楼主: min4max
从Cadence官方网站下载安装Cadence所有软件!
发表于 2015-8-6 00:36:15 | 显示全部楼层
收藏看,
发表于 2015-8-24 17:52:51 | 显示全部楼层
大虾,安装installscape出现这个怎么办?
[root@localhost bin]# sudo ./iscape.sh
Initializing InstallScape using JVM at /opt/cadence/iscape.04.23-s010/runtime/LNX86/bin/java. This might take some time...
./iscape.sh: /opt/cadence/iscape.04.23-s010/runtime/LNX86/bin/java: /lib/ld-linux.so.2: bad ELF interpreter: No such file or directory
Failed with InstallScape JVM.
Now loading System JVM...
./iscape.sh: line 219: java: command not found
Error:
which: no java in (/sbin:/bin:/usr/sbin:/usr/bin)
Could not use JVM packaged with Installcape. The Java in your path did not work or could not find Java in your path.  Ensure that Java 1.6 or later is in your PATH environment variable and restart InstallScape.
发表于 2015-8-24 17:54:18 | 显示全部楼层
大侠,安装installscape时出现这个怎么办?
Error:
 楼主| 发表于 2015-8-24 21:33:55 | 显示全部楼层
发表于 2015-8-26 09:53:17 | 显示全部楼层
大侠,我installscape安装好了,但是下软件的时候会自己停掉:total estimated time elapsed(一次第14分钟,一次第35分钟)和downloading都停掉,这是为啥?
发表于 2015-8-26 14:38:21 | 显示全部楼层
然后我想用windos从官网上下载,结果也得通过installscape,就在windos上装了,结果下了1小时40分钟后,也停掉了
发表于 2015-8-27 17:08:36 | 显示全部楼层
从其他地方找到ic616的base镜像和mmsim13的update镜像了,ic616安好了,但mmsim13不行说我这个不是一个正确的cadence安装文件夹,大侠,咋整
发表于 2015-9-13 23:01:08 | 显示全部楼层
回复 107# daxuepiao19
   给个镜像下载的链接呗 下载几个压缩包版本的不会安装
发表于 2015-9-15 18:22:02 | 显示全部楼层
学习了,非常感谢楼主的分享
发表于 2015-9-16 16:13:38 | 显示全部楼层
感谢楼主,是可以下载。
GMT+8, 2025-12-9 04:16 , Processed in 0.019693 second(s), 4 queries , Gzip On, Redis On.
