查看: 2353|回复: 3
[求助] 有两段锁相的程序实在看不懂,向前辈们请教一下,很着急啊
发表于 2014-8-18 09:48:04 | 显示全部楼层 |阅读模式
一、
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
USE IEEE.STD_LOGIC_ARITH.ALL;
USE IEEE.STD_LOGIC_UNSIGNED.ALL;
ENTITY pwmgen IS
generic
f_len:natural:=9;
delay_len:natural:=9;
dead:natural:=5
port(
rst,clk:in std_logic;
feedin:in std_logic;
        di:in std_logic;
--delay:in std_logic_vector(f_len-1 downto 0);
pwm1,pwm3,pwm2,pwm4ut std_logic
end entity pwmgen ;
architecture bhv of pwmgen is
signal tm,pwm10,pwm20,pwm30,pwm40:std_logic;
signal delay_r:std_logic_vector(delay_len+f_len-1 downto 0);
signal cmp,cmp_dead:std_logic_vector(f_len-1 downto 0);
signal f,fi:std_logic_vector(f_len-1 downto 0);
signal delay:std_logic_vector(f_len-1 downto 0):="011001100";
signal feedcount:std_logic_vector(11 downto 0):="000000000000";
signal close:std_logic:='0';
signal dis: std_logic;
component fcounter
generic
f_len:natural:=9;
f_delta:natural:=10
port(
rst,clk,di:in std_logic;
f,fiut std_logic_vector(f_len-1 downto 0);
tmut  std_logic
end component;
begin
d1:process(clk,close)
    begin
if close='0' then
if clk'event and clk='1' then
    if feedcount<"111111111100" then
        feedcount<=feedcount+'1';
        dis<=di;
--        di1<=dis;
  else
          close<='1';
  dis<=feedin;
  di1<=dis;
        end if;
end if;
        else
  dis<=feedin;
  di1<=dis;
end if;
end process;
fc1:fcounter generic map(9,10) port map(rst,clk,dis,f,fi,tm);
delay_r<=delay*f;
cmp<=delay_r(delay_len+f_len-1 downto delay_len);
cmp_dead<="0"&f(f'length-1 downto 1)-dead;
--adad
d:process(clk,rst)
begin
if rst='0' then
pwm10<='0';
pwm20<='0';
pwm30<='0';
pwm40<='0';
elsif clk'event and clk='1' then
if (fi>=0 and fi<cmp ) then
if tm='1' then pwm10<='1';end if;
if tm='0' then pwm20<='1';end if;
else
pwm10<='0';
pwm20<='0';
end if;
if (fi>dead and fi<cmp_dead) then
if tm='1' then pwm30<='1';end if;
if tm='0' then pwm40<='1';end if;
else
pwm30<='0';
pwm40<='0';
end if;
end if;
end process;
pwm1<=pwm10 and pwm30;
pwm3<=pwm20 and pwm40;
   pwm2<=not dis;
   pwm4<=dis;
end bhv;
二、
LIBRARY IEEE;
entity fcounter is
generic
f_len:natural:=9;  --棰戠巼鏈
 楼主| 发表于 2014-8-18 09:54:44 | 显示全部楼层
LIBRARY IEEE;
entity fcounter is
        generic
 楼主| 发表于 2014-8-18 09:55:49 | 显示全部楼层
LIBRARY IEEE;
二、
entity fcounter is
        generic
                f_len:natural:=9;
                f_delta:natural:=10
        port(
                tmut std_logic
end entity fcounter ;
architecture bhv of fcounter is
        type f_reg_type is array (natural range<>) of std_logic_vector(f_len-1 downto 0);
        signal f_reg:f_reg_type(2+2 downto 0);
        signal fsum:std_logic_vector(f_len-1+2 downto 0);
        signal di_reg:std_logic_vector(3 downto 0);
        signal di_rise,di_fall:std_logic;
        signal cnt:std_logic_vector(f_len-1 downto 0);
begin
        fsum<="00"&f_reg(0)+f_reg(1)+f_reg(2)+f_reg(2);
        f<=fsum(f_len-1+2 downto 2);
        fi<=cnt;
        count:process(clk,rst)
        begin
                if rst='0' then
                        di_reg<=(others=>'0');
                        f_reg<=(others=>(others=>'0'));
                        cnt<=(others=>'0');
                        tm<='0';
                                cnt<=cnt+'1';
                                di_reg<=di_reg(2 downto 0)&di;
                                if di_rise='1' then
                                        f_reg(4)<=cnt;
                                        cnt<=(others=>'0');
                                        tm<='1';
                                end if;
                                if di_fall='1' then
                                        f_reg(3)<=cnt;
                                        cnt<=(others=>'0');
                                        tm<='0';
                                end if;
                                if (f_reg(3)>f_reg(4) and f_reg(3)-f_delta<f_reg(4))
                                        or (f_reg(3)<f_reg(4) and f_reg(3)+f_delta>f_reg(4)) then
                                        f_reg(2 downto 0)<=f_reg(1 downto 0)&(f_reg(3)+f_reg(4));
                                end if;
                end if;
        end process;
        di_rise<= '1' when (di_reg(2)='0' and di_reg(1)='0'and di_reg(0)='1' and di='1') else '0';
        di_fall<= '1' when (di_reg(2)='1' and di_reg(1)='1'and di_reg(0)='0' and di='0') else '0';
end bhv;
 楼主| 发表于 2014-8-18 17:15:04 | 显示全部楼层
为什么仿真时pwm1和pwm3没有输出波形呢?请前辈们指教啊
GMT+8, 2025-12-19 07:29 , Processed in 0.016609 second(s), 5 queries , Gzip On, Redis On.
