查看: 1890|回复: 2
[招聘] 猎头急招 Principal/Lead Physical Design Engineer,上海
发表于 2014-6-27 22:15:00 | 显示全部楼层 |阅读模式
请发简历到 24402505@qq.com , 求推荐。可QQ交流。
美国公司职位,薪水诱人哦。
SOC-RIP Physical Design Team
Position: Principal/Lead Physical Design Engineer
Position Description:    Perform physical design implementation, including synthesis, floor planning, power grid design, place and route, clock tree synthesis, timing closure, power/signal integrity signoff, physical verification (DRC/LVS/Antenna), EM/IR signoff, DFM Closure, and physical design project management.
The candidate will have the opportunity to work on many varieties of challenging designs, i.e. low power and high speed design. The responsibility includes participating in or leading next generation physical design, methodology and flow development.
Position Requirements:    BS degree with 5~10+ years of applicable experience, MS degree with 3~7+ years of applicable experience in electrical engineering, microelectronics. Experienced with ASIC design flow, hierarchical physical design strategies, and methodologies and understand deep sub-micron technology issues. Solid knowledge on LP Design, DFT, static timing analysis, EM/IR-Drop/crosstalk analysis, formal verification, physical verification, DFM. Successful track records of taping out complex, 65/40/28 nm SOC chips. Automation and programming-minded, solid coding experience in Makefile/Tcl/Tk/Perl. Self-motivated, able to work independently or as a team player, excellent verbal and written communication skills in English.
 楼主| 发表于 2014-7-22 16:10:42 | 显示全部楼层
该职位依然有效,请打击持续关注。
 楼主| 发表于 2014-7-22 16:23:02 | 显示全部楼层
职位要求 高速数字产品 physical design 经验,依然急需 physical  design 工程师。
GMT+8, 2025-11-24 22:58 , Processed in 4.001013 second(s), 5 queries , Gzip On, Redis On.
