查看: 11714|回复: 16
[求助] ubuntu 装vcs遇到的问题
发表于 2014-5-1 19:50:06 | 显示全部楼层 |阅读模式
我的版本是:ubuntu 14.04,64位系统。没用虚拟机vcs版本是201306,scl是10.9.3,installer是v3.0,按照论坛上的教程已经装完了,license也用lmstat和lmgrd验证过了,如下
root@ashley-HP:~# lmstat -c /home/ashley/synopsys/setup_files/license/synopsys.dat
lmstat - Copyright (c) 1989-2006 Macrovision Europe Ltd. and/or Macrovision Corporation. All Rights Reserved.
Flexible License Manager status on Thu 5/1/2014 19:36
License server status: 27000@ashley-HP
    License file(s) on ashley-HP: /home/ashley/synopsys/setup_files/license/synopsys.dat:
lmgrd is not running: Cannot connect to license server system. (-15,570:115 "Operation now in progress")
root@ashley-HP:~# lmgrd -c /home/ashley/synopsys/setup_files/license/synopsys.dat
19:37:01 (lmgrd) -----------------------------------------------
19:37:01 (lmgrd)   Please Note:
19:37:01 (lmgrd)
19:37:01 (lmgrd)   This log is intended for debug purposes only.
19:37:01 (lmgrd)   In order to capture accurate license
19:37:01 (lmgrd)   usage data into an organized repository,
19:37:01 (lmgrd)   please enable report logging. Use Macrovision's
19:37:01 (lmgrd)   software license administration  solution,
19:37:01 (lmgrd)   FLEXnet Manager, to  readily gain visibility
19:37:01 (lmgrd)   into license usage data and to create
19:37:01 (lmgrd)   insightful reports on critical information like
19:37:01 (lmgrd)   license availability and usage. FLEXnet Manager
19:37:01 (lmgrd)   can be fully automated to run these reports on
19:37:01 (lmgrd)   schedule and can be used to track license
19:37:01 (lmgrd)   servers and usage across a heterogeneous
19:37:01 (lmgrd)   network of servers including Windows NT, Linux
19:37:01 (lmgrd)   and UNIX. Contact Macrovision at
19:37:01 (lmgrd)   www.macrovision.com for more details on how to
19:37:01 (lmgrd)   obtain an evaluation copy of FLEXnet Manager
19:37:01 (lmgrd)   for your enterprise.
19:37:01 (lmgrd)
19:37:01 (lmgrd)
19:37:01 (lmgrd)
19:37:01 (lmgrd) The license server manager (lmgrd) running as root:
19:37:01 (lmgrd)     This is a potential security problem
19:37:01 (lmgrd)     and is not recommended.
root@ashley-HP:~# 19:37:01 (lmgrd) FLEXnet Licensing (v10.8.5.0 build 31891 i86_re3) started on ashley-HP (linux) (5/1/2014)
19:37:01 (lmgrd) Copyright (c) 1988-2006 Macrovision Europe Ltd. and/or Macrovision Corporation. All Rights Reserved.
19:37:01 (lmgrd) US Patents 5,390,297 and 5,671,412.
19:37:01 (lmgrd) World Wide Web:  http://www.macrovision.com
19:37:01 (lmgrd) License file(s): /home/ashley/synopsys/setup_files/license/synopsys.dat
19:37:01 (lmgrd) lmgrd tcp-port 27000
19:37:01 (lmgrd) The license server manager has found no vendor daemons to start
19:37:01 (lmgrd)  (There are no VENDOR (or DAEMON) lines in the license file),
    lmgrd exiting.
dve &
[1] 16618
root@ashley-HP:~# Cannot connect to the license server.
The connect() system call failed.
Make sure that your SNPSLMD_LICENSE_FILE is pointing to the right
location and that the license server is up.
Retrying request.....
Failed to obtain license...
Note: Use +vcs+lic+wait ( or -licwait <minute> or -licqueue  in Unified Use Model ) to queue for license
但是确弄不成功,是怎么回事啊!求大神!
发表于 2014-5-2 11:41:13 | 显示全部楼层
换个系统试一下吧
发表于 2014-5-4 14:38:23 | 显示全部楼层
license文件里没把daemon写进去。
发表于 2014-12-11 14:48:43 | 显示全部楼层
回复 3# orlye
how to do ?
发表于 2015-6-28 13:12:11 | 显示全部楼层
请问下scl 和installer 在哪里可以下载
发表于 2015-6-28 21:46:37 | 显示全部楼层
回复 5# huanghx
善用搜索功能,论坛上到处都是
发表于 2015-7-10 10:00:48 | 显示全部楼层
回复 6# wind1986
   但是都没说怎么解决的额
发表于 2015-7-10 10:40:11 | 显示全部楼层
果然还是license的生成有问题啊
发表于 2015-7-11 22:31:51 | 显示全部楼层
thank you , the same question  to  you ,,i have try
发表于 2015-7-11 23:23:31 | 显示全部楼层
i want to download the soft ware ,could share vcs for me ?
GMT+8, 2025-12-27 20:27 , Processed in 0.021415 second(s), 7 queries , Gzip On, Redis On.
