查看: 3005|回复: 0
[求助] vivado 综合参数修改问题咨询
发表于 2014-7-19 07:36:48 | 显示全部楼层 |阅读模式
使用vivado综合时,报 Warning:[Synth 37-21] Bus register expansion bit limt(2000000) exceeded(found XXXX bus register bits). Bus register expansion disabled, which may impact constranit object selection. You may adjust the parameter synth.elab.expandBusRegLimit to a higher value at a cost of memory used in elaboration to re-enable expansion.
请问在vivado环境中具体怎么操作?
GMT+8, 2025-12-23 21:25 , Processed in 0.042087 second(s), 5 queries , Gzip On, Redis On.
