楼主: Chi_Ho_Wong
[求助] Help in CMOS Schmitt Trigger Design (Resend)
 楼主| 发表于 2014-7-31 12:50:47 | 显示全部楼层
Thanks everyone, I shall try and share experiancewith others.
 楼主| 发表于 2014-8-1 22:09:05 | 显示全部楼层
回复 5# Chi_Ho_Wong
However, i have tried that (Reducing sine wave frequency), the results are still unchanged.
 楼主| 发表于 2014-8-1 22:13:43 | 显示全部楼层
回复 10# bitcat
    Sorry, i do not understand "The comparator is not fast enough". Would you pls explain more in details?  Thanks.
发表于 2014-8-4 18:23:37 | 显示全部楼层
明显不是delay造成的,dc扫描显示触发点在2.76,已经大于你的设计值,因此和触发器的速度无关。计算值和仿真值有一定误差,主要是由于沟道长度调制效应造成的,需要手动修正。比较器触发点是dc参数,扫tran不妥,Allen的书里有介绍,不妨看下。
 楼主| 发表于 2014-8-4 20:11:55 | 显示全部楼层
回复 14# hszgl
If i receive a cmos process spice file (From specific foundry), what can i do further to ensure that the file received by me is correct? What parameters are useful from the received cmos process spice file? Thanks.
发表于 2014-8-4 23:18:37 | 显示全部楼层
回复 15# Chi_Ho_Wong
    说来从foundry得到的lib文档是最具参考价值的数据了。就以lib为参考标准吧。你用的计算公式是一阶模型,spice模型一般是49阶,比一阶模型要精确的多。如果对foundry提供的lib有疑虑,可以有hspice和spectre对比仿真,因为有不少foundry的spectre模型是从hspice模型拟合过来的。
还有就是自己建模了,但是出于成本(建模设备非常昂贵)考虑,实在是不现实,不如换一家靠谱的foundry,或者找第三方建模公司帮忙。
发表于 2021-11-3 16:25:34 | 显示全部楼层
你的公式錯了 你沒有把un up的因素考量進去
兩者差三倍
GMT+8, 2025-12-25 14:47 , Processed in 0.015552 second(s), 3 queries , Gzip On, Redis On.
