楼主: Leslie-T
Cadence SPB16.60 + Hotfix 30 Linux
发表于 2014-6-26 02:46:37 | 显示全部楼层
I tried to open allegro, but I always get error message
allegro.exe: error while loading shared libraries: libGL.so.1: cannot open shared object file:
no such file or directory.
please, give me an install instruction ....
 楼主| 发表于 2014-6-26 04:08:29 | 显示全部楼层
It works for me in Ubuntu 12.04 64bit with nVidia video card.
Your problem is caused by Mesa's /usr/lib32/libGL.so.1 being earlier in the LD_LIBRARY_PATH than the proprietary video driver. A workaround for this bug:
  LD_LIBRARY_PATH=/usr/lib32/nvidia-current allegro
  (nvidia-current directory may vary depending your version)
However, I recommend to create a valid environment file. I attached mine as an example.
Some more tips:
  I installed in /opt/cadence/SPB166
  Put environment as /opt/cadence/SPB166/cadence.env
  Install ia32-libs and libmotif4:i386 packages in Ubuntu
  After the correct environment settings, use the following commands to run:
    . /opt/cadence/SPB166/cadence.env
    /opt/cadence/SPB166/tools.lnx86/pcb/bin/allegro
Hope this helps.
allegro_env.tar.gz
976 Bytes, 下载次数: 88 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2014-6-27 01:14:16 | 显示全部楼层
Thank Leslie,
I use Ubuntu 14.04 x64 bit. I search and try to install ia32-libs, finally, that problem is gone. However, I'm facing with another problem is:
Unable to resolve function glXQueryExtension
Unable to resolve function glXMakeCurrent
unit specifier 'MHO' not found in UNITS environment
unit specifier 'W' not found in UNITS environment
'w/cm-degC' and 'W/M-DEGC' are not equivalent units
or lic_Error ....
please teach me how to solve this problem ...share patch & license
million thanks
发表于 2014-6-27 01:22:50 | 显示全部楼层
回复 12# Leslie-T
I'm using Ubuntu 14.04 x64, followed your instruction, I installed "ia32-libs" that problem is gone.
but I'm facing with another ###----------------------------------------
'w/cm-degC'and 'W/M-DEGC' are not equivalent units
please teach me how to solve this problem. when I select OrCAD or ...
I got lic_Error ... which batch and license do you use in this case ...
million thanks
发表于 2014-6-27 06:26:22 | 显示全部楼层
is there any crack or license for this
 楼主| 发表于 2014-6-27 16:00:00 | 显示全部楼层
You still have OpenGL graphics support problem. There are many google hits regarding this problem:
  This issue can be fixed by doing the following for nVidia cards,
    sudo ln -s /usr/lib/nvidia-current/libGL.so.1 /usr/lib/libGL.so.1
  or for AMD cards,
    sudo ln -s /usr/lib/fglrx/libGL.so.1 /usr/lib/libGL.so.1
 楼主| 发表于 2014-6-28 02:02:53 | 显示全部楼层
theshadowx 发表于 2014-6-27 06:26
You can use usual pubkey method to replace ecc keys.
This is a working version:
  "Generic ECC patcher by tanker, v1.10, 2013-06-30"
I have only the windows binary, but it runs under wine:
  wine ./pubkey -y
pubkey110.zip
63.97 KB, 下载次数: 98 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2014-6-28 05:45:27 | 显示全部楼层
Hi Leslie-T,
   a CPU in my system is AMD A10 6800k, the driver installed in my system is HD8670D, I followed your instruction: " sudo ln -s /usr/lib/fglrx/libGL.so.1 /usr/lib/libGL.so.1" but it is not help. pls give me a glue
Thx
发表于 2014-6-29 16:29:00 | 显示全部楼层
很新,第一次看到
发表于 2014-7-10 23:57:34 | 显示全部楼层
不错!!!!!!!!!!
GMT+8, 2025-9-18 12:23 , Processed in 0.019686 second(s), 6 queries , Gzip On, Redis On.
