查看: 5983|回复: 1
[求助] 新手 求助FPGA烧写相关
发表于 2014-7-16 11:15:17 | 显示全部楼层 |阅读模式
小弟最近在做FPGA相关的,用的XILINX Spartan-6,用到microblaze软核相关,用的串行FLASH,用impact烧写flash没有任何问题,但是用DEK时候就没法烧写,求大神出手相助!!
**** Build of configuration Debug for project mn_openMac ****
make prog_flash
Invoking: Xilinx iMPACT
impact -batch E:\powerlink\EPL_XILINX\02_Reference_Sources\tools\xilinx/scripts/program_prom_lx16.cmd
Release 13.2 - iMPACT O.61xd (nt)
Copyright (c) 1995-2011 Xilinx, Inc.  All rights reserved.
Preference Table
Name                 Setting
StartupClock         Auto_Correction
AutoSignature        False
KeepSVF              False
ConcurrentMode       False
UseHighz             False
ConfigOnFailure      Stop
UserLevel            Novice
MessageLevel         Detailed
svfUseTime           false
SpiByteSwap          Auto_Correction
AutoInfer            false
SvfPlayDisplayComments false
INFO:iMPACT - Digilent Plugin: no JTAG device was found.
AutoDetecting cable. Please wait.
Connecting to cable (Usb Port - USB21).
Checking cable driver.
Driver file xusb_xlp.sys found.
Driver version: src=1029, dest=1029.
Driver windrvr6.sys version = 10.2.1.0. WinDriver v10.21 Jungo (c) 1997 - 2010 Build Date: Aug 31 2010 X86 32bit SYS
14:35:41, version = 1021.
Cable PID = 0008.
Max current requested during enumeration is 74 mA.
Type = 0x0004.
Cable Type = 3, Revision = 0.
Setting cable speed to 6 MHz.
Cable connection established.
Firmware version = 1303.
File version of D:/XILINX/ISE_DS/ISE/data/xusb_xlp.hex = 1303.
Firmware hex file version = 1303.
PLD file version = 0012h.
PLD version = 0012h.
Type = 0x0004.
ESN device is not available for this cable.
Identifying chain contents...'0': : Manufacturer's ID = Xilinx xc6slx16, Version : 4
INFO:iMPACT:1777 -
   Reading D:/XILINX/ISE_DS/ISE/spartan6/data/xc6slx16.bsd...
INFO:iMPACT:501 - '1': Added Device xc6slx16 successfully.
done.
Elapsed time =      0 sec.
Unprotect sectors: FALSE
Maximum TCK operating frequency for this device chain: 25000000.
Validating chain...
Boundary-scan chain validated successfully.
'1': SPI access core not detected. SPI access core will be downloaded to the
INFO:iMPACT - Downloading core file
device to enable operations.
   D:/XILINX/ISE_DS/ISE/spartan6/data/xc6slx16_spi.cor.
'1': Downloading core...
LCK_cycle = NoWait.
LCK cycle: NoWait
done.
'1': Reading status register contents...
INFO:iMPACT:2219 - Status register values:
INFO:iMPACT - 0011 1100 1110 1100
INFO:iMPACT:2492 - '1': Completed downloading core to device.
'1': IDCODE is '202017' (in hex).
'1': ID Check failed.
INFO:iMPACT:2488 - The operation did not complete successfully.
Elapsed time =      2 sec.
INFO:iMPACT - SPI Device not found.
INFO:iMPACT - '1': Flash was not programmed successfully.
make: *** [prog_flash] 错误 1
发表于 2016-9-1 09:13:22 | 显示全部楼层
你的xilinx下载器接反了,我也遇到过同样的问题
GMT+8, 2025-12-18 21:47 , Processed in 0.287183 second(s), 6 queries , Gzip On, Redis On.
