查看: 2386|回复: 3
[求助] 求IEEE文章
发表于 2014-6-20 14:08:39 | 显示全部楼层 |阅读模式
A 1.4V, 13.5mW, 10/100MHz 6th order elliptic filter/VGA with DC-offset correction in 90nm CMOS
M. Elmala, B. Carlton, R. Bishop, K. Soumyanath
Intel Res. & Dev., Intel Corp., Hillsboro, OR, USA
In proceeding of: Radio Frequency integrated Circuits (RFIC) Symposium, 2005. Digest of Papers. 2005 IEEESource: IEEE Xplore
ABSTRACT This paper presents a complete base-band chain for WLAN applications in 1.4 V 90 nm CMOS. The chain consists of a 6th order elliptic Gm-C 10/100 MHz filter and five VGA stages. The design is DC-offset free and uses optimized transconductance for linearity and low-voltage operation. Moreover, the integrators in the filter are compensated for losses through a frequency transformation. The IIP3 is 2 dBm at 13.5 dB minimum gain, while dissipating 13.5 mW.
非常感谢
发表于 2014-6-20 14:45:33 | 显示全部楼层
回复 1# scy8080
01489627.pdf (608.03 KB , 下载次数: 18 )
发表于 2014-6-20 21:10:33 | 显示全部楼层
Take a look !!
Thanks !!
 楼主| 发表于 2014-6-23 09:47:50 | 显示全部楼层
非常感谢populbb
GMT+8, 2025-12-26 18:06 , Processed in 0.023881 second(s), 8 queries , Gzip On, Redis On.
