查看: 2832|回复: 7
[原创] Altium Designer v14.2.4.31871 + Library
发表于 2014-7-8 23:58:37 | 显示全部楼层 |阅读模式
The industry’s only unified electronic design software gives you an unmatched ability to design and build the next generation of electronic products.
Altium Designer is an EDA software package for printed circuit board, FPGA and embedded software design, and associated library and release management automation. It is developed and marketed by Altium Limited of Australia.
Schematic capture:
Schematic capture module provides electronics circuit editing functionality, including:
- Component library management
- Schematic document editing (component placement, connectivity editing and design rules definition)
- Integration with several component distributors allows search for components and access to manufacturer's data
- SPICE mixed-signal circuit simulation
- Pre-layout signal integrity analysis
- Netlist export.
- Reporting and BoM facilities.
- Multi-channel, hierarchical schematics and design re-use
PCB design:
Printed circuit board design module of Altium designer allows:
- Component footprint library management
- Component placement
- Manual trace routing, with support for differential pairs, multi-trace routing, pin-swapping and gate-swaping
- Automatic trace routing
- Automated multi-channel layout and routing
- Interactive 3D editing of the board and MCAD export to STEP
- Signal integrity analysis
- Manufacturing files generation with support for Gerber and ODB++ formats
Part1.zip
250 Bytes, 下载次数: 34 , 下载积分: 资产 -2 信元, 下载支出 2 信元
Part2.zip
249 Bytes, 下载次数: 25 , 下载积分: 资产 -2 信元, 下载支出 2 信元
Part3.zip
Part4.zip
249 Bytes, 下载次数: 26 , 下载积分: 资产 -2 信元, 下载支出 2 信元
Part5.zip
250 Bytes, 下载次数: 26 , 下载积分: 资产 -2 信元, 下载支出 2 信元
Part6.zip
250 Bytes, 下载次数: 24 , 下载积分: 资产 -2 信元, 下载支出 2 信元
Part7.zip
249 Bytes, 下载次数: 28 , 下载积分: 资产 -2 信元, 下载支出 2 信元
lib1.zip
lib2.zip
248 Bytes, 下载次数: 27 , 下载积分: 资产 -2 信元, 下载支出 2 信元
lib3.zip
lib4.zip
lib5.zip
249 Bytes, 下载次数: 27 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2014-7-9 13:58:41 | 显示全部楼层
好东东,下载下来用用
 楼主| 发表于 2014-7-9 21:57:14 | 显示全部楼层
Password: www.p30download.com
发表于 2014-7-26 15:07:37 | 显示全部楼层
taiguile
发表于 2014-8-16 21:32:56 | 显示全部楼层
真会赚积分。。。。
发表于 2014-9-1 17:11:15 | 显示全部楼层
楼主,就点TXT文档也值得一发啊。
发表于 2015-3-26 18:47:21 | 显示全部楼层
www.p30download.com?
发表于 2015-6-3 20:51:49 | 显示全部楼层
merci pour le partage
GMT+8, 2025-10-21 17:28 , Processed in 0.027166 second(s), 4 queries , Gzip On, Redis On.
