查看: 2032|回复: 0
[招聘] NO.273-Field Quality Engineer, Asia(Shenzhen)
发表于 2014-7-15 16:29:01 | 显示全部楼层 |阅读模式
Primary Function:
Carries out Quality functions for AET customers of finished parts, contract manufacturing as well as converters in Asia.
Description of Responsibilities:
• Under guidance of AET QA director:
• Supports sales of finished parts at End Use Customer’s:
o Helps turn customer’s explicit specification and implicit expectations into inspection specifications.
o Addresses customer’s complaints and dissatisfaction in a timely manner, including at the customer’s site as required.
o Runs investigations using specific problem solving methodology and manages communication to customers on these investigation and corrective action plans.
• Is responsible for verifying final inspection results of finished parts at our Contract manufacturers (CM):
o Helps ensure Customer specifications have been consistently implemented and updated in CM documentation system
o Audits CM final inspection procedures and results
o Provides our verification of CM inspection results for prototype, pre-production and production stages.
o Monitor’s CM’s Outgoing Quality control records, analyzes yields, identifies improvement opportunities.
o Drives Customers’ complaint investigation at the CM’s.
• Supports sales of semi-finished products  at converters
o Helps identify true end customer’s needs as well as converter’s needs and develop specifications.
o Helps optimize specifications for semi-finished products so as to optimize the whole supply chain.
o Addresses converter’s complaints and runs investigations using specific problem solving methodology.
Works in close relationship with: Integrated Solution process engineers, Lakewood (USA) plant Quality manager/engineers, Regional Sales Managers and Application Engineers.
Competencies:
• Customer focus
• Problem Solving
• Sense of urgency/priorities/ Responsiveness
• Attention to details
• Functional/Technical Skills
• Flexibility
• Integrity and trust
Knowledge / Skills / Experience:
5 years Engineering degree (mechanical degree)
Mandarin as mother language. Fluent English (written, spoken) is a must. Korean is a plus.
Good background in Quality system (ISO9000), Experience in Lean 6Sigma is a plus.
Masters Quality tools as problem solving, standard work, and statistical analysis.
Ability to use Solid works is a plus.
Working Conditions:
Significant travel. 75+% of time. Mainly in China. May include travelling to the USA, Korea and other countries in Asia.
Office and manufacturing (die cutting, lamination,..) environment at our customers/CM.
KT Human Resources Consulting Company (Shanghai) was established in 2001 in response to a need for a recruitment consultancy to be an active, contributing member of the semiconductor community, as opposed to simply a supplier to it.We provide professional search and talent acquisition in the Integrated Circuit、Electronic、Telecommunications industry of international corporations in Greater China. Our client list contains numerous international companies, many of them are long-term customers.
If you interested in the job, pls sent your cv to: hr@kthr.com, thanks!
“KT人才”微信也可查询职位啦!打开手机微信,搜号码“KTHR_COM”或查找微信公众帐号“KT人才”即可添加,欢迎大家关注!(关注成功后输入”KT“即可查询职位!)
GMT+8, 2025-12-21 21:15 , Processed in 0.013105 second(s), 5 queries , Gzip On, Redis On.
