楼主: magicdog
[转]几道analog面试题
发表于 2009-2-20 13:58:05 | 显示全部楼层
强烈要求附上答案!
发表于 2009-2-21 09:05:14 | 显示全部楼层
bucuode
发表于 2009-2-23 14:27:31 | 显示全部楼层
唔,有些题我也碰到过,唉后悔没有早看到这个啊
发表于 2009-2-24 09:03:16 | 显示全部楼层
xue xi le
发表于 2009-2-24 13:28:50 | 显示全部楼层
hmm, not bad!
发表于 2009-2-25 16:37:10 | 显示全部楼层
基础
从这几道题就可以看出,不管走到哪里,,基础总是重要的,
发表于 2009-2-26 12:32:49 | 显示全部楼层
看来得好好看拉扎维的书了。。
发表于 2009-2-26 13:06:58 | 显示全部楼层
凡人忍忍按时发送方
发表于 2009-2-26 13:08:04 | 显示全部楼层
灌水无罪吧
咯血啊安抚啊安抚
发表于 2009-2-28 23:06:11 | 显示全部楼层
2. the first stage has larger gain for less noise and offset, and the second stage has larger current for better driving capability, current up->gain down
3. it depends on CL
5. mobiity of hole< that of electron, depletion PMOS is the best, since the channel is much deeper
6. missmatch of input pair, missmatch of the active load and the systematic offset. all the offset can be equivalent to the input offset, of which the systematic offset can be solved by circuit design, and the other two can only be reduced by good layout match
GMT+8, 2025-12-29 21:17 , Processed in 0.018224 second(s), 4 queries , Gzip On, Redis On.
