查看: 15340|回复: 11
[求助] 求助。lvs报错了,如何修改?、、【已解决】
发表于 2014-8-12 14:38:33 | 显示全部楼层 |阅读模式
CELL COMPARISON RESULTS
                    #           #     INCORRECT     #
  Error:    Different numbers of nets (see below).
  Error:    Connectivity errors.
  Warning:  Extra ports in layout.
LAYOUT CELL NAME:         AN2D1BWP12THVT
SOURCE CELL NAME:         AN2D1BWP12THVT
INITIAL NUMBERS OF OBJECTS
                Layout    Source         Component Type
Ports:              7         5    *
Nets:               9         7    *
Instances:          3         3         MN (4 pins)
                     3         3         MP (4 pins)
Total Inst:         6         6
NUMBERS OF OBJECTS AFTER TRANSFORMATION
Ports:              7         5    *
Nets:               8         6    *
Instances:          1         1         _invv (4 pins)
                     1         1         _nand2v (5 pins)
Total Inst:         2         2
       * = Number of objects in layout different from number in source.
                                 INCORRECT OBJECTS
LEGEND:
  ne  = Naming Error (same layout name found in source
        circuit, but object was matched otherwise).
                                   INCORRECT NETS
DISC#  LAYOUT NAME                                               SOURCE NAME
  1    Net 9                                                     ** no similar net **
  2    Net 10                                                    ** no similar net **
                                 INCORRECT INSTANCES
  3    M5(0.620,0.880)  MP(PCH_HVT)                              M_u3-M_u3  MP(PCH_HVT)
         g: 12                                                     g: net6
         s: Z                                                      s: Z
         d: VDD                                                    d: VDD
         b: 10                                                     ** no similar net **
         ** VDD **                                                 b: VDD
  4    M2(0.620,0.180)  MN(NCH_HVT)                              M_u3-M_u2  MN(NCH_HVT)
         g: 12                                                     g: net6
         s: Z                                                      s: Z
         d: VSS                                                    d: VSS
         b: 9                                                      ** no similar net **
         ** VSS **                                                 b: VSS
  5    M1(0.380,0.180)  MN(NCH_HVT)                              M_u2-M_u4  MN(NCH_HVT)
         g: A2                                                     g: A2
         d: 12                                                     ** net6 **
         ** VSS **                                                 d: VSS
         ** VSS **                                                 b: VSS
  6    M0(0.180,0.180)  MN(NCH_HVT)                              M_u2-M_u3  MN(NCH_HVT)
         g: A1                                                     g: A1
         d: VSS                                                    b: VSS
         ** 12 **                                                  d: net6
  7    M4(0.380,1.190)  MP(PCH_HVT)                              M_u2-M_u2  MP(PCH_HVT)
         g: A2                                                     g: A2
         s: 12                                                     s: net6
         d: VDD                                                    d: VDD
         ** VDD **                                                 b: VDD
  8    M3(0.180,1.190)  MP(PCH_HVT)                              M_u2-M_u1  MP(PCH_HVT)
         g: A1                                                     g: A1
         s: 12                                                     s: net6
         d: VDD                                                    d: VDD
         ** VDD **                                                 b: VDD
                               INFORMATION AND WARNINGS
                  Matched    Matched    Unmatched    Unmatched    Component
                   Layout     Source       Layout       Source    Type
   Ports:               5          5            2            0
   Nets:                6          6            2            0
   Instances:           1          1            0            0    _invv
                        1          1            0            0    _nand2v
   Total Inst:          2          2            0            0
o Extra Ports in Layout:
   9 10
o Initial Correspondence Points:
   Ports:        VDD VSS Z A1 A2
                    #           #     INCORRECT     #
LAYOUT CELL NAME:         AN3XD1BWP12THVT
SOURCE CELL NAME:         AN3XD1BWP12THVT
Ports:              8         6    *
Nets:              11         9    *
Instances:          4         4         MN (4 pins)
                     4         4         MP (4 pins)
Total Inst:         8         8
Ports:              8         6    *
Nets:               9         7    *
                     1         1         _nand3v (6 pins)
Total Inst:         2         2
                                 INCORRECT OBJECTS
LEGEND:
                                   INCORRECT NETS
  1    Net 10                                                    ** no similar net **
  2    Net 11                                                    ** no similar net **
                                 INCORRECT INSTANCES
  3    M7(0.760,0.880)  MP(PCH_HVT)                              M_u3-M_u3  MP(PCH_HVT)
         g: 13                                                     g: net7
         s: Z                                                      s: Z
         d: VDD                                                    d: VDD
         b: 11                                                     ** no similar net **
         ** VDD **                                                 b: VDD
  4    M3(0.760,0.180)  MN(NCH_HVT)                              M_u3-M_u2  MN(NCH_HVT)
         g: 13                                                     g: net7
         s: Z                                                      s: Z
         d: VSS                                                    d: VSS
         ** VSS **                                                 b: VSS
  5    M2(0.520,0.180)  MN(NCH_HVT)                              M_u4-M_u6  MN(NCH_HVT)
         g: A3                                                     g: A3
         d: 13                                                     ** net7 **
         ** VSS **                                                 d: VSS
         ** VSS **                                                 b: VSS
  6    M0(0.160,0.180)  MN(NCH_HVT)                              M_u4-M_u4  MN(NCH_HVT)
         g: A1                                                     g: A1
         d: VSS                                                    b: VSS
  7    M1(0.340,0.180)  MN(NCH_HVT)                              M_u4-M_u5  MN(NCH_HVT)
         g: A2                                                     g: A2
         ** 13 **                                                  d: net7
         ** VSS **                                                 b: VSS
  8    M6(0.520,1.070)  MP(PCH_HVT)                              M_u4-M_u3  MP(PCH_HVT)
         g: A3                                                     g: A3
         s: 13                                                     s: net7
         d: VDD                                                    d: VDD
         ** VDD **                                                 b: VDD
  9    M4(0.160,1.070)  MP(PCH_HVT)                              M_u4-M_u1  MP(PCH_HVT)
         g: A1                                                     g: A1
         s: 13                                                     s: net7
         d: VDD                                                    d: VDD
         ** VDD **                                                 b: VDD
10    M5(0.340,1.070)  MP(PCH_HVT)                              M_u4-M_u2  MP(PCH_HVT)
         g: A2                                                     g: A2
         s: 13                                                     s: net7
         d: VDD                                                    d: VDD
         ** VDD **                                                 b: VDD
   Ports:               6          6            2            0
   Nets:                7          7            2            0
                        1          1            0            0    _nand3v
   Total Inst:          2          2            0            0
   10 11
   Ports:        VDD VSS Z A1 A2 A3
                    #           #     INCORRECT     #
LAYOUT CELL NAME:         AO21D1BWP12THVT
SOURCE CELL NAME:         AO21D1BWP12THVT
Ports:              8         6    *
Nets:              11         9    *
                     4         4         MP (4 pins)
Total Inst:         8         8
Ports:              8         6    *
Nets:               9         7    *
Instances:          1         1         MN (4 pins)
                     1         1         SPUP_2_1 (4 pins)
                     1         1         _invv (4 pins)
                     1         1         _smn2v (4 pins)
Total Inst:         4         4
                                 INCORRECT OBJECTS
LEGEND:
                                   INCORRECT NETS
  1    Net VSS                                                   VSS
           10
  2    Net 11                                                    ** missing net **
                                 INCORRECT INSTANCES
  3    M7(0.780,0.880)  MP(PCH_HVT)                              MI8-M_u3  MP(PCH_HVT)
         g: 14                                                     g: net59
         s: Z                                                      s: Z
         d: VDD                                                    d: VDD
         b: 11                                                     ** missing net **
         ** VDD **                                                 b: VDD
  4    M4(0.160,0.880)  MP(PCH_HVT)                              M_u4  MP(PCH_HVT)
         g: A2                                                     g: A2
         ** VDD **                                                 b: VDD
  5    M5(0.340,0.880)  MP(PCH_HVT)                              M_u3  MP(PCH_HVT)
         g: A1                                                     g: A1
         ** VDD **                                                 b: VDD
  6    M6(0.540,0.880)  MP(PCH_HVT)                              M_u2  MP(PCH_HVT)
         g: B                                                      g: B
         ** VDD **                                                 b: VDD
   Ports:               7          6            1            0
   Nets:                8          7            1            0
   Instances:           1          1            0            0    MN(NCH_HVT)
                        1          1            0            0    SPUP_2_1
                        1          1            0            0    _invv
                        1          1            0            0    _smn2v
   Total Inst:          4          4            0            0
   11
   Ports:        VDD VSS Z A2 A1 B
发表于 2014-8-12 14:57:52 | 显示全部楼层
没加tap cell,
tapless的cell 单独做lvs过不了的, well没有正确的偏置
发表于 2014-8-12 14:57:55 | 显示全部楼层
没加tap cell,
 楼主| 发表于 2014-8-12 16:01:25 | 显示全部楼层
我按版主说的找了,tap cell用哪个cell呢?应该是filler cell 吧?
发表于 2014-8-12 17:12:44 | 显示全部楼层
就叫tapcellxxx吧, tsmc 多少nm的库?
 楼主| 发表于 2014-8-12 17:22:17 | 显示全部楼层
那些问题都消除了,现在有一些错,但是不多,erc也过了。
发表于 2014-8-12 17:24:57 | 显示全部楼层
         g: A2                                                     g: A2
         d: 12                                                     ** net6 **
         ** VSS **                                                 d: VSS
         ** VSS **                                                 b: VSS
==>N管衬底没接好。
 楼主| 发表于 2014-8-13 10:53:19 | 显示全部楼层
没加tap cell,
icfbicfb 发表于 2014-8-12 14:57
   怎样设置sroute布线后core里横向的电源线都布线在M3层上呢。。试了很多次都不行,要么没布上要么还是老样子。
发表于 2014-8-13 11:04:24 | 显示全部楼层
sroute -layer不行么,或者把m2 选中,改成m3 行么,不过就是drop via麻烦,
 楼主| 发表于 2014-8-13 17:26:49 | 显示全部楼层
回复 9# icfbicfb
   只有layerChangeRange { toplayernum  bottomlayernum} 不行的
GMT+8, 2025-12-20 16:22 , Processed in 0.027222 second(s), 5 queries , Gzip On, Redis On.
