查看: 2116|回复: 1
[求助] 求助大神们cadence RTL compiler的问题!
发表于 2014-6-28 10:39:32 | 显示全部楼层 |阅读模式
最近用RTL compiler综合电路的时候,发现用read_hdl命令读取源程序总是默认为verilog程序,如何设置才认为是vhd文件呢?
发表于 2014-7-4 20:14:34 | 显示全部楼层
command:   set_attribute hdl_language {v1995 | v2001| vhdl |sv}
hdl_language
hdl_language {v1995 | v2001 |vhdl |sv}
Default: v1995
Read-write root attribute. Specifies the default hdl language mode assumed when you run the read_hdl command without specifying the language mode.
Note:  This attribute is supported only in the RTL flow.
GMT+8, 2025-12-28 18:54 , Processed in 0.017002 second(s), 8 queries , Gzip On, Redis On.
