查看: 2665|回复: 0
[求助] verilog 程序写好以后,硬件不布线
发表于 2014-6-19 17:56:39 | 显示全部楼层 |阅读模式
写了一个DDS的程序,用bdf文件是可以实现的。如下图:
但是写成verilog文件以后(DDS_BLOCK.v),编译发现文件编译后,RTL图,逻辑都是对的,但是就是不在CPLD上面布线。用到的逻辑单元也只有6个。实在是疑惑不解。
module DDS_BLOCK
DATABUS,
ADDR,
WRITE,
READ,
CLK,
DDS_SINE,
PD_SINE
inout [7:0]DATABUS;
input [7:0]ADDR;
input WRITE,READ;
input CLK;
output [7:0] DDS_SINE;
output [2:0] PD_SINE;
wire CLK_DIV_N;
wire [8:0] ADDRBUS;
parameter addr_N_H=8'h0b;
parameter addr_N_L=8'h0c;
parameter addr_M=8'h0d;
parameter addr_PHASE=8'h0e;
reg [7:0] reg_N_H,reg_N_L,reg_M,reg_PHASE;
always @ (ADDR)
begin
        case(ADDR)
        addr_N_H:        reg_N_H=DATABUS;
        addr_N_L:        reg_N_L=DATABUS;
        addr_M:                reg_M=DATABUS;
        addr_PHASE:        reg_PHASE=DATABUS;
        default:;
        endcase
end
CLK_DIV CLK_DIV_entity
.CLK(CLK),
.N(16),
.CLK_div_N(CLK_DIV_N)
ADDR_COUNT ADDR_COUNT_entity
.CLK(CLK_DIV_N),
.M(M),
.EN(reg_PHASE[7]),
.ADDR(ADDRBUS)
DDS_512 DDS_512_entity
.ADDR_i(ADDRBUS),
.DATA_o(DDS_SINE)
DDS_8 DDS_8_entity
.ADDR_i(ADDRBUS),
.PHASE_i(reg_PHASE[1:0]),
.DATA_o(PD_SINE)
endmodule
GMT+8, 2025-12-14 13:15 , Processed in 0.014417 second(s), 7 queries , Gzip On, Redis On.
