楼主: min4max
从Cadence官方网站下载安装Cadence所有软件!
发表于 2015-10-25 01:17:59 | 显示全部楼层
感谢!
发表于 2015-10-28 18:02:29 | 显示全部楼层
楼主太强了!!赞赞赞!
发表于 2015-10-29 20:42:02 | 显示全部楼层
# sh iscape.sh -configure
Initializing InstallScape using JVM at /opt/Cadence/InstallScape/iscape.04.23-s010/runtime/LNX86/bin/java. This might take some time...
java.lang.reflect.InvocationTargetException
        at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
        at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
        at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
        at java.lang.reflect.Method.invoke(Unknown Source)
        at com.khanpur.installer.gui.InstallerUI.main(InstallerUI.java:123)
Caused by: java.lang.IllegalArgumentException:
Illegal commandline argument: -configure
        at com.khanpur.util.Commandline.parse(Commandline.java:195)
        at com.khanpur.installer.gui.InstallerUINoSplash.processCommandLine(InstallerUINoSplash.java:338)
        at com.khanpur.installer.gui.InstallerUINoSplash.main(InstallerUINoSplash.java:372)
        ... 5 more
Failed with InstallScape JVM.
Now loading System JVM...
        at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
        at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
        at java.lang.reflect.Method.invoke(Method.java:606)
        ... 5 more
Error:
/usr/bin/java
Could not use JVM packaged with Installcape. The Java in your path did not work or could not find Java in your path.  Ensure that Java 1.6 or later is in your PATH environment variable and restart InstallScape.
请问大侠这个问题该怎么解决?先感谢了
我系统是 centos6.7 64bit ,安装ic616+hotfix,已经 yum install java-1.7*,
java 的环境变量配置在/etc/profile中,配置为:
export JAVA_HOME=/usr/lib/jvm/java-1.7.0-openjdk-1.7.0.91.x86_64
export CLASSPATH=.JAVA_HOME/jre/lib/rt.jarJAVA_HOME/lib/dt.jarJAVA_HOME/lib/tools.jar
export PATH=$PATH:$JAVA_HOME/bin
安装完后不能启动配置,目前是 configure failed
发表于 2015-10-31 02:29:47 | 显示全部楼层
   Recently Cadence Announces that :
Our records indicate that you are registered at Cadence.com. Cadence appreciates your interest and support. You will continue to have access to Cadence.com and get updates on the latest products and solutions being developed by the Cadence community. Effective Nov. 09, 2015, the access policy for software downloads will be changing. In order to have continued access to downloads, you will need to register for access through the Cadence Online Support portal support.cadence.com Please register
i.e. from 9 oct of 2015 download.cadence.com would not be open to free subscribes.
only users that registered at online support can get access to software downloads.
发表于 2015-11-4 15:08:19 | 显示全部楼层
Our records indicate that you are registered at Cadence. ...
mamdali 发表于 2015-10-31 02:29
    I already met the same question as you.
发表于 2015-11-5 09:36:34 | 显示全部楼层
thanks for sharing
发表于 2015-11-7 10:36:20 | 显示全部楼层
牛人啊,大侠万岁万岁万万岁
发表于 2015-11-12 16:37:44 | 显示全部楼层
THANKS
发表于 2015-11-12 16:38:28 | 显示全部楼层
thanks
发表于 2015-11-12 16:39:53 | 显示全部楼层
thanks
GMT+8, 2025-12-9 05:07 , Processed in 0.019287 second(s), 3 queries , Gzip On, Redis On.
