查看: 15742|回复: 2
[讨论] calibre lvs option
发表于 2014-5-30 12:25:52 | 显示全部楼层 |阅读模式
大家好, 我使用 calbre2008 lvs pass, calibre2011 lvs  net error ,感觉 lvs 开关选项的问题(版图,网标,lvs rule 都是相同的,好像这两个版本的默认选项不同),还请大侠多多指点,谢谢。
比较了下, calibre 2011 LVS  rule  比 calibre 2008  LVS  rule 多了 一个 error, 四个不同选项:
ERROR  Connectivity     error
LVS   FLATTEN INSIDE                       NO
LVS   SPICE SCALE X PARAMETERS     NO
LVS   SHORT EQUIVALENT  NODES      NO
LVS   FILTER  UNUSED  OPTION  AB AC AD AE RB RC RD RE ZC RG (CAL2011 没有 RG )
LVS  CAL2008 与 CAL2011  REPORT  如下:
                  ##         C A L I B R E    S Y S T E M         ##
                  ##             L V S   R E P O R T              ##
REPORT FILE NAME:         XRC9607_OTG20_PHY.lvs.report
LAYOUT NAME:              /home/user/run_calibre/run_lvs/XRC9607_OTG20_PHY.sp ('XRC9607_OTG20_PHY')
SOURCE NAME:              /home/user/2014_project/XRC96_S55NEF/trunk/XRC96_IP/XRC9607_OTG_S55NEF/analog/XRC9607_OTG20_S55NEF_201404/netlist/XRS55NEFLUSB2PHY_OTG20A.sp ('XRC9607_OTG20_PHY')
RULE FILE:                /home/user/run_calibre/run_lvs/_SmicSP1RR2R_cal55_LLRF_sali_p1mt7_121825_V1.3_2.1R.lvs_
CREATION TIME:            Wed May 28 18:24:05 2014
CURRENT DIRECTORY:        /home/user/run_calibre/run_lvs
USER NAME:                user
CALIBRE VERSION:          v2008.3_34.24    Fri Oct 3 15:32:40 PDT 2008
                               OVERALL COMPARISON RESULTS
                    #           #     INCORRECT     #
  Error:    Different numbers of instances.
  Error:    Property errors.
  Warning:  Unbalanced smashed mosfets were matched.
  Warning:  Ambiguity points were found and resolved arbitrarily.
                                      CELL  SUMMARY
  Result         Layout                        Source
  INCORRECT      XRC9607_OTG20_PHY             XRC9607_OTG20_PHY
                                      LVS PARAMETERS
o LVS Setup:
   // LVS COMPONENT TYPE PROPERTY
   // LVS COMPONENT SUBTYPE PROPERTY
   // LVS PIN NAME PROPERTY
   LVS POWER NAME                         "VDD" "SAVDD?" "?VDD?" "?VCC?" "?vcc?" "?vdd?" "AVD?" "VD*" "VRP" "VCCA?" "AVD_REF"
                                          "AVD*" "VREFP_SAR"
   LVS GROUND NAME                        "VSS" "SAVSS?" "?gnd?" "?GND?" "?VSS?" "?vss?" "AVS" "AGND?" "VRN" "VREFN_SAR"
   LVS CELL SUPPLY                        NO
   LVS RECOGNIZE GATES                    ALL
   LVS IGNORE PORTS                       NO
   LVS CHECK PORT NAMES                   YES
   LVS IGNORE TRIVIAL NAMED PORTS         NO
   LVS BUILTIN DEVICE PIN SWAP            YES
   LVS ALL CAPACITOR PINS SWAPPABLE       YES
   LVS DISCARD PINS BY DEVICE             NO
   LVS SOFT SUBSTRATE PINS                NO
   LVS INJECT LOGIC                       NO
   LVS EXPAND UNBALANCED CELLS            YES
   LVS EXPAND SEED PROMOTIONS             NO
   LVS PRESERVE PARAMETERIZED CELLS       NO
   LVS GLOBALS ARE PORTS                  YES
   LVS REVERSE WL                         NO
   LVS SPICE PREFER PINS                  YES
   LVS SPICE SLASH IS SPACE               YES
   LVS SPICE ALLOW FLOATING PINS          YES
   // LVS SPICE ALLOW INLINE PARAMETERS
   LVS SPICE ALLOW UNQUOTED STRINGS       NO
   LVS SPICE CONDITIONAL LDD              NO
   LVS SPICE CULL PRIMITIVE SUBCIRCUITS   NO
   LVS SPICE IMPLIED MOS AREA             NO
   LVS SPICE MULTIPLIER NAME              "M" "MR"
   LVS SPICE OVERRIDE GLOBALS             NO
   LVS SPICE REDEFINE PARAM               NO
   LVS SPICE REPLICATE DEVICES            NO
   LVS SPICE STRICT WL                    NO
   // LVS SPICE OPTION
   LVS STRICT SUBTYPES                    NO
   LVS EXACT SUBTYPES                     NO
   LAYOUT CASE                            NO
   SOURCE CASE                            NO
   LVS COMPARE CASE                       NO
   LVS DOWNCASE DEVICE                    NO
   LVS REPORT MAXIMUM                     ALL
   LVS PROPERTY RESOLUTION MAXIMUM        65536
   // LVS SIGNATURE MAXIMUM
   LVS FILTER UNUSED OPTION               AB AC AD AE RB RC RD RE RG ZC
   // LVS REPORT OPTION
   LVS REPORT UNITS                       YES
   // LVS NON USER NAME PORT
   // LVS NON USER NAME NET
   // LVS NON USER NAME INSTANCE
   // Device Type Map
   LVS DEVICE TYPE                        RESISTOR "rndif_ckt" [ POS=PLUS NEG=MINUS ]  SOURCE LAYOUT
   LVS DEVICE TYPE                        RESISTOR "rpdif_ckt" [ POS=PLUS NEG=MINUS ]  SOURCE LAYOUT
   LVS DEVICE TYPE                        RESISTOR "rnpo_ckt" [ POS=PLUS NEG=MINUS ]  SOURCE LAYOUT
   LVS DEVICE TYPE                        RESISTOR "rppo_ckt" [ POS=PLUS NEG=MINUS ]  SOURCE LAYOUT
   LVS DEVICE TYPE                        RESISTOR "rnwsti_ckt" [ POS=PLUS NEG=MINUS ]  SOURCE LAYOUT
   LVS DEVICE TYPE                        RESISTOR "rnwaa_ckt" [ POS=PLUS NEG=MINUS ]  SOURCE LAYOUT
   LVS DEVICE TYPE                        RESISTOR "rndifsab_ckt" [ POS=PLUS NEG=MINUS ]  SOURCE LAYOUT
   LVS DEVICE TYPE                        RESISTOR "rpdifsab_ckt" [ POS=PLUS NEG=MINUS ]  SOURCE LAYOUT
   LVS DEVICE TYPE                        RESISTOR "rnposab_ckt" [ POS=PLUS NEG=MINUS ]  SOURCE LAYOUT
   LVS DEVICE TYPE                        RESISTOR "rpposab_ckt" [ POS=PLUS NEG=MINUS ]  SOURCE LAYOUT
   LVS DEVICE TYPE                        RESISTOR "rnpo_3t_ckt" [ POS=PLUS NEG=MINUS ]  SOURCE LAYOUT
   LVS DEVICE TYPE                        RESISTOR "rppo_3t_ckt" [ POS=PLUS NEG=MINUS ]  SOURCE LAYOUT
   LVS DEVICE TYPE                        RESISTOR "rnposab_3t_ckt" [ POS=PLUS NEG=MINUS ]  SOURCE LAYOUT
   LVS DEVICE TYPE                        RESISTOR "rpposab_3t_ckt" [ POS=PLUS NEG=MINUS ]  SOURCE LAYOUT
   LVS DEVICE TYPE                        RESISTOR "rm1_ckt" [ POS=PLUS NEG=MINUS ]  SOURCE LAYOUT
   LVS DEVICE TYPE                        RESISTOR "rm2_ckt" [ POS=PLUS NEG=MINUS ]  SOURCE LAYOUT
   LVS DEVICE TYPE                        RESISTOR "rm3_ckt" [ POS=PLUS NEG=MINUS ]  SOURCE LAYOUT
   LVS DEVICE TYPE                        RESISTOR "ralpa_ckt" [ POS=PLUS NEG=MINUS ]  SOURCE LAYOUT
   LVS DEVICE TYPE                        RESISTOR "rm4_ckt" [ POS=PLUS NEG=MINUS ]  SOURCE LAYOUT
   LVS DEVICE TYPE                        RESISTOR "rm5_ckt" [ POS=PLUS NEG=MINUS ]  SOURCE LAYOUT
   LVS DEVICE TYPE                        RESISTOR "rm6_ckt" [ POS=PLUS NEG=MINUS ]  SOURCE LAYOUT
   LVS DEVICE TYPE                        RESISTOR "rtm2_ckt" [ POS=PLUS NEG=MINUS ]  SOURCE LAYOUT
   LVS DEVICE TYPE                        NMOS "n12ll_mis_ckt" SOURCE LAYOUT
   LVS DEVICE TYPE                        NMOS "nt12ll_mis_ckt" SOURCE LAYOUT
   LVS DEVICE TYPE                        NMOS "n18ll_mis_ckt" SOURCE LAYOUT
   LVS DEVICE TYPE                        NMOS "nt18ll_mis_ckt" SOURCE LAYOUT
   LVS DEVICE TYPE                        NMOS "nlvt12ll_mis_ckt" SOURCE LAYOUT
   LVS DEVICE TYPE                        NMOS "nhvt12ll_mis_ckt" SOURCE LAYOUT
   LVS DEVICE TYPE                        NMOS "dnw12ll_ckt" SOURCE LAYOUT
   LVS DEVICE TYPE                        NMOS "dnw18ll_ckt" SOURCE LAYOUT
   LVS DEVICE TYPE                        NMOS "dnwlvt12ll_ckt" SOURCE LAYOUT
   LVS DEVICE TYPE                        NMOS "dnwhvt12ll_ckt" SOURCE LAYOUT
   LVS DEVICE TYPE                        PMOS "p12ll_mis_ckt" SOURCE LAYOUT
   LVS DEVICE TYPE                        PMOS "p18ll_mis_ckt" SOURCE LAYOUT
   LVS DEVICE TYPE                        PMOS "phvt12ll_mis_ckt" SOURCE LAYOUT
   LVS DEVICE TYPE                        PMOS "plvt12ll_mis_ckt" SOURCE LAYOUT
   LVS DEVICE TYPE                        NMOS "nld50ll_ckt" SOURCE LAYOUT
   LVS DEVICE TYPE                        NMOS "nld50llod_ckt" SOURCE LAYOUT
   LVS DEVICE TYPE                        NMOS "nld50ll_sh_ckt" SOURCE LAYOUT
   LVS DEVICE TYPE                        NMOS "nld50llod_sh_ckt" SOURCE LAYOUT
   LVS DEVICE TYPE                        PMOS "pld50ll_ckt" SOURCE LAYOUT
   LVS DEVICE TYPE                        PMOS "pld50llod_ckt" SOURCE LAYOUT
   LVS DEVICE TYPE                        PMOS "pld50ll_sh_ckt" SOURCE LAYOUT
   LVS DEVICE TYPE                        PMOS "pld50llod_sh_ckt" SOURCE LAYOUT
   LVS DEVICE TYPE                        NMOS "n25ll_mis_ckt" SOURCE LAYOUT
   LVS DEVICE TYPE                        NMOS "nt25ll_mis_ckt" SOURCE LAYOUT
   LVS DEVICE TYPE                        NMOS "nod33ll_mis_ckt" SOURCE LAYOUT
   LVS DEVICE TYPE                        NMOS "nud18ll_mis_ckt" SOURCE LAYOUT
   LVS DEVICE TYPE                        NMOS "ntod33ll_mis_ckt" SOURCE LAYOUT
   LVS DEVICE TYPE                        NMOS "ntud18ll_mis_ckt" SOURCE LAYOUT
   LVS DEVICE TYPE                        PMOS "p25ll_mis_ckt" SOURCE LAYOUT
   LVS DEVICE TYPE                        PMOS "pod33ll_mis_ckt" SOURCE LAYOUT
   LVS DEVICE TYPE                        PMOS "pud18ll_mis_ckt" SOURCE LAYOUT
   LVS DEVICE TYPE                        NMOS "dnw25ll_ckt" SOURCE LAYOUT
   LVS DEVICE TYPE                        NMOS "dnwod33ll_ckt" SOURCE LAYOUT
   LVS DEVICE TYPE                        NMOS "dnwud18ll_ckt" SOURCE LAYOUT
   LVS DEVICE TYPE                        CAPACITOR "mom_2t_ckt" [ POS=PLUS NEG=MINUS ]  SOURCE LAYOUT
   LVS DEVICE TYPE                        CAPACITOR "mom_3t_ckt" [ POS=PLUS NEG=MINUS ]  SOURCE LAYOUT
   LVS DEVICE TYPE                        CAPACITOR "mom_rf" [ POS=PLUS NEG=MINUS ]  SOURCE LAYOUT
   // Reduction
   LVS REDUCE SERIES MOS                  YES
   LVS REDUCE PARALLEL MOS                YES
   LVS REDUCE SEMI SERIES MOS             NO
   LVS REDUCE SPLIT GATES                 YES
   LVS REDUCE PARALLEL BIPOLAR            YES
   LVS REDUCE SERIES CAPACITORS           NO
   LVS REDUCE PARALLEL CAPACITORS         NO
   LVS REDUCE SERIES RESISTORS            YES
   LVS REDUCE PARALLEL RESISTORS          YES
   LVS REDUCE PARALLEL DIODES             YES
CELL COMPARISON RESULTS ( TOP LEVEL )
                    #           #     INCORRECT     #
  Error:    Different numbers of instances (see below).
LAYOUT CELL NAME:         XRC9607_OTG20_PHY
SOURCE CELL NAME:         XRC9607_OTG20_PHY
INITIAL NUMBERS OF OBJECTS
                Layout    Source         Component Type
Ports:            114       115    *
Nets:           30859     30311    *
Instances:      32781     28828    *    MN (4 pins)
                 32110     28044    *    MP (4 pins)
                     9         2    *    Q (3 pins)
                     0         2    *    C (2 pins)
                     8         4    *    rppo_ckt (2 pins)
                   448       135    *    rpposab_ckt (2 pins)
                    32        13    *    D (2 pins)
Total Inst:     65388     57028
NUMBERS OF OBJECTS AFTER TRANSFORMATION
Ports:            114       114
Nets:           16804     16804
Instances:       1779      1779         MN (4 pins)
                  2730      2729    *    MP (4 pins)
                     2         2         Q (3 pins)
                     0         2    *    C (2 pins)
                     4         4         rppo_ckt (2 pins)
                   127       127         rpposab_ckt (2 pins)
                    12        12         D (2 pins)
                 10849     10849         INV (2 pins)
                  1528      1528         NAND2 (3 pins)
                    63        63         NAND3 (4 pins)
                    29        29         NAND4 (5 pins)
                   384       384         NOR2 (3 pins)
                    59        59         NOR3 (4 pins)
                    29        29         NOR4 (5 pins)
                    91        91         AOI_2_1 (4 pins)
                    80        80         AOI_2_1_1 (5 pins)
                   136       136         AOI_2_2 (5 pins)
                     5         5         AOI_2_2_1 (6 pins)
                    19        19         AOI_2_2_2 (7 pins)
                    14        14         AOI_3_1 (5 pins)
                    10        10         AOI_3_2 (6 pins)
                   155       155         OAI_2_1 (4 pins)
                    76        76         OAI_2_1_1 (5 pins)
                    79        79         OAI_2_2 (5 pins)
                    15        15         OAI_2_2_1 (6 pins)
                     2         2         OAI_2_2_2 (7 pins)
                    14        14         OAI_3_1 (5 pins)
                    12        12         OAI_3_2 (6 pins)
                     4         4         OAI_3_3 (7 pins)
                  1258      1258         SDW2 (3 pins)
                  2002      2002         SDW3 (4 pins)
                  3362      3362         SUP2 (3 pins)
                    52        52         SUP3 (4 pins)
                    74        74         SPDW_2_1 (4 pins)
                     1         1         SPDW_2_2_2 (7 pins)
                    35        35         SPUP_2_1 (4 pins)
                     1         1         SPUP_2_2_2 (7 pins)
                    62        62         SMN2 (4 pins)
                     1         1         SMN3 (5 pins)
                     4         4         SMP2 (4 pins)
                     2         2         SMP3 (5 pins)
                    33        33         SPMN((2+1)*1) (6 pins)
                    22        22         SPMP((2+1)*1) (6 pins)
Total Inst:     25216     25217
       * = Number of objects in layout different from number in source.
                                 INCORRECT OBJECTS
LEGEND:
  ne  = Naming Error (same layout name found in source
        circuit, but object was matched otherwise).
                                 INCORRECT INSTANCES
DISC#  LAYOUT NAME                                               SOURCE NAME
  1    X0/X13/X35/M3(232.930,130.085)  MP(P12LL)                 ** missing instance **
  2    ** missing instance **                                    XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DM_driver/CC0  C(CP)
  3    ** missing instance **                                    XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DP_driver/CC0  C(CP)
                                      PROPERTY ERRORS
DISC#  LAYOUT                                                    SOURCE                      ERROR
  4    X0/X15/X12/X7/M39(239.712,241.822)  MP(POD33LL)           XI_ANA/XI_Transceiver/XI_HSRCV/XI_Amp/MPM5  MP(POD33LL)
       l: 5 u                                                    l: 5.816 u                    14%
       w: 47.2 u                                                 w: 40.231 u                 17.3%
  5    X0/X13/X15/X78/M6(121.219,188.585)  MN(NOD33LL)           XI_ANA/XI_CLKGEN/XI_PLL/XI_LPF/MM4  MN(NOD33LL)
       l: 11.9881 u                                              l: 10.987 u                 9.11%
       w: 571.468 u                                              w: 649.7 u                    12%
  6    X0/X14/X13/M25(186.376,547.270)  MN(NOD33LL)              XI_ANA/XI_VREF_OTG_HOST/XI_VREF/MM48  MN(NOD33LL)
       l: 5.56485 u                                              l: 7.019 u                  20.7%
       w: 58.7706 u                                              w: 40.438 u                 45.3%
  7    X0/X14/X13/M37(214.906,534.875)  MN(NOD33LL)              XI_ANA/XI_VREF_OTG_HOST/MNcap  MN(NOD33LL)
       l: 5.38391 u                                              l: 10 u                     46.2%
       w: 49.6665 u                                              w: 10 u                      397%
  8    X0/X19/M9(256.609,96.864)  MN(NOD33LL)                    XI_ANA/XI_CLKGEN/XI_PLL/XI_VtoI/MNM2  MN(NOD33LL)
       l: 7.68706 u                                              l: 6.668 u                  15.3%
       w: 118.381 u                                              w: 141.58 u                 16.4%
  9    X0/X8/X29/M3(86.901,334.980)  MN(NOD33LL)                 XI_ANA/XI_DPM/MM18  MN(NOD33LL)
       l: 3.79285 u                                              l: 4 u                      5.18%
       w: 26.55 u                                                w: 25 u                      6.2%
10    X0/X14/X20/M1(233.701,562.439)  MN(NOD33LL)               XI_ANA/XI_VREF_OTG_HOST/XI_OTGCON/MM13  MN(NOD33LL)
       l: 5.05211 u                                              l: 5 u                      1.04%
       w: 63.6566 u                                              w: 60 u                     6.09%
11    X0/X14/X20/X53/M34(237.186,536.596)  MN(NOD33LL)          XI_ANA/XI_VREF_OTG_HOST/XI_OTGCON/XI_PD_ALL/MM17  MN(NOD33LL)
       l: 2.81824 u                                              l: 5 u                      43.6%
       w: 71.8887 u                                              w: 40 u                     79.7%
12    X0/X15/X12/X7/M31(239.907,233.072)  MN(NOD33LL)           XI_ANA/XI_Transceiver/XI_HSRCV/XI_Amp/MNM7  MN(NOD33LL)
       l: 5 u                                                    l: 6 u                      16.7%
       w: 27.2 u                                                 w: 20 u                       36%
13    X0/X15/X16/M3(235.605,245.190)  MN(NOD33LL)               XI_ANA/MM0  MN(NOD33LL)
       l: 7.68377 u                                              l: 10 u                     23.2%
       w: 280.103 u                                              w: 10 u                  2.7e+03%
14    X0/X6/X18/X1/M1(36.390,72.650)  MN(NOD33LL)               XI_ANA/XI_ID/MM0  MN(NOD33LL)
       w: 720 u                                                  w: 420 u                    71.4%
15    X0/X6/X24/X1/M1(46.058,72.700)  MP(POD33LL)               XI_ANA/XI_ID/MM4  MP(POD33LL)
       w: 672 u                                                  w: 392 u                    71.4%
16    X0/X8/X29/X30/X0/M0(93.288,330.600)  MP(POD33LL)          XI_ANA/XI_DPM/MM13  MP(POD33LL)
       l: 20 u                                                   l: 21 u                     4.76%
17    X0/X9/X7/X6/D0(6.790,573.730)  D(NDIO25LL)                XI_ANA/XI_VBUS/DD5  D(NDIO25LL)
       a: 954.245 sq u                                           a: 905.384 sq u              5.4%
18    X0/X11/X7/D0(37.249,489.110)  D(NDIO25LL)                 XI_ANA/XI_AGND1_AGND2/DD5  D(NDIO25LL)
       a: 2052.97 sq u                                           a: 1722.09 sq u             19.2%
19    X1/X8/X50/X1/M0(250.130,328.325)  MP(P25LL)               MPM0  MP(P25LL)
       l: 5 u                                                    l: 0.28 u               1.69e+03%
       w: 82.36 u                                                w: 0.21 u               3.91e+04%
20    X0/X9/X6/X7/X1/X1/X1/M3(62.940,570.720)  MN(NOD33LL)      XI_ANA/XI_VBUS/MM10  MN(NOD33LL)
       w: 960 u                                                  w: 480 u                     100%
21    X0/X9/X6/X7/X1/X1/X1/M2(62.940,569.920)  MN(NOD33LL)      XI_ANA/XI_VBUS/MM11  MN(NOD33LL)
                               INFORMATION AND WARNINGS
                  Matched    Matched    Unmatched    Unmatched    Component
                   Layout     Source       Layout       Source    Type
   Ports:             114        114            0            0
   Nets:            16804      16804            0            0
   Instances:        1468       1468            0            0    MN(N12LL)
                      311        311            0            0    MN(NOD33LL)
                     2522       2522            1            0    MP(P12LL)
                        1          1            0            0    MP(P25LL)
                      206        206            0            0    MP(POD33LL)
                        2          2            0            0    Q(PNP25A25LL_SH)
                        0          0            0            2    C(CP)
                        4          4            0            0    rppo_ckt
                      127        127            0            0    rpposab_ckt
                        4          4            0            0    D(NDIO25LL)
                        8          8            0            0    D(PDIO25LL)
                    10849      10849            0            0    INV
                     1528       1528            0            0    NAND2
                       63         63            0            0    NAND3
                       29         29            0            0    NAND4
                      384        384            0            0    NOR2
                       59         59            0            0    NOR3
                       29         29            0            0    NOR4
                       91         91            0            0    AOI_2_1
                       80         80            0            0    AOI_2_1_1
                      136        136            0            0    AOI_2_2
                        5          5            0            0    AOI_2_2_1
                       19         19            0            0    AOI_2_2_2
                       14         14            0            0    AOI_3_1
                       10         10            0            0    AOI_3_2
                      155        155            0            0    OAI_2_1
                       76         76            0            0    OAI_2_1_1
                       79         79            0            0    OAI_2_2
                       15         15            0            0    OAI_2_2_1
                        2          2            0            0    OAI_2_2_2
                       14         14            0            0    OAI_3_1
                       12         12            0            0    OAI_3_2
                        4          4            0            0    OAI_3_3
                     1258       1258            0            0    SDW2
                     2002       2002            0            0    SDW3
                     3362       3362            0            0    SUP2
                       52         52            0            0    SUP3
                       74         74            0            0    SPDW_2_1
                        1          1            0            0    SPDW_2_2_2
                       35         35            0            0    SPUP_2_1
                        1          1            0            0    SPUP_2_2_2
                       62         62            0            0    SMN2
                        1          1            0            0    SMN3
                        4          4            0            0    SMP2
                        2          2            0            0    SMP3
                       33         33            0            0    SPMN((2+1)*1)
                       22         22            0            0    SPMP((2+1)*1)
   Total Inst:      25215      25215            1            2
o Statistics:
   1 passthrough source net was deleted.
   12304 layout mos transistors were reduced to 3984.  478 connecting nets were deleted.
     7406 mos transistors were deleted by parallel reduction.
     16 mos transistors and 16 connecting nets were deleted by series reduction.
     898 mos transistors and 462 connecting nets were deleted by split-gate reduction.
   407 source mos transistors were reduced to 76.  171 connecting nets were deleted.
     1 mos transistor was deleted by parallel reduction.
     11 mos transistors and 11 connecting nets were deleted by series reduction.
     319 mos transistors and 160 connecting nets were deleted by split-gate reduction.
   8 parallel layout bipolar transistors were reduced to 1.
   369 series/parallel layout resistors were reduced to 70.  242 connecting nets were deleted.
   13 parallel source resistors were reduced to 5.
   26 parallel layout diodes were reduced to 6.
   2 parallel source diodes were reduced to 1.
   30 unused layout mos transistors were deleted.
   1 unused source mos transistor was deleted.
   26 unused layout resistors were deleted.
   100 nets were matched arbitrarily.
o Initial Correspondence Points:
   Ports:        VCCA2 VDDL AGND1 AGND2 VSSC ID DM DP VBUS AVALID BVALID CLK120_O CLK480_O
                 CLK60_30 CLK60_O DATA_IN[0] DATA_IN[1] DATA_IN[2] DATA_IN[3] DATA_IN[4]
                 DATA_IN[5] DATA_IN[6] DATA_IN[7] DATA_IN[8] DATA_IN[9] EN_OSC12M IDDIG
                 ID_PULLUP OPMODE[0] OPMODE[1] OSC_CLK PLL_EN REG_EN RESET RSTN_DLY RX_ACTIVE
                 RX_DM RX_DP RX_ERROR RX_RCV RX_VALID RX_VALIDH SELF_TEST SESSEND SUSPENDM
                 TEST_BIST TX_DAT TX_READY TX_SE0 TX_VALID TX_VALIDH UNI_BIDI_I USABLE_EN
                 TOP_TIEH TOP_TIEL CHRG_VBUS CLK_MODE_I2C[0] CLK_MODE_I2C[1] CLK_MODE_I2C[2]
                 DATA_BUS16_8 DATA_IN[10] DATA_IN[11] DATA_IN[12] DATA_IN[13] DATA_IN[14]
                 DATA_IN[15] DATA_OUT[0] DATA_OUT[1] DATA_OUT[2] DATA_OUT[3] DATA_OUT[4]
                 DATA_OUT[5] DATA_OUT[6] DATA_OUT[7] DATA_OUT[8] DATA_OUT[9] DATA_OUT[10]
                 DATA_OUT[11] DATA_OUT[12] DATA_OUT[13] DATA_OUT[14] DATA_OUT[15] DISCHRG_VBUS
                 EXTOSC_MODE FSLSSERIALMODE HOSTDISCONNECT LINE_STATE[0] LINE_STATE[1]
                 OTG_SUSPENDM SHORT_5V_ENABLE TERM_SELECT TEST_ANA_FAST TXBITSTUFFENABLE
                 TX_ENABLE_N VBUS_VALID XCVR_SELECT[0] XCVR_SELECT[1] DPPULLDOWN DMPULLDOWN
                 HSZR_CNTL_I2C[2] HSZR_CNTL_I2C[1] HSZR_CNTL_I2C[0] PLLICP_SEL_I2C
                 SQVTH_CNTL_I2C[0] SQVTH_CNTL_I2C[1] SW_RREF_I2C[2] SW_RREF_I2C[1]
                 SW_RREF_I2C[0] SW_BUF_I2C TEST_ANA_FAST_I2C[2] TEST_ANA_FAST_I2C[1]
                 TEST_ANA_FAST_I2C[0] TX2RX_T_CFG_I2C[1] TX2RX_T_CFG_I2C[0]
o Ambiguity Resolution Points:
      (Each one of the following objects belongs to a group of indistinguishable objects.
       The listed objects were matched arbitrarily by the Ambiguity Resolution feature of LVS.
       Arbitrary matching may be prevented by assigning names to these objects or to adjacent nets).
       Layout                                                    Source
                                     Nets
       X1/X8/X217/3                                              XI_DIG/XFILLER_L0N1_170/net14
       X1/X8/X216/3                                              XI_DIG/XFILLER_1960/net14
       X1/X8/X215/3                                              XI_DIG/XFILLER_1950/net14
       X1/X8/X214/3                                              XI_DIG/XFILLER_1948/net14
       X1/X8/X213/3                                              XI_DIG/XFILLER_1946/net14
       X1/X8/X212/3                                              XI_DIG/XFILLER_1936/net14
       X1/X8/X211/3                                              XI_DIG/XFILLER_1927/net14
       X1/X8/X210/3                                              XI_DIG/XFILLER_1920/net14
       X1/X8/X209/3                                              XI_DIG/XFILLER_1919/net14
       X1/X8/X208/3                                              XI_DIG/XFILLER_1915/net14
       X1/X8/X207/3                                              XI_DIG/XFILLER_1903/net14
       X1/X8/X206/3                                              XI_DIG/XFILLER_1899/net14
       X1/X8/X205/3                                              XI_DIG/XFILLER_1881/net14
       X1/X8/X204/3                                              XI_DIG/XFILLER_1852/net14
       X1/X8/X203/3                                              XI_DIG/XFILLER_1843/net14
       X1/X8/X202/3                                              XI_DIG/XFILLER_1832/net14
       X1/X8/X201/3                                              XI_DIG/XFILLER_1827/net14
       X1/X8/X200/3                                              XI_DIG/XFILLER_1816/net14
       X1/X8/X199/3                                              XI_DIG/XFILLER_1814/net14
       X1/X8/X198/3                                              XI_DIG/XFILLER_1772/net14
       X1/X8/X197/3                                              XI_DIG/XFILLER_1744/net14
       X1/X8/X196/3                                              XI_DIG/XFILLER_1708/net14
       X1/X8/X195/3                                              XI_DIG/XFILLER_1693/net14
       X1/X8/X194/3                                              XI_DIG/XFILLER_1644/net14
       X1/X8/X193/3                                              XI_DIG/XFILLER_1624/net14
       X1/X8/X192/3                                              XI_DIG/XFILLER_1607/net14
       X1/X7/X152/3                                              XI_DIG/XFILLER_1575/net14
       X1/X7/X151/3                                              XI_DIG/XFILLER_1568/net14
       X1/X7/X150/3                                              XI_DIG/XFILLER_1566/net14
       X1/X7/X149/3                                              XI_DIG/XFILLER_1557/net14
       X1/X7/X148/3                                              XI_DIG/XFILLER_1555/net14
       X1/X7/X147/3                                              XI_DIG/XFILLER_1537/net14
       X1/X7/X146/3                                              XI_DIG/XFILLER_1498/net14
       X1/X7/X145/3                                              XI_DIG/XFILLER_1474/net14
       X1/X7/X144/3                                              XI_DIG/XFILLER_1425/net14
       X1/X6/X177/3                                              XI_DIG/XFILLER_1412/net14
       X1/X6/X176/3                                              XI_DIG/XFILLER_1407/net14
       X1/X6/X175/3                                              XI_DIG/XFILLER_1398/net14
       X1/X6/X174/3                                              XI_DIG/XFILLER_1366/net14
       X1/X6/X173/3                                              XI_DIG/XFILLER_1311/net14
       X1/X6/X172/3                                              XI_DIG/XFILLER_1287/net14
       X1/X5/X279/3                                              XI_DIG/XFILLER_999/net14
       X1/X4/X322/3                                              XI_DIG/XFILLER_920/net14
       X1/X4/X321/3                                              XI_DIG/XFILLER_915/net14
       X1/X4/X320/3                                              XI_DIG/XFILLER_882/net14
       X1/X4/X319/3                                              XI_DIG/XFILLER_758/net14
       X1/X4/X318/3                                              XI_DIG/XFILLER_755/net14
       X1/X4/X317/3                                              XI_DIG/XFILLER_747/net14
       X1/X3/X314/3                                              XI_DIG/XFILLER_692/net14
       X1/X3/X313/3                                              XI_DIG/XFILLER_667/net14
       X1/X3/X312/3                                              XI_DIG/XFILLER_551/net14
       X1/X2/X150/3                                              XI_DIG/XFILLER_519/net14
       X1/X2/X149/3                                              XI_DIG/XFILLER_504/net14
       X1/X2/X148/3                                              XI_DIG/XFILLER_478/net14
       X1/X2/X147/3                                              XI_DIG/XFILLER_438/net14
       X1/X1/X264/3                                              XI_DIG/XFILLER_414/net14
       X1/X1/X263/3                                              XI_DIG/XFILLER_354/net14
       X1/X1/X262/3                                              XI_DIG/XFILLER_346/net14
       X1/X1/X261/3                                              XI_DIG/XFILLER_342/net14
       X1/X1/X260/3                                              XI_DIG/XFILLER_325/net14
       X1/X1/X259/3                                              XI_DIG/XFILLER_313/net14
       X1/X1/X258/3                                              XI_DIG/XFILLER_263/net14
       X1/X1/X257/3                                              XI_DIG/XFILLER_238/net14
       X1/X1/X256/3                                              XI_DIG/XFILLER_236/net14
       X1/X1/X255/3                                              XI_DIG/XFILLER_178/net14
       X1/X1/X254/3                                              XI_DIG/XFILLER_163/net14
       X1/X0/X122/3                                              XI_DIG/XFILLER_119/net14
       X1/X0/X121/3                                              XI_DIG/XFILLER_50/net14
       X1/X0/X120/3                                              XI_DIG/XFILLER_28/net14
       X1/X0/X119/3                                              XI_DIG/XFILLER_11/net14
       X1/X8/X816/3                                              XI_DIG/XFILLER_L0N1_186/net14
       X1/X8/X815/3                                              XI_DIG/XFILLER_L0N1_182/net14
       X1/X8/X814/3                                              XI_DIG/XFILLER_1957/net14
       X1/X7/X505/3                                              XI_DIG/XFILLER_1912/net14
       X1/X7/X504/3                                              XI_DIG/XFILLER_1621/net14
       X1/X2/X624/3                                              XI_DIG/XFILLER_1603/net14
       X1/X0/X502/3                                              XI_DIG/XFILLER_1470/net14
       X1/X0/X501/3                                              XI_DIG/XFILLER_503/net14
       X1/X0/X500/3                                              XI_DIG/XFILLER_93/net14
       X1/X0/X499/3                                              XI_DIG/XFILLER_78/net14
       X0/X8/X27/X28/X11/X1/15                                   XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DP_driver/net0201
       X0/X8/X27/X28/X11/X0/15                                   XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DP_driver/net016
       X0/X8/X27/X28/X10/X1/15                                   XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DP_driver/net0189
       X0/X8/X27/X28/X10/X0/15                                   XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DP_driver/net0442
       X0/X8/X27/X28/X10/16                                      XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DP_driver/net0153
       X0/X8/X26/X28/X11/X1/15                                   XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DM_driver/net0201
       X0/X8/X26/X28/X11/X0/15                                   XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DM_driver/net016
       X0/X8/X26/X28/X10/X1/15                                   XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DM_driver/net0189
       X0/X8/X26/X28/X10/X0/15                                   XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DM_driver/net0442
       X0/X8/X26/X28/X10/16                                      XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DM_driver/net0153
       X0/X8/X27/X28/X12/X1/15                                   XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DP_driver/net0141
       X0/X8/X27/X28/X12/16                                      XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DP_driver/net0137
       X0/X8/X27/X28/X9/15                                       XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DP_driver/net0125
       X0/X8/X26/X28/X12/X1/15                                   XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DM_driver/net0141
       X0/X8/X26/X28/X12/16                                      XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DM_driver/net0137
       X0/X8/X26/X28/X9/15                                       XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DM_driver/net0125
       X0/73                                                     XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DP_driver/net0113
       X0/70                                                     XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DM_driver/net0113
       X0/X8/X27/X18/30                                          XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DP_driver/net0267
       X0/X8/X26/X18/30                                          XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DM_driver/net0267
o Matched Mosfets Which Have Been Unequally Reduced:
       X0/X14/X20/X53/X133/M0(260.696,546.621)                   XI_ANA/XI_VREF_OTG_HOST/XI_OTGCON/XI_PD_ALL/MM32
       X0/X14/X20/X53/X135/M0(260.696,551.261)                   XI_ANA/XI_VREF_OTG_HOST/XI_OTGCON/XI_PD_ALL/MM16
       X0/X14/X20/X53/X134/M0(260.696,548.941)                   ** missing smashed mosfet **
       X0/X8/X29/X30/X0/M0(93.288,330.600)                       XI_ANA/XI_DPM/MM13
       X0/X8/X29/X31/X0/M0(91.828,330.600)                       XI_ANA/XI_DPM/MM14
       X0/X8/X29/X31/X1/M0(92.558,330.600)                       XI_ANA/XI_DPM/MM12
       X0/X8/X29/X30/X1/M0(94.018,330.600)                       ** missing smashed mosfet **
       X0/X8/X28/X4/X1/X1/M1(5.748,336.100)                      XI_ANA/XI_DPM/MM22
       X0/X8/X28/X2/X0/X0/M0(78.848,328.400)                     XI_ANA/XI_DPM/MM23
       X0/X8/X28/X2/X0/X0/M1(78.848,325.930)                     ** missing smashed mosfet **
       X0/X8/X28/X2/X0/X1/M0(78.848,325.010)                     ** missing smashed mosfet **
       X0/X8/X28/X2/X0/X1/M1(78.848,322.540)                     ** missing smashed mosfet **
       X0/X8/X28/X2/X1/X0/M0(5.748,328.400)                      ** missing smashed mosfet **
       X0/X8/X28/X2/X1/X0/M1(5.748,325.930)                      ** missing smashed mosfet **
       X0/X8/X28/X2/X1/X1/M0(5.748,325.010)                      ** missing smashed mosfet **
       X0/X8/X28/X2/X1/X1/M1(5.748,322.540)                      ** missing smashed mosfet **
       X0/X8/X28/X3/X0/X0/M0(78.848,335.180)                     ** missing smashed mosfet **
       X0/X8/X28/X3/X0/X0/M1(78.848,332.710)                     ** missing smashed mosfet **
       X0/X8/X28/X3/X0/X1/M0(78.848,331.790)                     ** missing smashed mosfet **
       X0/X8/X28/X3/X0/X1/M1(78.848,329.320)                     ** missing smashed mosfet **
       X0/X8/X28/X3/X1/X0/M0(5.748,335.180)                      ** missing smashed mosfet **
       X0/X8/X28/X3/X1/X0/M1(5.748,332.710)                      ** missing smashed mosfet **
       X0/X8/X28/X3/X1/X1/M0(5.748,331.790)                      ** missing smashed mosfet **
       X0/X8/X28/X3/X1/X1/M1(5.748,329.320)                      ** missing smashed mosfet **
       X0/X8/X28/X4/X0/X0/M0(78.848,341.960)                     ** missing smashed mosfet **
       X0/X8/X28/X4/X0/X0/M1(78.848,339.490)                     ** missing smashed mosfet **
       X0/X8/X28/X4/X0/X1/M0(78.848,338.570)                     ** missing smashed mosfet **
       X0/X8/X28/X4/X0/X1/M1(78.848,336.100)                     ** missing smashed mosfet **
       X0/X8/X28/X4/X1/X0/M0(5.748,341.960)                      ** missing smashed mosfet **
       X0/X8/X28/X4/X1/X0/M1(5.748,339.490)                      ** missing smashed mosfet **
       X0/X8/X28/X4/X1/X1/M0(5.748,338.570)                      ** missing smashed mosfet **
                                         SUMMARY
Total CPU Time:      1 sec
Total Elapsed Time:  1 sec
LVS Netlist Compiler - Errors and Warnings for "/home/user/2014_project/XRC96_S55NEF/trunk/XRC96_IP/XRC9607_OTG_S55NEF/analog/XRC9607_OTG20_S55NEF_201404/netlist/XRS55NEFLUSB2PHY_OTG20A.sp"
Warning: *.MEGA at line 17 in file "/home/user/2014_project/XRC96_S55NEF/trunk/XRC96_IP/XRC9607_OTG_S55NEF/analog/XRC9607_OTG20_S55NEF_201404/netlist/XRC9607_OTG20_ANA.sp" not applied to earlier global-scope .PARAM statements
CREATION TIME:            Wed May 28 19:01:47 2014
USER NAME:                user
CALIBRE VERSION:          v2011.2_34.26    Wed Jul 6 05:20:09 PDT 2011
                    #           #     INCORRECT     #
  Error:    Connectivity errors.
                                      CELL  SUMMARY
                                      LVS PARAMETERS
o LVS Setup:
                                          "AVD*" "VREFP_SAR"
   LVS CELL SUPPLY                        NO
   LVS IGNORE PORTS                       NO
   LVS INJECT LOGIC                       NO
   LVS FLATTEN INSIDE CELL                NO
   LVS REVERSE WL                         NO
   // LVS SPICE OPTION
   LAYOUT CASE                            NO
   SOURCE CASE                            NO
   LVS COMPARE CASE                       NO
   // Device Type Map
                    #           #     INCORRECT     #
Ports:            114       115    *
Nets:           30859     30312    *
                     9         2    *    Q (3 pins)
                     0         2    *    C (2 pins)
                    32        13    *    D (2 pins)
Ports:            114       114
Nets:           16804     16804
                     2         2         Q (3 pins)
                     0         2    *    C (2 pins)
                    12        12         D (2 pins)
                    59        59         NOR3 (4 pins)
                    29        29         NOR4 (5 pins)
                    52        52         SUP3 (4 pins)
                    62        62         SMN2 (4 pins)
                     1         1         SMN3 (5 pins)
                     4         4         SMP2 (4 pins)
                     2         2         SMP3 (5 pins)
                                 INCORRECT OBJECTS
LEGEND:
                                   INCORRECT NETS
  1    Net X0/X8/X26/X28/19                                      XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DM_driver/net0189
       (SDW2)utput                                             ** missing connection **
         X0/X8/X26/X28/X10/X0/X1/M2(24.280,306.175):s
       X0/X8/X26/X28/X10/X0/X1/X8(51.820,308.325):MINUS          ** missing connection **
       ** missing connection **                                  (SDW2)utput
        XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DM_driver/MM9:d
       ** missing connection **                                  XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DM_driver/XR2:MINUS
  2    Net X0/X8/X26/X28/X10/16                                  XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DM_driver/net016
         X0/X8/X26/X28/X10/X1/X1/M2(24.280,297.355):s
       X0/X8/X26/X28/X10/X1/X1/X8(51.820,299.505):MINUS          ** missing connection **
       ** missing connection **                                  (SDW2):output
        XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DM_driver/MM1:d
       ** missing connection **                                  XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DM_driver/XR0:MINUS
  3    Net X0/X8/X26/X28/X10/X1/15                               XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DM_driver/net0201
       (SDW2):output                                             ** missing connection **
         X0/X8/X26/X28/X10/X1/X0/M2(24.280,303.365):s
       X0/X8/X26/X28/X10/X1/X0/X8(51.820,301.215):MINUS          ** missing connection **
        XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DM_driver/MM4:d
       ** missing connection **                                  XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DM_driver/XR1:MINUS
  4    Net X0/X8/X26/X28/X11/X0/15                               XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DM_driver/net0442
         X0/X8/X26/X28/X11/X0/X0/M2(24.280,294.545):s
       X0/X8/X26/X28/X11/X0/X0/X8(51.820,292.395):MINUS          ** missing connection **
        XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DM_driver/MM21:d
       ** missing connection **                                  XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DM_driver/XR6:MINUS
  5    Net X0/X8/X26/X28/X11/X1/15                               XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DM_driver/net0153
         X0/X8/X26/X28/X11/X1/X0/M2(24.280,285.725):s
       X0/X8/X26/X28/X11/X1/X0/X8(51.820,283.575):MINUS          ** missing connection **
        XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DM_driver/MM22:d
       ** missing connection **                                  XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DM_driver/XR7:MINUS
  6    Net X0/X8/X27/X28/X10/16                                  XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DP_driver/net016
         X0/X8/X27/X28/X10/X1/X1/M2(24.280,366.645):s
       X0/X8/X27/X28/X10/X1/X1/X8(51.820,364.495):MINUS          ** missing connection **
        XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DP_driver/MM1:d
       ** missing connection **                                  XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DP_driver/XR0:MINUS
  7    Net X0/X8/X27/X28/X10/X1/15                               XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DP_driver/net0189
       X0/X8/X27/X28/X10/X1/X0/X8(51.820,362.785):MINUS          ** missing connection **
       ** missing connection **                                  XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DP_driver/XR2:MINUS
  8    Net X0/X8/X27/X28/X11/X0/15                               XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DP_driver/net0442
         X0/X8/X27/X28/X11/X0/X0/M2(24.280,369.455):s
       X0/X8/X27/X28/X11/X0/X0/X8(51.820,371.605):MINUS          ** missing connection **
        XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DP_driver/MM21:d
       ** missing connection **                                  XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DP_driver/XR6:MINUS
  9    Net X0/X8/X27/X28/X11/X1/15                               XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DP_driver/net0153
         X0/X8/X27/X28/X11/X1/X0/M2(24.280,378.275):s
       X0/X8/X27/X28/X11/X1/X0/X8(51.820,380.425):MINUS          ** missing connection **
        XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DP_driver/MM22:d
       ** missing connection **                                  XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DP_driver/XR7:MINUS
10    Net X0/X8/X26/X28/X10/X0/15                               ** no similar net **
11    Net X0/X8/X27/X28/X10/X0/15                               ** no similar net **
12    ** no similar net **                                      XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DM_driver/OUT_T
13    ** no similar net **                                      XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DP_driver/OUT_T
                                 INCORRECT INSTANCES
14    X0/X13/X37/M3(232.930,130.085)  MP(P12LL)                 ** missing instance **
15    ** missing instance **                                    XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DM_driver/CC0  C(CP)
16    ** missing instance **                                    XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DP_driver/CC0  C(CP)
                                      PROPERTY ERRORS
17    X0/X15/X16/X11/M39(239.712,241.822)  MP(POD33LL)          XI_ANA/XI_Transceiver/XI_HSRCV/XI_Amp/MPM5  MP(POD33LL)
18    X0/X13/X15/X78/M6(121.219,188.585)  MN(NOD33LL)           XI_ANA/XI_CLKGEN/XI_PLL/XI_LPF/MM4  MN(NOD33LL)
19    X0/X14/X13/M25(186.376,547.270)  MN(NOD33LL)              XI_ANA/XI_VREF_OTG_HOST/XI_VREF/MM48  MN(NOD33LL)
20    X0/X14/X13/M37(214.906,534.875)  MN(NOD33LL)              XI_ANA/XI_VREF_OTG_HOST/MNcap  MN(NOD33LL)
21    X0/X19/M9(256.609,96.864)  MN(NOD33LL)                    XI_ANA/XI_CLKGEN/XI_PLL/XI_VtoI/MNM2  MN(NOD33LL)
22    X0/X8/X29/M3(86.901,334.980)  MN(NOD33LL)                 XI_ANA/XI_DPM/MM18  MN(NOD33LL)
23    X0/X14/X20/M1(233.701,562.439)  MN(NOD33LL)               XI_ANA/XI_VREF_OTG_HOST/XI_OTGCON/MM13  MN(NOD33LL)
24    X0/X14/X20/X53/M34(237.186,536.596)  MN(NOD33LL)          XI_ANA/XI_VREF_OTG_HOST/XI_OTGCON/XI_PD_ALL/MM17  MN(NOD33LL)
25    X0/X15/X16/X11/M31(239.907,233.072)  MN(NOD33LL)          XI_ANA/XI_Transceiver/XI_HSRCV/XI_Amp/MNM7  MN(NOD33LL)
       l: 5 u                                                    l: 6 u                      16.7%
26    X0/X15/X20/M3(235.605,245.190)  MN(NOD33LL)               XI_ANA/MM0  MN(NOD33LL)
27    X0/X6/X18/X1/M1(36.390,72.650)  MN(NOD33LL)               XI_ANA/XI_ID/MM0  MN(NOD33LL)
28    X0/X6/X24/X1/M1(46.058,72.700)  MP(POD33LL)               XI_ANA/XI_ID/MM4  MP(POD33LL)
29    X0/X8/X29/X30/M0(94.018,330.600)  MP(POD33LL)             XI_ANA/XI_DPM/MM13  MP(POD33LL)
30    X0/X9/X7/X6/D0(6.790,573.730)  D(NDIO25LL)                XI_ANA/XI_VBUS/DD5  D(NDIO25LL)
31    X0/X11/X7/D0(37.249,489.110)  D(NDIO25LL)                 XI_ANA/XI_AGND1_AGND2/DD5  D(NDIO25LL)
32    X1/X8/X50/X1/M0(250.130,328.325)  MP(P25LL)               MPM0  MP(P25LL)
33    X0/X9/X6/X9/X1/X1/M3(62.940,570.720)  MN(NOD33LL)         XI_ANA/XI_VBUS/MM10  MN(NOD33LL)
34    X0/X9/X6/X9/X1/X1/M2(62.940,569.920)  MN(NOD33LL)         XI_ANA/XI_VBUS/MM11  MN(NOD33LL)
   Ports:             114        114            0            0
   Nets:            16802      16802            2            2
                        1          1            0            0    MP(P25LL)
                        0          0            0            2    C(CP)
                        4          4            0            0    rppo_ckt
                        4          4            0            0    D(NDIO25LL)
                        8          8            0            0    D(PDIO25LL)
                    10849      10849            0            0    INV
                     1528       1528            0            0    NAND2
                       63         63            0            0    NAND3
                       29         29            0            0    NAND4
                      384        384            0            0    NOR2
                       59         59            0            0    NOR3
                       29         29            0            0    NOR4
                       91         91            0            0    AOI_2_1
                       80         80            0            0    AOI_2_1_1
                      136        136            0            0    AOI_2_2
                        5          5            0            0    AOI_2_2_1
                       19         19            0            0    AOI_2_2_2
                       14         14            0            0    AOI_3_1
                       10         10            0            0    AOI_3_2
                      155        155            0            0    OAI_2_1
                       76         76            0            0    OAI_2_1_1
                       79         79            0            0    OAI_2_2
                       15         15            0            0    OAI_2_2_1
                        2          2            0            0    OAI_2_2_2
                       14         14            0            0    OAI_3_1
                       12         12            0            0    OAI_3_2
                        4          4            0            0    OAI_3_3
                     1258       1258            0            0    SDW2
                     2002       2002            0            0    SDW3
                     3362       3362            0            0    SUP2
                       52         52            0            0    SUP3
                       74         74            0            0    SPDW_2_1
                        1          1            0            0    SPDW_2_2_2
                       35         35            0            0    SPUP_2_1
                        1          1            0            0    SPUP_2_2_2
                       62         62            0            0    SMN2
                        1          1            0            0    SMN3
                        4          4            0            0    SMP2
                        2          2            0            0    SMP3
o Statistics:
   1 source net had all its pins removed and was deleted.
   90 nets and 24 instances were matched arbitrarily.
       Layout                                                    Source
                                     Nets
       X0/X8/X27/X18/32                                          XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DP_driver/net0271
       X0/X8/X26/X18/30                                          XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DM_driver/net0271
       X0/X8/X27/X28/X12/16                                      XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DP_driver/net0141
       X0/X8/X27/X28/X12/X1/15                                   XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DP_driver/net0137
       X0/X8/X27/X28/X9/15                                       XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DP_driver/net0121
       X0/X8/X26/X28/X12/16                                      XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DM_driver/net0141
       X0/X8/X26/X28/X12/X1/15                                   XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DM_driver/net0137
       X0/X8/X26/X28/X9/15                                       XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DM_driver/net0121
       X1/X0/X498/4                                              XI_DIG/XFILLER_L0N1_186/net13
       X1/X0/X499/4                                              XI_DIG/XFILLER_L0N1_182/net13
       X1/X0/X500/4                                              XI_DIG/XFILLER_1957/net13
       X1/X0/X501/4                                              XI_DIG/XFILLER_1912/net13
       X1/X0/X502/4                                              XI_DIG/XFILLER_1621/net13
       X1/X2/X624/4                                              XI_DIG/XFILLER_1603/net13
       X1/X7/X504/4                                              XI_DIG/XFILLER_1470/net13
       X1/X7/X505/4                                              XI_DIG/XFILLER_503/net13
       X1/X8/X814/4                                              XI_DIG/XFILLER_93/net13
       X1/X8/X815/4                                              XI_DIG/XFILLER_78/net13
       X1/X8/X208/3                                              XI_DIG/XFILLER_263/net14
       X1/X8/X207/3                                              XI_DIG/XFILLER_313/net14
       X1/X8/X206/3                                              XI_DIG/XFILLER_325/net14
       X1/X8/X205/3                                              XI_DIG/XFILLER_342/net14
       X1/X8/X204/3                                              XI_DIG/XFILLER_346/net14
       X1/X8/X203/3                                              XI_DIG/XFILLER_354/net14
       X1/X8/X202/3                                              XI_DIG/XFILLER_414/net14
       X1/X8/X201/3                                              XI_DIG/XFILLER_438/net14
       X1/X8/X200/3                                              XI_DIG/XFILLER_478/net14
       X1/X8/X199/3                                              XI_DIG/XFILLER_163/net14
       X1/X8/X198/3                                              XI_DIG/XFILLER_504/net14
       X1/X8/X197/3                                              XI_DIG/XFILLER_519/net14
       X1/X8/X196/3                                              XI_DIG/XFILLER_551/net14
       X1/X8/X195/3                                              XI_DIG/XFILLER_10/net14
       X1/X8/X194/3                                              XI_DIG/XFILLER_667/net14
       X1/X8/X193/3                                              XI_DIG/XFILLER_692/net14
       X1/X8/X192/3                                              XI_DIG/XFILLER_747/net14
       X1/X8/X212/3                                              XI_DIG/XFILLER_755/net14
       X1/X8/X213/3                                              XI_DIG/XFILLER_758/net14
       X1/X7/X152/3                                              XI_DIG/XFILLER_882/net14
       X1/X7/X151/3                                              XI_DIG/XFILLER_915/net14
       X1/X7/X150/3                                              XI_DIG/XFILLER_920/net14
       X1/X7/X149/3                                              XI_DIG/XFILLER_999/net14
       X1/X7/X148/3                                              XI_DIG/XFILLER_1287/net14
       X1/X7/X147/3                                              XI_DIG/XFILLER_1311/net14
       X1/X7/X146/3                                              XI_DIG/XFILLER_1366/net14
       X1/X7/X145/3                                              XI_DIG/XFILLER_1398/net14
       X1/X7/X144/3                                              XI_DIG/XFILLER_1407/net14
       X1/X6/X176/3                                              XI_DIG/XFILLER_1425/net14
       X1/X6/X175/3                                              XI_DIG/XFILLER_119/net14
       X1/X6/X174/3                                              XI_DIG/XFILLER_1474/net14
       X1/X6/X173/3                                              XI_DIG/XFILLER_1498/net14
       X1/X6/X172/3                                              XI_DIG/XFILLER_1537/net14
       X1/X5/X279/3                                              XI_DIG/XFILLER_1555/net14
       X1/X4/X322/3                                              XI_DIG/XFILLER_1557/net14
       X1/X4/X321/3                                              XI_DIG/XFILLER_1566/net14
       X1/X4/X320/3                                              XI_DIG/XFILLER_1568/net14
       X1/X4/X319/3                                              XI_DIG/XFILLER_1575/net14
       X1/X4/X318/3                                              XI_DIG/XFILLER_178/net14
       X1/X4/X317/3                                              XI_DIG/XFILLER_1607/net14
       X1/X3/X314/3                                              XI_DIG/XFILLER_236/net14
       X1/X3/X313/3                                              XI_DIG/XFILLER_1624/net14
       X1/X3/X312/3                                              XI_DIG/XFILLER_1644/net14
       X1/X8/X209/3                                              XI_DIG/XFILLER_1693/net14
       X1/X8/X214/3                                              XI_DIG/XFILLER_1708/net14
       X1/X2/X150/3                                              XI_DIG/XFILLER_1744/net14
       X1/X2/X149/3                                              XI_DIG/XFILLER_1772/net14
       X1/X2/X148/3                                              XI_DIG/XFILLER_1814/net14
       X1/X2/X147/3                                              XI_DIG/XFILLER_1816/net14
       X1/X1/X264/3                                              XI_DIG/XFILLER_1827/net14
       X1/X1/X263/3                                              XI_DIG/XFILLER_1832/net14
       X1/X1/X262/3                                              XI_DIG/XFILLER_1843/net14
       X1/X1/X261/3                                              XI_DIG/XFILLER_1852/net14
       X1/X1/X260/3                                              XI_DIG/XFILLER_1881/net14
       X1/X1/X259/3                                              XI_DIG/XFILLER_1899/net14
       X1/X1/X258/3                                              XI_DIG/XFILLER_1903/net14
       X1/X1/X257/3                                              XI_DIG/XFILLER_50/net14
       X1/X1/X256/3                                              XI_DIG/XFILLER_1915/net14
       X1/X1/X255/3                                              XI_DIG/XFILLER_1919/net14
       X1/X1/X254/3                                              XI_DIG/XFILLER_1920/net14
       X1/X8/X215/3                                              XI_DIG/XFILLER_1927/net14
       X1/X8/X216/3                                              XI_DIG/XFILLER_1936/net14
       X1/X8/X217/3                                              XI_DIG/XFILLER_1946/net14
       X1/X8/X211/3                                              XI_DIG/XFILLER_1948/net14
       X1/X8/X210/3                                              XI_DIG/XFILLER_1950/net14
       X1/X0/X122/3                                              XI_DIG/XFILLER_28/net14
       X1/X0/X121/3                                              XI_DIG/XFILLER_1960/net14
       X1/X0/X120/3                                              XI_DIG/XFILLER_L0N1_170/net14
       X1/X0/X119/3                                              XI_DIG/XFILLER_238/net14
                                   Instances
       X0/X8/X26/X28/X11/X1/X0/M7(60.210,286.595)  MP(POD33LL)   XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DM_driver/MM15  MP(POD33LL)
       X0/X8/X26/X28/X11/X0/X0/M7(60.210,295.415)  MP(POD33LL)   XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DM_driver/MM14  MP(POD33LL)
       X0/X8/X26/X28/X10/X1/X1/M7(60.210,296.485)  MP(POD33LL)   XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DM_driver/MM2  MP(POD33LL)
       X0/X8/X26/X28/X10/X1/X0/M7(60.210,304.235)  MP(POD33LL)   XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DM_driver/MM3  MP(POD33LL)
       X0/X8/X26/X28/X10/X1/X1/X8(51.820,299.505)  rpposab_ckt   XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DM_driver/XR7  rpposab_ckt
       X0/X8/X26/X28/X10/X1/X0/X8(51.820,301.215)  rpposab_ckt   XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DM_driver/XR6  rpposab_ckt
       X0/X8/X26/X28/X10/X0/X1/X8(51.820,308.325)  rpposab_ckt   XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DM_driver/XR1  rpposab_ckt
       X0/X8/X26/X28/X10/X0/X0/X8(51.820,310.035)  rpposab_ckt   XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DM_driver/XR2  rpposab_ckt
       X0/X8/X27/X28/X11/X1/X0/M7(60.210,377.405)  MP(POD33LL)   XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DP_driver/MM15  MP(POD33LL)
       X0/X8/X27/X28/X11/X0/X0/M7(60.210,368.585)  MP(POD33LL)   XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DP_driver/MM14  MP(POD33LL)
       X0/X8/X27/X28/X10/X1/X1/M7(60.210,367.515)  MP(POD33LL)   XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DP_driver/MM2  MP(POD33LL)
       X0/X8/X27/X28/X10/X1/X0/M7(60.210,359.765)  MP(POD33LL)   XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DP_driver/MM6  MP(POD33LL)
       X0/X8/X27/X28/X10/X1/X1/X8(51.820,364.495)  rpposab_ckt   XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DP_driver/XR7  rpposab_ckt
       X0/X8/X27/X28/X10/X1/X0/X8(51.820,362.785)  rpposab_ckt   XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DP_driver/XR6  rpposab_ckt
       X0/X8/X27/X28/X10/X0/X1/X8(51.820,355.675)  rpposab_ckt   XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DP_driver/XR1  rpposab_ckt
       X0/X8/X27/X28/X10/X0/X0/X8(51.820,353.965)  rpposab_ckt   XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DP_driver/XR2  rpposab_ckt
       (SDW2)                                                    (SDW2)
       Transistors:
         X0/X8/X26/X28/X11/X1/X0/M3(24.280,286.495)  MN(NOD33LL)   XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DM_driver/MM5  MN(NOD33LL)
         X0/X8/X26/X28/X11/X1/X0/M2(24.280,285.725)  MN(NOD33LL)   XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DM_driver/MM4  MN(NOD33LL)
       (SDW2)                                                    (SDW2)
       Transistors:
         X0/X8/X26/X28/X10/X0/X1/M3(24.280,305.405)  MN(NOD33LL)   XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DM_driver/MM23  MN(NOD33LL)
         X0/X8/X26/X28/X10/X0/X1/M2(24.280,306.175)  MN(NOD33LL)   XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DM_driver/MM22  MN(NOD33LL)
       (SDW2)                                                    (SDW2)
       Transistors:
         X0/X8/X26/X28/X10/X1/X1/M3(24.280,296.585)  MN(NOD33LL)   XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DM_driver/MM20  MN(NOD33LL)
         X0/X8/X26/X28/X10/X1/X1/M2(24.280,297.355)  MN(NOD33LL)   XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DM_driver/MM21  MN(NOD33LL)
       (SDW2)                                                    (SDW2)
       Transistors:
         X0/X8/X26/X28/X10/X0/X0/M3(24.280,312.955)  MN(NOD33LL)   XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DM_driver/MM8  MN(NOD33LL)
         X0/X8/X26/X28/X10/X0/X0/M2(24.280,312.185)  MN(NOD33LL)   XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DM_driver/MM9  MN(NOD33LL)
       (SDW2)                                                    (SDW2)
       Transistors:
         X0/X8/X27/X28/X10/X0/X1/M3(24.280,358.595)  MN(NOD33LL)   XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DP_driver/MM5  MN(NOD33LL)
         X0/X8/X27/X28/X10/X0/X1/M2(24.280,357.825)  MN(NOD33LL)   XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DP_driver/MM4  MN(NOD33LL)
       (SDW2)                                                    (SDW2)
       Transistors:
         X0/X8/X27/X28/X10/X1/X1/M3(24.280,367.415)  MN(NOD33LL)   XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DP_driver/MM23  MN(NOD33LL)
         X0/X8/X27/X28/X10/X1/X1/M2(24.280,366.645)  MN(NOD33LL)   XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DP_driver/MM22  MN(NOD33LL)
       (SDW2)                                                    (SDW2)
       Transistors:
         X0/X8/X27/X28/X10/X0/X0/M3(24.280,351.045)  MN(NOD33LL)   XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DP_driver/MM20  MN(NOD33LL)
         X0/X8/X27/X28/X10/X0/X0/M2(24.280,351.815)  MN(NOD33LL)   XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DP_driver/MM21  MN(NOD33LL)
       (SDW2)                                                    (SDW2)
       Transistors:
         X0/X8/X27/X28/X10/X1/X0/M3(24.280,359.865)  MN(NOD33LL)   XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DP_driver/MM8  MN(NOD33LL)
         X0/X8/X27/X28/X10/X1/X0/M2(24.280,360.635)  MN(NOD33LL)   XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DP_driver/MM9  MN(NOD33LL)
       X0/X8/X29/X30/M0(94.018,330.600)                          XI_ANA/XI_DPM/MM13
       X0/X8/X29/X33/M0(91.828,330.600)                          XI_ANA/XI_DPM/MM14
       X0/X8/X29/X32/M0(92.558,330.600)                          XI_ANA/XI_DPM/MM12
       X0/X8/X29/X31/M0(93.288,330.600)                          ** missing smashed mosfet **
       X0/X8/X28/X5/X1/X1/M1(5.748,322.540)                      XI_ANA/XI_DPM/MM22
       X0/X8/X28/X2/X0/M0(78.848,341.960)                        XI_ANA/XI_DPM/MM23
       X0/X8/X28/X2/X0/M1(78.848,339.490)                        ** missing smashed mosfet **
       X0/X8/X28/X2/X1/M0(78.848,338.570)                        ** missing smashed mosfet **
       X0/X8/X28/X2/X1/M1(78.848,336.100)                        ** missing smashed mosfet **
       X0/X8/X28/X3/X0/M0(5.748,341.960)                         ** missing smashed mosfet **
       X0/X8/X28/X3/X0/M1(5.748,339.490)                         ** missing smashed mosfet **
       X0/X8/X28/X3/X1/M0(5.748,338.570)                         ** missing smashed mosfet **
       X0/X8/X28/X3/X1/M1(5.748,336.100)                         ** missing smashed mosfet **
       X0/X8/X28/X4/X0/X0/M0(78.848,335.180)                     ** missing smashed mosfet **
       X0/X8/X28/X4/X0/X0/M1(78.848,332.710)                     ** missing smashed mosfet **
       X0/X8/X28/X4/X0/X1/M0(78.848,331.790)                     ** missing smashed mosfet **
       X0/X8/X28/X4/X0/X1/M1(78.848,329.320)                     ** missing smashed mosfet **
       X0/X8/X28/X4/X1/X0/M0(78.848,328.400)                     ** missing smashed mosfet **
       X0/X8/X28/X4/X1/X0/M1(78.848,325.930)                     ** missing smashed mosfet **
       X0/X8/X28/X4/X1/X1/M0(78.848,325.010)                     ** missing smashed mosfet **
       X0/X8/X28/X4/X1/X1/M1(78.848,322.540)                     ** missing smashed mosfet **
       X0/X8/X28/X5/X0/X0/M0(5.748,335.180)                      ** missing smashed mosfet **
       X0/X8/X28/X5/X0/X0/M1(5.748,332.710)                      ** missing smashed mosfet **
       X0/X8/X28/X5/X0/X1/M0(5.748,331.790)                      ** missing smashed mosfet **
       X0/X8/X28/X5/X0/X1/M1(5.748,329.320)                      ** missing smashed mosfet **
       X0/X8/X28/X5/X1/X0/M0(5.748,328.400)                      ** missing smashed mosfet **
       X0/X8/X28/X5/X1/X0/M1(5.748,325.930)                      ** missing smashed mosfet **
       X0/X8/X28/X5/X1/X1/M0(5.748,325.010)                      ** missing smashed mosfet **
                             DETAILED INSTANCE CONNECTIONS
          (This section contains detailed information about connections of
           matched instances that are involved in net discrepancies).
         PLUS: DM                                                  PLUS: DM
         MINUS: X0/X8/X26/X28/X10/X0/15                            ** no similar net **
         ** X0/X8/X26/X28/19 **                                    MINUS: XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DM_driver/net0189
         PLUS: DM                                                  PLUS: DM
         MINUS: X0/X8/X26/X28/19                                   ** XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DM_driver/net0189 **
         ** X0/X8/X26/X28/X10/X1/15 **                             MINUS: XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DM_driver/net0201
         PLUS: DM                                                  PLUS: DM
         MINUS: X0/X8/X26/X28/X10/X1/15                            ** XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DM_driver/net0201 **
         ** X0/X8/X26/X28/X11/X0/15 **                             MINUS: XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DM_driver/net0442
         PLUS: DM                                                  PLUS: DM
         MINUS: X0/X8/X26/X28/X10/16                               ** XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DM_driver/net016 **
         ** X0/X8/X26/X28/X11/X1/15 **                             MINUS: XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DM_driver/net0153
       X0/X8/X26/X28/X11/X0/X0/X8(51.820,292.395)  rpposab_ckt    XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DM_driver/XR0  rpposab_ckt
         PLUS: DM                                                  PLUS: DM
         MINUS: X0/X8/X26/X28/X11/X0/15                            ** XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DM_driver/net0442 **
         ** X0/X8/X26/X28/X10/16 **                                MINUS: XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DM_driver/net016
       X0/X8/X26/X28/X11/X1/X0/X8(51.820,283.575)  rpposab_ckt    XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DM_driver/XR28  rpposab_ckt
         PLUS: DM                                                  PLUS: DM
         MINUS: X0/X8/X26/X28/X11/X1/15                            ** XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DM_driver/net0153 **
         ** no similar net **                                      MINUS: XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DM_driver/OUT_T
         PLUS: DP                                                  PLUS: DP
         MINUS: X0/X8/X27/X28/X10/X0/15                            ** no similar net **
         ** X0/X8/X27/X28/X10/X1/15 **                             MINUS: XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DP_driver/net0189
         PLUS: DP                                                  PLUS: DP
         MINUS: X0/X8/X27/X28/X10/X1/15                            ** XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DP_driver/net0189 **
         ** X0/X8/X27/X28/X11/X0/15 **                             MINUS: XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DP_driver/net0442
         PLUS: DP                                                  PLUS: DP
         MINUS: X0/X8/X27/X28/X10/16                               ** XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DP_driver/net016 **
         ** X0/X8/X27/X28/X11/X1/15 **                             MINUS: XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DP_driver/net0153
       X0/X8/X27/X28/X11/X0/X0/X8(51.820,371.605)  rpposab_ckt    XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DP_driver/XR0  rpposab_ckt
         PLUS: DP                                                  PLUS: DP
         MINUS: X0/X8/X27/X28/X11/X0/15                            ** XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DP_driver/net0442 **
         ** X0/X8/X27/X28/X10/16 **                                MINUS: XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DP_driver/net016
       X0/X8/X27/X28/X11/X1/X0/X8(51.820,380.425)  rpposab_ckt    XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DP_driver/XR28  rpposab_ckt
         PLUS: DP                                                  PLUS: DP
         MINUS: X0/X8/X27/X28/X11/X1/15                            ** XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DP_driver/net0153 **
         ** no similar net **                                      MINUS: XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DP_driver/OUT_T
       (SDW2)                                                    (SDW2)
         input: X0/X8/X26/54                                       input: XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DM_driver/N_driver
         input: X0/X8/X26/41                                       input: XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DM_driver/net015
         output: X0/X8/X26/X28/19                                  ** XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DM_driver/net0189 **
         ** X0/X8/X26/X28/X11/X1/15 **                             output: XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DM_driver/net0153
       Transistors:
       (SDW2)                                                    (SDW2)
         output: X0/X8/X26/X28/X10/16                              ** XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DM_driver/net016 **
         ** X0/X8/X26/X28/X11/X0/15 **                             output: XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DM_driver/net0442
       Transistors:
       (SDW2)                                                    (SDW2)
         output: X0/X8/X26/X28/X10/X0/15                           ** no similar net **
         ** X0/X8/X26/X28/19 **                                    output: XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DM_driver/net0189
       Transistors:
       (SDW2)                                                    (SDW2)
         output: X0/X8/X26/X28/X10/X1/15                           ** XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DM_driver/net0201 **
         ** X0/X8/X26/X28/X10/16 **                                output: XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DM_driver/net016
       Transistors:
         X0/X8/X26/X28/X10/X1/X0/M3(24.280,304.135)  MN(NOD33LL)   XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DM_driver/MM0  MN(NOD33LL)
         X0/X8/X26/X28/X10/X1/X0/M2(24.280,303.365)  MN(NOD33LL)   XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DM_driver/MM1  MN(NOD33LL)
       (SDW2)                                                    (SDW2)
         output: X0/X8/X26/X28/X11/X0/15                           ** XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DM_driver/net0442 **
         ** no similar net **                                      output: XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DM_driver/OUT_T
       Transistors:
         X0/X8/X26/X28/X11/X0/X0/M3(24.280,295.315)  MN(NOD33LL)   XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DM_driver/MM61  MN(NOD33LL)
         X0/X8/X26/X28/X11/X0/X0/M2(24.280,294.545)  MN(NOD33LL)   XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DM_driver/MM60  MN(NOD33LL)
       (SDW2)                                                    (SDW2)
         output: X0/X8/X26/X28/X11/X1/15                           ** XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DM_driver/net0153 **
         ** X0/X8/X26/X28/X10/X1/15 **                             output: XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DM_driver/net0201
       Transistors:
       (SDW2)                                                    (SDW2)
         input: X0/X8/X27/54                                       input: XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DP_driver/N_driver
         input: X0/X8/X27/41                                       input: XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DP_driver/net015
         output: X0/X8/X27/X28/X10/16                              ** XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DP_driver/net016 **
         ** X0/X8/X27/X28/X11/X1/15 **                             output: XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DP_driver/net0153
       Transistors:
       (SDW2)                                                    (SDW2)
         output: X0/X8/X27/X28/X10/X0/15                           ** no similar net **
         ** X0/X8/X27/X28/X11/X0/15 **                             output: XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DP_driver/net0442
       Transistors:
       (SDW2)                                                    (SDW2)
         output: X0/X8/X27/X28/X11/X0/15                           ** XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DP_driver/net0442 **
         ** X0/X8/X27/X28/X10/16 **                                output: XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DP_driver/net016
       Transistors:
         X0/X8/X27/X28/X11/X0/X0/M3(24.280,368.685)  MN(NOD33LL)   XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DP_driver/MM0  MN(NOD33LL)
         X0/X8/X27/X28/X11/X0/X0/M2(24.280,369.455)  MN(NOD33LL)   XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DP_driver/MM1  MN(NOD33LL)
       (SDW2)                                                    (SDW2)
         output: X0/X8/X27/X28/X11/X1/15                           ** XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DP_driver/net0153 **
         ** no similar net **                                      output: XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DP_driver/OUT_T
       Transistors:
         X0/X8/X27/X28/X11/X1/X0/M3(24.280,377.505)  MN(NOD33LL)   XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DP_driver/MM61  MN(NOD33LL)
         X0/X8/X27/X28/X11/X1/X0/M2(24.280,378.275)  MN(NOD33LL)   XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DP_driver/MM60  MN(NOD33LL)
                                         SUMMARY
发表于 2016-4-15 10:18:44 | 显示全部楼层
篇幅吓到人了
回复 支持 2 反对 0
 楼主| 发表于 2016-4-18 20:01:10 | 显示全部楼层
问题已解决, 现在使用的是  2013 的版本。
GMT+8, 2025-12-26 10:41 , Processed in 0.038297 second(s), 5 queries , Gzip On, Redis On.
