查看: 2211|回复: 1
[原创] DC不能生成网表文件是什么原因?
发表于 2014-5-20 10:27:34 | 显示全部楼层 |阅读模式
compilelog如下;
                        DC Professional (TM)
                           DC Expert (TM)
                            DC Ultra (TM)
                       FloorPlan Manager (TM)
                          HDL Compiler (TM)
                         VHDL Compiler (TM)
                        Library Compiler (TM)
                      DesignWare Developer (TM)
                          DFT Compiler (TM)
                            BSD Compiler
                         Power Compiler (TM)
             Version B-2008.09 for linux -- Aug 25, 2008
              Copyright (c) 1988-2008 by Synopsys, Inc.
                         ALL RIGHTS RESERVED
This software and the associated documentation are confidential and
proprietary to Synopsys, Inc. Your use or disclosure of this software
is subject to the terms and conditions of a written license agreement
between you, or your company, and Synopsys, Inc.
The above trademark notice does not imply that you are licensed to use
all of the listed products. You are licensed to use only those products
for which you have lawfully obtained a valid license key.
Initializing...
#                      script                                         #
#set rpt_file "/home/project/spi_syn/log/spi.rpt"
#set design   "/home/project/spi_syn/src/spi.v"
#set log_directory "/home/project/spi_syn/log/"
read_file -format verilog {/home/project/spi_syn/src/spi.v}
Loading db file '/eda/synopsys/dc2008_09/libraries/syn/gtech.db'
Loading db file '/eda/synopsys/dc2008_09/libraries/syn/standard.sldb'
  Loading link library 'gtech'
Loading verilog file '/home/project/spi_syn/src/spi.v'
Detecting input file type automatically (-rtl or -netlist).
Running DC verilog reader
Reading with Presto HDL Compiler (equivalent to -rtl option).
Running PRESTO HDLC
Compiling source file /home/project/spi_syn/src/spi.v
Statistics for case statements in always block at line 191 in file
|           Line           |  full/ parallel  |
|           192            |    auto/auto     |
Statistics for case statements in always block at line 247 in file
|           261            |    auto/auto     |
|           298            |    auto/auto     |
Inferred memory devices in process
in routine SPI_CORE line 158 in file
'/home/project/spi_syn/src/spi.v'.
|    Register Name    |   Type    | Width | Bus | MB | AR | AS | SR | SS | ST |
|    reset_d2n_reg    | Flip-flop |   1   |  N  | N  | N  | N  | N  | N  | N  |
|    reset_dn_reg     | Flip-flop |   1   |  N  | N  | N  | N  | N  | N  | N  |
|    reset_d3n_reg    | Flip-flop |   1   |  N  | N  | N  | N  | N  | N  | N  |
|    rst_sclkp_reg    | Flip-flop |   1   |  N  | N  | N  | N  | N  | N  | N  |
in routine SPI_CORE line 173 in file
|    omux_sel_reg     | Flip-flop |   2   |  N  | N  | N  | N  | N  | N  | N  |
|    data_out_reg     | Flip-flop |  16   |  Y  | N  | N  | N  | N  | N  | N  |
in routine SPI_CORE line 227 in file
|    stat_mat_reg     | Flip-flop |   1   |  N  | N  | N  | N  | N  | N  | N  |
|     clk_cnt_reg     | Flip-flop |   4   |  Y  | N  | N  | N  | N  | N  | N  |
|     spi_st_reg      | Flip-flop |   3   |  Y  | N  | N  | N  | N  | N  | N  |
|     data_in_reg     | Flip-flop |  14   |  Y  | N  | N  | N  | N  | N  | N  |
|     rd_wrn_reg      | Flip-flop |   1   |  N  | N  | N  | N  | N  | N  | N  |
in routine SPI_CORE line 166 in file
|    rst_sclkn_reg    | Flip-flop |   1   |  N  | N  | N  | N  | N  | N  | N  |
in routine SPI_CORE line 206 in file
|   pre_data_wr_reg   | Flip-flop |   1   |  N  | N  | N  | N  | N  | N  | N  |
|    stat_rd_o_reg    | Flip-flop |   1   |  N  | N  | N  | N  | N  | N  | N  |
|   pre_stat_rd_reg   | Flip-flop |   1   |  N  | N  | N  | N  | N  | N  | N  |
|    data_reg_reg     | Flip-flop |  12   |  Y  | N  | N  | N  | N  | N  | N  |
|    data_wr_o_reg    | Flip-flop |   1   |  N  | N  | N  | N  | N  | N  | N  |
Presto compilation completed successfully.
Current design is now '/home/project/spi_syn/src/SPI_CORE.db:SPI_CORE'
Loaded 1 design.
Current design is 'SPI_CORE'.
SPI_CORE
read_file -format verilog {/home/project/spi_syn/src/buf_i.v}
Loading verilog file '/home/project/spi_syn/src/buf_i.v'
Performing 'read' command.
Compiling source file /home/project/spi_syn/src/buf_i.v
Reading with netlist reader (equivalent to -netlist option).
Verilog netlist reader completed successfully.
Current design is now '/home/project/spi_syn/src/PS_IBUF.dbS_IBUF'
Loaded 1 design.
Current design is 'PS_IBUF'.
PS_IBUF
read_file -format verilog {/home/project/spi_syn/src/buf_o.v}
Loading verilog file '/home/project/spi_syn/src/buf_o.v'
Compiling source file /home/project/spi_syn/src/buf_o.v
Current design is now '/home/project/spi_syn/src/PS_OBUF.dbS_OBUF'
Loaded 1 design.
Current design is 'PS_OBUF'.
PS_OBUF
#report lib cell's information
#report_lib lsi_10k.lib -all
current_design SPI_CORE
{SPI_CORE}
link
  Linking design 'SPI_CORE'
  Using the following designs and libraries:
  * (3 designs)               /home/project/spi_syn/src/SPI_CORE.db, etc
1
reset_design
1
#check_design
set auto_wire_load_selection true
true
set_wire_load_mode enclosed
1
#this value should be consistent with target library max_fanout&fanout_load
set_fanout_load 2.0 [all_outputs]
1
set_drive       1.0 {SDIN}
1
# clock frequency is set as 10Mhz
set clk_name SCLK
SCLK
create_clock -period 100 -waveform [list 0 50] $clk_name
1
set_clock_latency 2.0 [get_clocks $clk_name]
1
set_clock_uncertainty -setup 1.0    [get_clocks $clk_name]
1
set_clock_uncertainty -hold  0.5    [get_clocks $clk_name]
1
set_clock_transition 0.5            [get_clocks $clk_name]
1
set_drive 0 $clk_name
1
set_structure -boolean true -boolean_effort high
1
set_structure -timing true
1
set_fix_multiple_port_nets -all -buffer_constants
1
# PS_ibuf does not exists in target library?
#set_driving_cell -lib_cell PS_IBUF -pin Z [all_inputs]
#set_driving_cell -lib_cell PS_IBUF  {stat_i[0]}
#set_driving_cell -lib_cell reset_n_buf -pin Z {reset_n_i}
source /home/project/spi_syn/script/timing.tcl
set_load 1.0 DATA
1
set_load 1.0 DATA_WR
1
set_load 1.0 SDOUT
1
#define design constraints
set_input_delay  60   -clock $clk_name { RESET_N }
1
set_input_delay  60   -clock $clk_name { CS_N    }
1
set_input_delay  60   -clock $clk_name { SDIN    }
1
set_input_delay  60   -clock $clk_name { ADDR    }
1
#set_input_delay  60   -clock $clk_name { ADDR[11]    }
set_input_delay  65   -clock $clk_name { SDINIT  }
1
set_input_delay  65   -clock $clk_name { BPIN    }
1
set_input_delay  65   -clock $clk_name { STATUS  }
1
set_input_delay  65   -clock $clk_name { INTRPT  }
1
set_output_delay 70   -clock $clk_name { STAT_RD DATA DATA_WR SDOUT}
1
check_timing
Information: Updating design information... (UID-85)
Information: Checking generated_clocks...
Information: Checking loops...
Information: Checking no_input_delay...
Information: Checking unconstrained_endpoints...
Information: Checking pulse_clock_cell_type...
1
#set_max_delay 75 -to {SDOUT}
set_max_area 0
1
set command_log_file  "./transcript.log"
./transcript.log
set view_command_log_file "./view_command.log"
./view_command.log
#report_timing -from SDIN -to SDOUT
#report_design
report_area
Report : area
Design : SPI_CORE
Version: B-2008.09
Date   : Tue May 20 10:00:53 2014
Library(s) Used:
    gtech (File: /eda/synopsys/dc2008_09/libraries/syn/gtech.db)
Number of ports:               53
Number of nets:               501
Number of cells:              343
Number of references:          27
Combinational area:          0.000000
Noncombinational area:       0.000000
Net Interconnect area:      undefined  (No wire load specified)
Total cell area:             0.000000
Total area:                 undefined
Information: This design contains unmapped logic. (RPT-7)
1
alias sc_on  syntax_check  true
alias sc_off syntax_check  false
alias cc_on  context_check true
alias cc_off context_check false
echo syntax_check_status
syntax_check_status
echo context_check_status
sc_off
Syntax checker off.
1
cc_on
Context checker on.
1
set_fsm_encoding_style binary
report_fsm
report_constraint
#fsm_auto_inferring true
#hdlin_reporting_level comprehensive
uniquify
#compile!
compile -exact_map -map_effort high
#generate netlist file (verilog)
write -hierarchy -output spi.db
write -format verilog -hierarchy -output /home/project/spi_syn/script/spi.sv
write_sdf -version 2.1  /home/project/spi_syn/sdf/SPI_CORE.sdf
#write_sdc                 sdc_script_file.sdc
#save design before quit dc_shell(ddc)
write -format ddc  -hierarchy -output  spi.ddc
set hdlin_report_inferred_modules verbose
verbose
#check_design
#/home/project/spi_syn/script/spi.v
dc_shell> quit
Memory usage for this session 26 Mbytes.
CPU usage for this session 1 seconds.
Thank you...
发表于 2014-5-21 07:54:23 | 显示全部楼层
路过看看  帮你顶下
GMT+8, 2025-12-25 09:13 , Processed in 0.043402 second(s), 6 queries , Gzip On, Redis On.
