查看: 2990|回复: 4
[讨论] Design a new high speed data transceiver By AXSEM Chips
发表于 2014-5-12 15:26:30 | 显示全部楼层 |阅读模式
Hello to everyone,
I try to design a new High speed data transceiver by AXSEM chips. These chips are programmable and have a various modulation such as FSK, MSK, GFSK, GMSK, OQPSK & ASK, PSK. I suggest that we get together to have a good design.
Many Thanks
发表于 2014-5-12 21:34:41 | 显示全部楼层
谢谢楼主 分享
 楼主| 发表于 2014-5-13 02:11:15 | 显示全部楼层
回复 2# li90ying
Your welcome....
 楼主| 发表于 2014-5-13 02:15:46 | 显示全部楼层
AXSEM ax5042 also has these features:
AXSEM The most intelligent RF.
Your key benefits:
• RX sensitivities at 868 MHz
-121 dBm for 1.2 kbps FSK
-104 dBm for 100 kbps FSK
• RX sensitivities at 433 MHz
-123 dBm for 1.2 kbps FSK
-106 dBm for 100 kbps FSK
• TX and RX data rates
1-250 kbps for FSK
600 kbps for ASK/PSK
• All modulations shaped
 楼主| 发表于 2014-5-13 02:48:38 | 显示全部楼层
I have a few design, for now i shared one of them.
This figure shows Typical application diagram with single-ended antenna and internal TX/RX switch.
GMT+8, 2025-12-25 18:34 , Processed in 0.031189 second(s), 7 queries , Gzip On, Redis On.
