查看: 2452|回复: 2
[求助] 半整数分频器 求助
发表于 2014-9-17 21:29:53 | 显示全部楼层 |阅读模式
小弟刚入门 对于代码原理不是很懂 尤其是仿真后temp1波形更是觉得匪夷所思 望朋友们能热心帮助
// 代码功能 实现1.5分频
module div_half(div,clk);
output div;
input clk;
reg count=0;
reg div;
reg clk_temp2=0, clk_temp3=0;
assign clk_temp1 = clk^clk_temp2;
always @ (posedge clk_temp1)
begin
if (count == 0)
begin count <=1; clk_temp3<=1; div<=1;end
else
begin count <= count - 1;clk_temp3<=0; div<=0;end
end
always @(posedge clk_temp3)
begin
clk_temp2<=~clk_temp2;
end
endmodule
仿真后输入输出波形 及代码中变量波形:
 楼主| 发表于 2014-9-25 19:23:46 | 显示全部楼层
//任意分频系数为 N+0.5 的占空比为1:1的非整数分频器
module div2(clk, clk_div, cnt1, cnt2, temp1, temp2);
input clk;
output clk_div;
output reg [31:0]cnt1, cnt2;
output reg temp1, temp2;
parameter N=1;
initial begin temp1=0; temp2=1;cnt1=0;cnt2=2*N;end
always @(posedge clk)
begin
if(cnt1==2*N) begin cnt1<=0; end
else begin cnt1<=cnt1+1; end
if(cnt1==0) begin temp1<=1; end
if(cnt1==N+1) begin temp1<=0; end
end
always @(negedge clk)
begin
if(cnt2==0) begin temp2<=0; end
if(cnt2==N) begin temp2<=1; end
if(cnt2==2*N) begin cnt2<=0; end
else begin cnt2<=cnt2+1; end
end
assign clk_div=temp1&&temp2;
endmodule
// Testbench
`timescale 1 ns/ 1 ns
module div2_vlg_tst();
// constants
// general purpose registers
reg eachvec;
// test vector input registers
reg clk;
wire clk_div;
wire [31:0]  cnt1;
wire [31:0]  cnt2;
wire temp1;
wire temp2;
div2 i1 (
.clk(clk),
.clk_div(clk_div),
.cnt1(cnt1),
.cnt2(cnt2),
.temp1(temp1),
.temp2(temp2)
initial
begin
clk=0;
forever #5 clk=~clk;
end
endmodule
发表于 2014-9-26 08:57:59 | 显示全部楼层
问题解决了?既然解决了,给大家报告下最终解决结果以及方法
GMT+8, 2025-12-26 01:12 , Processed in 0.023255 second(s), 9 queries , Gzip On, Redis On.
