查看: 13355|回复: 14
[求助] Cadence IC6151 在运行spectre仿真出现问题
发表于 2014-4-13 22:12:33 | 显示全部楼层 |阅读模式
大家帮我看看,我为啥出错误了,谢谢大家!
Cadence (R) Virtuoso (R) Spectre (R) Circuit Simulator
Version 10.1.1.017 32bit -- 25 Nov 2010
Copyright (C) 1989-2010 Cadence Design Systems, Inc. All rights reserved worldwide. Cadence, Virtuoso and Spectre are registered trademarks of Cadence Design Systems, Inc. All others are the property of their respective holders.
Protected by U.S. Patents:
        5,610,847; 5,790,436; 5,812,431; 5,859,785; 5,949,992; 5,987,238;
        6,088,523; 6,101,323; 6,151,698; 6,181,754; 6,260,176; 6,278,964;
        6,349,272; 6,374,390; 6,493,849; 6,504,885; 6,618,837; 6,636,839;
        6,778,025; 6,832,358; 6,851,097; 6,928,626; 7,024,652; 7,035,782;
        7,085,700; 7,143,021; 7,493,240; 7,571,401.
Includes RSA BSAFE(R) Cryptographic or Security Protocol Software from RSA Security, Inc.
Simulating `input.scs' on localhost.localdomain at 10:18:17 PM, Sun Apr 13, 2014 (process id: 25024).
Command line:
        /home/xiejing/eda/cadence/MMSIM10/tools.lnx86/spectre/bin/32bit/spectre  \
        input.scs +escchars +log ../psf/spectre.out +inter=mpsc  \
        +mpssession=spectre0_24473_2 -format sst2 -raw ../psf  \
        +lqtimeout 900 -maxw 5 -maxn 5
spectre pid = 25024
Loading /home/xiejing/eda/cadence/MMSIM10/tools.lnx86/cmi/lib/5.0/libinfineon_sh.so ...
Loading /home/xiejing/eda/cadence/MMSIM10/tools.lnx86/cmi/lib/5.0/libphilips_sh.so ...
Loading /home/xiejing/eda/cadence/MMSIM10/tools.lnx86/cmi/lib/5.0/libsparam_sh.so ...
Loading /home/xiejing/eda/cadence/MMSIM10/tools.lnx86/cmi/lib/5.0/libstmodels_sh.so ...
Error found by spectre during circuit read-in.
    ERROR (SFE-675): "/home/xiejing/foundry2/smic180/TD-MM18-SP-2001v7R/ms018_v1p6_spe.lib" 4: Illegal library definition found in netlist
Time for NDB Parsing: CPU = 797.878 ms, elapsed = 821.377 ms.
Time accumulated: CPU = 797.878 ms, elapsed = 821.377 ms.
Peak resident memory used = 31.2 Mbytes.
Time for parsing: CPU = 0 s, elapsed = 25.034 us.
Time accumulated: CPU = 797.878 ms, elapsed = 821.932 ms.
Aggregate audit (10:18:17 PM, Sun Apr 13, 2014):
Time used: CPU = 802 ms, elapsed = 826 ms, util. = 97%.
Time spent in licensing: elapsed = 723 ms, percentage of total = 87.5%.
Peak memory used = 31.2 Mbytes.
spectre completes with 1 error, 0 warnings, and 0 notices.
spectre terminated prematurely due to fatal error.
 楼主| 发表于 2014-4-14 13:48:18 | 显示全部楼层
怎么没有人给我回复呢?
发表于 2014-6-7 15:45:17 | 显示全部楼层
同问啊
发表于 2014-7-2 14:51:00 | 显示全部楼层
我跟你的错误一模一样 请问楼主怎么解决的
发表于 2014-7-7 21:48:57 | 显示全部楼层
相同问题求高手帮忙解决下啊!
发表于 2014-7-17 10:29:13 | 显示全部楼层
好!!!!!!!!!
发表于 2014-8-18 11:50:26 | 显示全部楼层
应该你没有把你工艺库设置好!  打开ADE  》》setup  》》 library module setup 这里面把你库加载进来就行了!
发表于 2014-8-18 16:42:55 | 显示全部楼层
你是不是把32位的操作系统换成64位的了?
发表于 2014-9-11 23:19:57 | 显示全部楼层
感謝大大分享
发表于 2014-9-12 20:00:40 | 显示全部楼层
谢谢楼主分享资料  收下了
GMT+8, 2025-9-14 08:50 , Processed in 0.019473 second(s), 5 queries , Gzip On, Redis On.
