3 queries , Gzip On, Redis On.
