楼主: 673429464
[资料] cadence ic 5141 安装过程全记录,适合于linux零基础者
发表于 2017-9-9 08:11:25 | 显示全部楼层
thanks
发表于 2017-9-9 12:35:12 | 显示全部楼层
收了,谢谢
发表于 2017-9-20 12:49:17 | 显示全部楼层
谢楼主,学习一下
发表于 2017-11-6 10:17:39 | 显示全部楼层
谢谢楼主的分享
发表于 2019-1-7 21:24:02 | 显示全部楼层
求问楼主,安装到 cd /tmp/ic5141/CDROM1
./SETUP.SH
的时候,屏幕出现一堆错误:
Specify path of install directory \c
[OR type [RETURN] to exit]: \c
/cadence
Setting up softload for lnx86 in /cadence
\c
The following tar errors were detected:
\c
/bin/tar: ./install/bin.lnx86/columnize: Cannot open: File exists
/bin/tar: ./install/bin.lnx86/io_fltr.c: Cannot open: File exists
/bin/tar: ./install/bin.lnx86/process_file.c: Cannot open: File exists
/bin/tar: ./install/bin.lnx86/cdsudp.c: Cannot open: File exists
/bin/tar: ./install/bin.lnx86/genControl.c: Cannot open: File exists
/bin/tar: ./install/bin.lnx86/io_fltr: Cannot open: File exists
/bin/tar: ./install/bin.lnx86/tart: Cannot open: File exists
/bin/tar: ./install/bin.lnx86/process_file: Cannot open: File exists
/bin/tar: ./install/bin.lnx86/genControl: Cannot open: File exists
/bin/tar: ./install/bin.lnx86/cdsudp: Cannot open: File exists
/bin/tar: ./install/bin.lnx86/bundle_fltr: Cannot open: File exists
/bin/tar: ./install/bin.lnx86/softload: Cannot open: File exists
/bin/tar: ./install/bin.lnx86/softload_GUI: Cannot open: File exists
/bin/tar: ./install/bin.lnx86/cdsLoad: Cannot open: File exists
/bin/tar: ./install/bin.lnx86/check_tape: Cannot open: File exists
/bin/tar: ./install/bin.lnx86/check_load: Cannot open: File exists
/bin/tar: ./install/bin.lnx86/check_pdtok: Cannot open: File exists
/bin/tar: ./install/bin.lnx86/chk_attr: Cannot open: File exists
/bin/tar: ./install/bin.lnx86/read_media: Cannot open: File exists
/bin/tar: ./install/bin.lnx86/status_fltr: Cannot open: File exists
/bin/tar: ./install/bin.lnx86/vld: Cannot open: File exists
/bin/tar: ./install/bin.lnx86/menu_install: Cannot open: File exists
/bin/tar: ./install/bin.lnx86/inv_pdts: Cannot open: File exists
/bin/tar: ./install/bin.lnx86/load_fltr: Cannot open: File exists
/bin/tar: ./install/bin.lnx86/make_pdtnok: Cannot open: File exists
/bin/tar: ./install/bin.lnx86/menu_dat: Cannot open: File exists
/bin/tar: ./install/bin.lnx86/overwrite: Cannot open: File exists
/bin/tar: ./install/bin.lnx86/sconf_fltr: Cannot open: File exists
/bin/tar: ./install/bin.lnx86/verify_pkgs: Cannot open: File exists
/bin/tar: ./install/bin.lnx86/delete_fltr: Cannot open: File exists
/bin/tar: ./install/bin.lnx86/disk_tbl: Cannot open: File exists
/bin/tar: ./install/bin.lnx86/media_iface: Cannot open: File exists
/bin/tar: ./install/bin.lnx86/update_pdtok: Cannot open: File exists
/bin/tar: ./install/bin.lnx86/conf_sys: Cannot open: File exists
/bin/tar: ./install/bin.lnx86/waitMsgf: Cannot open: File exists
/bin/tar: ./install/bin.lnx86/pdtMappkg: Cannot open: File exists
/bin/tar: ./install/bin.lnx86/read_label: Cannot open: File exists
/bin/tar: ./install/bin.lnx86/getEmailMedia: Cannot open: File exists
/bin/tar: ./install/bin.lnx86/inv_pkgs: Cannot open: File exists
/bin/tar: ./install/bin.lnx86/inv_tapes: Cannot open: File exists
/bin/tar: ./install/bin.lnx86/pkg_fltr: Cannot open: File exists
/bin/tar: ./install/bin.lnx86/choice_fltr: Cannot open: File exists
/bin/tar: ./install/bin.lnx86/disk_chk: Cannot open: File exists
/bin/tar: ./install/bin.lnx86/email_choice: Cannot open: File exists
/bin/tar: ./install/bin.lnx86/load_pkgs: Cannot open: File exists
/bin/tar: ./install/bin.lnx86/media_cntrl: Cannot open: File exists
/bin/tar: ./install/bin.lnx86/conf_user: Cannot open: File exists
/bin/tar: ./install/bin.lnx86/delete_fls: Cannot open: File exists
/bin/tar: ./install/bin.lnx86/delete_pkgs: Cannot open: File exists
/bin/tar: ./install/bin.lnx86/duptape: Cannot open: File exists
/bin/tar: ./install/bin.lnx86/menu_media: Cannot open: File exists
/bin/tar: ./install/bin.lnx86/update_pkgok: Cannot open: File exists
/bin/tar: ./install/bin.lnx86/getInstMedia: Cannot open: File exists
/bin/tar: ./install/bin.lnx86/freeDisk: Cannot open: File exists
/bin/tar: ./install/bin.lnx86/menu_emailMedia: Cannot open: File exists
/bin/tar: ./install/bin.lnx86/vtar: Cannot open: File exists
/bin/tar: ./install/bin.lnx86/tapeinfo: Cannot open: File exists
/bin/tar: ./install/bin.lnx86/test_inst: Cannot open: File exists
/bin/tar: ./install/bin.lnx86/tstinst_fltr: Cannot open: File exists
/bin/tar: ./install/bin.lnx86/uconf_fltr: Cannot open: File exists
/bin/tar: ./install/bin.lnx86/vload: Cannot open: File exists
/bin/tar: ./install/bin.lnx86: Cannot utime: Operation not permitted
/bin/tar: ./install/pkgs: Cannot utime: Operation not permitted
/bin/tar: ./install/pkgs: Cannot change mode to rwxr-xr-x: Operation not permitted
/bin/tar: ./install/pdts: Cannot utime: Operation not permitted
/bin/tar: ./install/pdts: Cannot change mode to rwxr-xr-x: Operation not permitted
/bin/tar: ./install/tmp: Cannot utime: Operation not permitted
/bin/tar: ./install: Cannot utime: Operation not permitted
/bin/tar: Error exit delayed from previous errors
/bin/tar: ./install/tmp/allbundles.lnx86: Cannot open: File exists
/bin/tar: ./install/tmp/allmapinfo.lnx86: Cannot open: File exists
/bin/tar: ./install/tmp/allmediaMap.lnx86: Cannot open: File exists
/bin/tar: ./install/tmp/allpkginfo.lnx86: Cannot open: File exists
/bin/tar: ./install/tmp/allsoftloadVersion.lnx86: Cannot open: File exists
/bin/tar: ./install/tmp/allsourceMedia.lnx86: Cannot open: File exists
/bin/tar: ./install/tmp/platforms: Cannot open: File exists
Could not set up SoftLoad in /cadence\c
You must have write permissions to install directory \c
and all its subdirectories
and atleast 10 MB available disk \c
space in install directory.
\c
求问楼主和各路大神我该怎么办呀,真的特别着急用cadence,万分感激大家帮忙了
发表于 2019-1-12 11:12:55 | 显示全部楼层
楼主大大求救,在修改license.dat文件那部分我的license.dat文件显示是new file,里边什么都没有,可是在cadence安装的iso文件上是有一个叫做cadence_license_full.dat的文件的,现在没有改就继续安装了,结果用icfb&命令打不开,显示报错:
[cds@localhost ~]$ icfb&
[1] 22029
[cds@localhost ~]$ Xlib: connection to ":0.0" refused by server
Xlib: No protocol specified
*ERROR* X Window Display Initialization failure
*WARNING* X Window Display Initialization failure
[1]+  Exit 255                icfb
我觉得是不是就是因为license那个没弄好,现在没有权限呀,求大神们救救我。。。。好着急啊
发表于 2019-12-9 16:13:43 | 显示全部楼层
多谢多谢
发表于 2020-3-4 12:47:35 | 显示全部楼层
一边赚一边花
GMT+8, 2025-12-30 11:09 , Processed in 0.016873 second(s), 5 queries , Gzip On, Redis On.
