查看: 3945|回复: 3
[求助] cscope安装错误:version `GLIBCXX_3.4.9' not found
发表于 2014-9-25 11:30:09 | 显示全部楼层 |阅读模式
今天下了cscope的linux版:CosmosScope64_H-2012.12_linux  安装后用命令cscope发现如下问题:/home/ZYG/zhaowei/synopsysSoft/cscope64_2012.12/./bin/aimsh: /usr/lib64/libstdc++.so.6: version `GLIBCXX_3.4.11' not found (required by /home/ZYG/zhaowei/synopsysSoft/cscope64_2012.12/./bin/libai_analogy.so)
/home/ZYG/zhaowei/synopsysSoft/cscope64_2012.12/./bin/aimsh: /usr/lib64/libstdc++.so.6: version `GLIBCXX_3.4.9' not found (required by /home/ZYG/zhaowei/synopsysSoft/cscope64_2012.12/./bin/libai_analogy.so)
/home/ZYG/zhaowei/synopsysSoft/cscope64_2012.12/./bin/aimsh: /lib64/libgcc_s.so.1: version `GCC_4.0.0' not found (required by /home/ZYG/zhaowei/synopsysSoft/cscope64_2012.12/./bin/libai_util.so)
/home/ZYG/zhaowei/synopsysSoft/cscope64_2012.12/./bin/aimsh: /usr/lib64/libstdc++.so.6: version `GLIBCXX_3.4.9' not found (required by /home/ZYG/zhaowei/synopsysSoft/cscope64_2012.12/./bin/libai_util.so)
/home/ZYG/zhaowei/synopsysSoft/cscope64_2012.12/./bin/aimsh: /usr/lib64/libstdc++.so.6: version `GLIBCXX_3.4.11' not found (required by /home/ZYG/zhaowei/synopsysSoft/cscope64_2012.12/./bin/libai_util.so)
/home/ZYG/zhaowei/synopsysSoft/cscope64_2012.12/./bin/aimsh: /usr/lib64/libstdc++.so.6: version `GLIBCXX_3.4.9' not found (required by /home/ZYG/zhaowei/synopsysSoft/cscope64_2012.12/./bin/libai_complex.so)
/home/ZYG/zhaowei/synopsysSoft/cscope64_2012.12/./bin/aimsh: /usr/lib64/libstdc++.so.6: version `GLIBCXX_3.4.9' not found (required by /home/ZYG/zhaowei/synopsysSoft/cscope64_2012.12/./bin/libos_std.so)
我是直接把网上下的tar.gz用tar zxvf命令解压的,没有用installer安装。solvnet里关于coscope的安装明显和其他synopsys软件不一样,感觉很乱。有没有前辈以前装过coscope成功的?请多多指点!
 楼主| 发表于 2014-9-25 13:16:55 | 显示全部楼层
在网上查了点资料。感觉是我偶的redhat系统少了点东西
 楼主| 发表于 2014-9-25 14:07:48 | 显示全部楼层
http://blog.csdn.net/xiaolong2w/article/details/23915171#
参考如上教程,问题解决了很多,但是仍有提示: error while loading shared libraries:libstdc++.so.6:cannot open shared object file:No such file or directory
发表于 2022-12-5 16:37:29 | 显示全部楼层
楼主解决了没啊,我的virtuoso运行得时候也有这个错误
GMT+8, 2025-12-26 04:37 , Processed in 0.019462 second(s), 6 queries , Gzip On, Redis On.
