查看: 3340|回复: 0
[招聘] InvenSense热招持续进行中(数字IC设计/验证,上海张江)
发表于 2014-4-19 16:58:02 | 显示全部楼层 |阅读模式
这周已经陆续对之前投简历的候选者进行了面试,热招持续进行中, 请有兴趣者踊跃投递简历。
   重点:这是InvenSense在上海成立R&D 之后的第一轮社招,刚开始扩张,机会应该是相当不错, 关于工作年限那块,牛人可以放宽到3年以上
1.Digital RTL Design and Implementation (synthesis \ DFT \ Timing Closure) Engineer
Responsibilities:
•    Digital RTL design and implementation for mixed signal/SoC ICs
•    Starting from Verilog RTL, and using industry standard tools, implement the design through synthesis, floor planning, clock tree synthesis and routing.
Block level RTL design.
•    Perform static timing analysis(STA) and help to identify and fix timing problems in the design
•    Perform design for test (DFT) and test pattern generation (ATPG).
•    Close interaction with analog/mixed signal designers.
Qualifications:
•    Master's degree with at least 5 years of experience with digital RTL design and flow.
•    Experience with RTL design
•    Experience with one of the below area
o    Synthesis,
o    Timing analysis / Timing Closure
o    DFT
•    Knowledge of  Audio processing or signal processing or SOC design is a big plus
•    Knowledge of scripting languages such as Perl and Tcl is a plus.
•    Good English written and verbal communication skills.
•    Excellent communication and team-oriented skills.
•    Self-motivated individual willing to take ownership and responsibility.
2. Digital Verification Engineer (mixed signal/SoC)
Responsibilities:
•    Verification with Verilog / System Verilog / UVM
•    Setup verification testbench in module level and Chip level, define and execute verification plan with full functional coverage.
•    Doing simulation in Gate Level and doing co-simulation with analog designer.
•    Interact with design team to achieve design quality and meet schedule target.
•    Document and review detail test plans, testbench and meet verification goals.
•    Support silicon evaluation effort.
Qualifications:
•    Master's degree with 5+ years of experience with SoC/Mix-signals IC verification
•    Knowledge of OVM/VMM/UVM
•    Knowledge of Audio processing or signal processing or SOC design is a big plus.
•    Familiar with digital & mixed signal verification tools, such as NC-verilog/Verdi/Vplan.
•    Familiar with Verilog/ System Verilog/ System C language.
简历请发送:
ypan@invensense.com
GMT+8, 2025-12-14 10:17 , Processed in 0.013980 second(s), 8 queries , Gzip On, Redis On.
