查看: 3274|回复: 0
[讨论] zynq 关于Board Support Package OS选项下无device-tree
发表于 2014-6-10 15:17:25 | 显示全部楼层 |阅读模式
按照http://www.wiki.xilinx.com/Build+Device+Tree+Blob,将Device Tree Generator加载到windows中,可以遇到在Board Support Package OS选项下无device-tree,感到很纳闷,研究了半天终于对WIKI的这句英文深入的理解:
4.Note: In order for SDK to be able to import the Device Tree Generator correctly, the file and directory hierarchy needs to look like:
(注意:为了SDK能够正确的导入Device Tree Generator ,文件和路径层次需要相似:)
<bsp repo>/bsp/device-tree_v0_00_x/data/device-tree_v2_1_0.mld
<bsp repo>/bsp/device-tree_v0_00_x/data/device-tree_v2_1_0.tcl
就是这个<bsp repo>让我做了好多测试,突然想起导入后裸机的bsp都是在SDK_Export下,于是Xilinx Tools->Respositories,在Local Repositories中点击New,加载到Device TreeGenerator工具的目录
E:\xilinxlianxi\SDK_TEST\SDK_TEST.sdk\SDK\SDK_Export,然后点击File->New->Xilinx Board Support Package,看一下是否有了。
如果有用您就顶一下。
GMT+8, 2025-11-16 07:19 , Processed in 0.018456 second(s), 6 queries , Gzip On, Redis On.
