查看: 32027|回复: 54
linux下安装allegro166与asi166全过程
发表于 2014-8-29 09:56:21 | 显示全部楼层 |阅读模式
1.配置依赖文件
运行yum install libXext.i686 libXtst.i686 libXi.i686 libXrender.i686 xterm.x86_64 ksh.x86_64 tcsh.x86_64 tcl.x86_64 tcl.i686 redhat-lsb.x86_64 redhat-lsb.i686 compat-libstdc++-33.x86_64 compat-libstdc++-33.i686 openmotif.i686 openmotif.x86_64 mesa-libGLU.x86_64 mesa-libGLU.i686 mesa-libGL.x86_64 mesa-libGL.i686 elfutils-libs.x86_64 elfutils-libs.i686 elfutils-libelf.x86_64 elfutils-libelf.i686 libXmu.x86_64 libXmu.i686 libXp.x86_64 libXp.i686
2.安装iscape.04.23-s004。安装spb166hotfix33。安装asi1664.
3.破解软件。
a. 将 pubkey_verify拷贝到SPB166/tools.lnx86。
        ./pubkey_verify
        ./pubkey_verify -y
b.  将 pubkey_verify拷贝到ASI1664/tools.lnx86。
        ./pubkey_verify
        ./pubkey_verify -y
f. 将license.dat 拷贝到 /opt/cadence/SPB166/share/license 中。更改 license.dat 权限到
644。
至此破解完成
4.环境配置:
运行gedit .bashrc
在文件最后加上:
# for cadence
alias lmgrd='/opt/cadence/SPB166/tools/bin/lmgrd -c /opt/cadence/SPB166/share/license/license.dat'
alias lmdown='/opt/cadence/SPB166/tools/bin/lmdown -c /opt/cadence/SPB166/share/license/license.dat'
export CDS_LIC_FILE=27000@localhost.localdomain
export SPB166=/opt/cadence/SPB166
export OA_HOME=/opt/cadence/SPB166/oa_v22.43.006
export CDS_Netlisting_Mode=Analog
export
PATH=$SPB166/tools/binSPB166/tools/pcb/binSPB166/tools/fet/binSPB166/tools/specctra/bin:$PATH
# end cadence
终端运行source .bashrc
运行lmgrd和lmdown开启及关闭license manager
终端输入
cd /etc/rc2.d
gedit S100cdslic
文本中加入
/export/opt/cadence/spb166/tools/bin/lmgrd -C  /export/opt/cadence/spb166/share/license/license.txt -l /tmp/cds.log
存盘
最后感谢tanker大侠提供神一样的pubkey
pubkey_verify_1.10.rar (256.59 KB , 下载次数: 490 ) license.dat.tar.gz (156.54 KB , 下载次数: 432 )
 楼主| 发表于 2014-8-29 10:40:12 | 显示全部楼层
回复 1# 坐对群山青
?怎么传不了附件?
发表于 2014-8-30 11:13:55 | 显示全部楼层
下面是什么问题?
>>allegro
  OrCAD PCB Designer Standard 16.6 S033 Linux I32
(c) Copyright 1986-2012 Cadence Design Systems, Inc.
                All Rights Reserved.
Xlib:  extension "NV-GLX" missing on display "192.168.200.50:0.0".
unit specifier 'MHO' not found in UNITS environment
unit specifier 'W' not found in UNITS environment
'w/cm-degC' and 'W/M-DEGC' are not equivalent units
warning: no preferred units for 'ETCH_THICKNESS'
unit specifier 'MIL' not found in UNITS environment
Termination codes: exit=3, signal=11, errno=2
发表于 2014-8-30 11:21:58 | 显示全部楼层
好的  谢谢
发表于 2014-8-31 03:49:16 | 显示全部楼层
试一下看看。
发表于 2014-8-31 03:50:15 | 显示全部楼层
不错,试试。
发表于 2014-9-2 12:53:21 | 显示全部楼层
试试!
发表于 2014-9-2 12:56:33 | 显示全部楼层
感謝分享~
发表于 2014-9-10 14:32:56 | 显示全部楼层
iscape.04.23-s004能提供个下载吗?谢谢!
发表于 2014-10-15 13:45:44 | 显示全部楼层
运行ASI的时候提示没有有效的license,有人遇到同样的情况么。
楼主能正常运行ASI么,我的系统是Centos6.5 x64。
GMT+8, 2025-12-28 09:47 , Processed in 0.023586 second(s), 6 queries , Gzip On, Redis On.
