楼主: wjx197733
[求助] 设计一个高压开关,请各位推荐合适的工艺
 楼主| 发表于 2014-6-30 17:07:58 | 显示全部楼层
回复 10# peterlin2010
您说的“vanguard”是哪个工艺厂?有联系方式吗?
正如你所说,source- buck 之间的低电压是一个让人很郁闷的事情。我们这次流片失败,就是由于源体之间的耐压不够。
CSMC和ASMC都看过了,找不到合适的工艺。主要是栅源之间的耐压、源体之间的耐压都不够30V!!!
发表于 2014-6-30 17:20:47 | 显示全部楼层
回复 11# wjx197733
    Vanguard International Semiconductor Corporation
世界先進積體電路股份有限公司
发表于 2014-6-30 17:26:37 | 显示全部楼层
回复 11# wjx197733
世界先進積體電路股份有限公司
发表于 2015-6-6 10:43:01 | 显示全部楼层
Korea Dongbu
发表于 2015-6-6 10:49:14 | 显示全部楼层
Dongbu is 0.35um 60v BCD process ..
LDMOS  gate  source is Low voltage ..
and need high-side Nmos ,  source-bulk have high breakdown .
VIS (vanguard )have 40v mos
vgs = 40v
vds=40v
use "sym_nmos  "
asy_nmos  source to Bulk还是低压
by the way , how can provide some paper about analog switch ?
usb have high speed switch
        Digitally controlled high-voltage analog switch array for medical ultrasound applications in thin-layer silicon-on-insulator process
        Integrated analog switch matrix with large input signal and 46 dB isolation at 1 GHz        Low-resistance wide-voltage-range analog switch for implantable neural stimulators
                                                A one-way MOS analog switch
                                                        Wu Ge;                                                         Shi Yin
                                        Solid-State and Integrated Circuit Technology, 1998. Proceedings. 1998 5th International Conference on
        Bootstrapped low-voltage analog switches
                                                        Steensgaard, J.
                                        Circuits and Systems, 1999. ISCAS '99. Proceedings of the 1999 IEEE International Symposium on
An analysis of the performance of a new high-speed single-way analog switch
High-voltage current-controlled analog switches for various kinds of application
                                                        Jankowski, M.
Design of Novel 300-V Field-MOS FETs With Low on-Resistance for Analog Switch Circuits
        Design and characterization of low-voltage analog switch without the need for clock boosting
find low voltage design paper
Low-Voltage Analog Switch in Deep Submicron.1996.pdf (1.24 MB , 下载次数: 49 )
发表于 2017-5-8 18:42:06 | 显示全部楼层
wanguard 有高压工艺,simc  今年刚出了高压工艺
发表于 2017-7-1 15:33:18 | 显示全部楼层
GMT+8, 2025-12-29 02:47 , Processed in 0.018299 second(s), 5 queries , Gzip On, Redis On.
